I need some help to configure a HTML button. This button serve to control a LED with the Ethernet Sheild.
I started with that :
cl.println("<input type=\"button\" name=\"BT\" value=\"Ouverture\" onclick=\"submit();\">");
I don't know how to have a resquest.
Thanks for help.
Server test code with buttons.
//zoomkat 3-17-12
//simple button GET server code to control servo and arduino pin 5
//for use with IDE 1.0
//open serial monitor to see what the arduino receives
//use the \ slash to escape the " in the html
//address will look like http://192.168.1.102:84 when submited
//for use with W5100 based ethernet shields
//Powering a servo from the arduino usually DOES NOT WORK.
//note that the below bug fix may be required
// http://code.google.com/p/arduino/issues/detail?id=605
#include <SPI.h>
#include <Ethernet.h>
#include <Servo.h>
Servo myservo; // create servo object to control a servo
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte ip[] = { 192, 168, 1, 102 }; // ip in lan
byte gateway[] = { 192, 168, 1, 1 }; // internet access via router
byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
EthernetServer server(84); //server port
String readString;
void setup(){
pinMode(5, OUTPUT); //pin selected to control
//start Ethernet
Ethernet.begin(mac, ip, gateway, gateway, subnet);
server.begin();
myservo.write(90); //set initial servo position if desired
myservo.attach(7); //the pin for the servo co
//enable serial data print
Serial.println("server LED test 1.0"); // so I can keep track of what is loaded
void loop(){
// Create a client connection
if (client) {
while (client.connected()) {
if (client.available()) {
char c = client.read();
//read char by char HTTP request
if (readString.length() < 100) {
//store characters to string
readString += c;
//Serial.print(c);
//if HTTP request has ended
if (c == '\n') {
Serial.println(readString); //print to serial monitor for debuging
client.println("HTTP/1.1 200 OK"); //send new page
client.println("Content-Type: text/html");
client.println();
client.println("<HTML>");
client.println("<HEAD>");
client.println("<TITLE>Arduino GET test page</TITLE>");
client.println("</HEAD>");
client.println("<BODY>");
client.println("<H1>Zoomkat's simple Arduino button</H1>");
// DIY buttons
client.println("<a href=\"/?on5\"\">ON</a>");
client.println("<a href=\"/?off5\"\">OFF</a>
// mousedown buttons
client.println("
<input type=\"button\" value=\"ON\" onmousedown=\"location.href ('/?on5');\"/>");
client.println("<input type=\"button\" value=\"OFF\" onmousedown=\"location.href ('/?off5');\"/>");
// mousedown radio buttons
client.println("
<input type=\"radio\" value=\"ON\" onmousedown=\"location.href ('/?on5');\"\">ON</>");
client.println("<input type=\"radio\" value=\"OFF\" onmousedown=\"location.href ('/?off5');\"\">OFF</>");
client.println("</BODY>");
client.println("</HTML>");
delay(1);
//stopping client
client.stop();
///////////////////// control arduino pin
if(readString.indexOf("on5") >0)//checks for on5
myservo.write(40);
digitalWrite(5, HIGH); // set pin 5 high
Serial.println("Led On");
if(readString.indexOf("off5") >0)//checks for off5
myservo.write(140);
digitalWrite(5, LOW); // set pin 5 low
Serial.println("Led Off");
//clearing string for next read
readString="";
I use ethernet sheild, and I want to use button like this example :
for control LED.
Guillaume_Lalande:
Start you dev : focus développement et programmation
for control LED.
There seems to be several examples there. Which one are you talking about?
