Hi Everyone.
So I have a servo motor, HS-422:
Amazon.com: Hitec RCD 31422S HS-422 Deluxe Servo: Toys & Games
And I am currently running this simple code:
#include <Servo.h>
int servopin = 3;
int servoPos = 0;
Servo MyServo;
MyServo.attach(servopin);
Serial.println("What angle for the Servo?");
while(Serial.available()==0){
servoPos = Serial.parseInt();
MyServo.write(servoPos);
When i first ran the code with the servo powered by the Arduino, it worked as intended. However, a day later, I ran the same code through the Servo, powered by the Arduino again. What it does now is that after I give the servo an angle, it rotates to that angle for a split second and then resets at the zero position.
I read online that a possibility could be the draw current is insufficient. I have a DC power supply in possession and I was wondering if that would be useful as a power source instead of the UNO. I tried it with the power supply and I still get the same result. I have the negative terminal of the power supply commonly grounded to the arduino's ground.
Does anyone have any ideas what may be going wrong?
