Hello,
If you want to send commands from a remote control driven by a HT12E chip to your Arduino board, then this is the right library for you.
This new library for HT12E is intended to follow the same underlining principles of other libraries.
HT12E.cpp
HT12E Support for Arduino
The purpose of this library is to enable your Arduino to receive commands remotely
from a HT12E-driven device or control.
Note : make sure HT12E is operating at 3~4kHz clock range
Author: Marcelo Shiniti Uchimura
Date : Sep '13
#include "HT12E.h"
HT12E::HT12E(int pin, unsigned int addrMask)
_pin = pin;
pinMode(_pin, INPUT);
_data = 0;
_mask = addrMask << 4; // the HT12E basic word is a stream with an 8-bit address
// followed by 4-bit data. I left shift the
// address mask 4 bits so I can match it to the entire word
int HT12E::read()
return _data;
int HT12E::error()
uint8_t temp = _flags;
_flags = 0;
return temp & B00001111; // LSB of _flags is the error flag
uint8_t HT12E::maskMatchesIncomingData()
if((_data & _mask) < _mask)
_flags |= B1000;
return 0;
return 1;
uint8_t HT12E::dataStreamAvailable()
uint8_t ctr;
/* let's get the address+data bits now */
for(_data = 0, ctr = 0; ctr < DATASIZE; ++ctr)
_dur = pulseIn(_pin, HIGH);
if(_dur > 250 && _dur < 333) // if pulse width is between 1/4000 and 1/3000 secs
_data = (_data << 1) + 1; // attach a *1* to the rightmost end of the buffer
else if(_dur > 500 && _dur < 666) // if pulse width is between 2/4000 and 2/3000 secs
_data = (_data << 1); // attach a *0* to the rightmost end of the buffer
_flags |= B0100;
return 0;
return 1;
uint8_t HT12E::syncBitGone()
/* now wait until sync bit is gone */
for(uint8_t ctr = 0; ctr < MAXTRIES; ++ctr)
if(digitalRead(_pin) == LOW)
return 1;
delayMicroseconds(80);
_flags |= B0010;
return 0;
uint8_t HT12E::pilotStreamAvailable()
/* look for HT12E basic word's pilot stream */
while(digitalRead(_pin) == LOW); // wait for the signal to go HIGH
_dur = pulseIn(_pin, LOW);
if(_dur > 9000 && _dur < 12000)
return 1; // 36x(clock tick interval)
_flags |= B0001;
return 0;
int HT12E::available()
_flags = 0; // initializes error handling reference
if (pilotStreamAvailable()
&& syncBitGone()
&& dataStreamAvailable()
&& maskMatchesIncomingData())
_data ^= _mask;
return 1;
_data = 0;
return 0;
HT12E.h
Date : Sep '13
#ifndef HT12E_h
#define HT12E_h
#define MAXTRIES 13
#define DATASIZE 12
#include "Arduino.h"
class HT12E
public:
HT12E(int pin, unsigned int addrMask); // this is the constructor
int read(); // this is the main method
int error(); // for error handling purpose
int available(); // used when there's potentially significant data
private:
uint8_t _pin; // this is Arduino input pin
unsigned int _data; // this is data
unsigned int _mask; // this is the address mask
uint8_t _flags; // handles error() (bit 0, 1, 2, and 3) flag
unsigned long _dur; // pulse duration
uint8_t pilotStreamAvailable();
uint8_t syncBitGone();
uint8_t dataStreamAvailable();
uint8_t maskMatchesIncomingData();
#endif
Usage example sketch
#include <HT12E.h>
HT12E remoteControl(7, B01111111); /* the incoming stream is tied to pin 7, and the address mask is the binary 01111111 */
if (remoteControl.available() > 0)
unsigned int data;
data = remoteControl.read();
Serial.println("I have just received the following data stream: ");
Serial.println(data, BIN);
switch (remoteControl.error())
case 0:
case 1:
Serial.println("Failure when waiting for a pilot stream");
case 2:
Serial.println("Failure when waiting for sync bit to go away");
case 4:
Serial.println("Failure when waiting for a data stream");
case 8:
Serial.println("Data mask does not match predefined address mask");
default:
Serial.println("Unknown error occurred");
