Hi all,
First of all, I am sorta new to arduino. I have two HR-SR04 rangefinders that I purchased off Amazon. I quickly pulled them out, wired them up, and downloaded (of course ) the newping library. Got it all set, loaded up an example program to test one of the sensors. Changed the pin numbers to match the ones my sensor was hooked up to, and uploaded.
At first, i thought it was working fine…Until i tried measuring anything passed 50cm. below 50cm, it was perfectly accurate (i have a meter stick out and was checking the sensor against that). However, after moving the piece of cardboard i was using to test the sensor with out to around 150 cm, i would just return a value between 50 to 60cm.
I traded out the sensors (thinking one might have been damaged), and got the same problem. afterwards, I tried changing the code to fix it, but it’s still not working. Here are the changes and code. Thanks to anyone who can help me.
I have also removed the default comments from the example code to make room for my own…
#include <NewPing.h>
#define TRIGGER_PINÂ 11Â //plugged into the "trig" pin of the sensor
#define ECHO_PINÂ Â 9Â //plugged into the "echo" pin of the sensor
#define MAX_DISTANCE 200 //changed this value several times, from 100, 200, 400, and 500 cm
int led = 12; //I always have an led in so i know when the program has started
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE);
 Serial.begin(115200); // Open serial monitor at 115200 baud to see ping results.
 pinMode(led, OUTPUT); //my led code
 digitalWrite(led, HIGH); /my led code
 delay(250);           // started this value at 50, then changed to 1000, and to 250, no luck
 unsigned int uS = sonar.ping(); // Send ping, get ping time in microseconds (uS).
 Serial.print("Ping: ");
 Serial.print(uS / US_ROUNDTRIP_CM); // Convert ping time to distance in cm and print result (0 = outside set distance range)
 Serial.println("cm");
And that’s it. I have no idea why these will not work past 50cm. and yes, the vcc and ground pins are hooked up to the 5v and gnd pins of the arduino
TechnoD
