Html form only seems to take 1 value
Bit of a beginner with html and forms here.
This code only seems to take input value 1 and NOT input value 2!
For example when the ''submit'' button on the web based input screen in clicked I only receive a message that input 1 value has been set!
In addition I'm displaying the web based input onto an LCD and the same, the data does not seem to be passed on.
Any help on what I'm not doing right will be greatly appreciated indeed.
#include <ESP8266WiFi.h>
#include <ESP8266WebServer.h>
// WiFi credentials
const char* ssid = "xxxx";
const char* password = "xxxxxx";
// Web server port
const int serverPort = 80;
// Web server object
ESP8266WebServer server(serverPort);
// Variables to store input numbers
int input1 = 0;
int input2 = 0;
// Variables to store output pins
int output1 = 14;
int output2 = 15;
// Variables to store input pins
int inputPin1 = 13;
int inputPin2 = 15;
// Timer variables
unsigned long timer1 = 0;
unsigned long timer2 = 0;
int buttonState = 0;
LiquidCrystal_I2C lcd(0x26, 20, 4); // LCD address is 0x26
  lcd.init();
 // Turn on the backlight.
  lcd.backlight();
 // Move the cursor 5 characters to the right and
 // zero characters down (line 1).
  lcd.setCursor(0, 0);
 // Print HELLO to the screen, starting at 5,0.
  lcd.print("Teddy Fox Brewery");
  // Move the cursor to the next line and print
  // WORLD.
  lcd.setCursor(0, 1);
  lcd.print("Beer Filler 5000");
  // initialize the pushbutton pin as an input
  pinMode(input1, INPUT);
  // initialize the LED pin as an output
  pinMode(output1, OUTPUT);
  // Initialize serial monitor
  // Connect to WiFi network
  WiFi.begin(ssid, password);
    Serial.print(".");
  // Print WiFi network information to Serial and LCD
  Serial.println("");
  Serial.println("WiFi connected");
  lcd.setCursor(0, 2);
  lcd.print("WiFi connected");
  Serial.print("IP address: ");
  lcd.setCursor(0, 3);
  lcd.print("IP:");
  lcd.setCursor(4, 3);
  lcd.print(WiFi.localIP());
  // Initialize web server
  server.on("/", handleRoot);
  server.on("/input1", handleInput1);
  server.on("/input2", handleInput2);
  server.begin();
  Serial.println("Web server started");
// Handle root page request
void handleRoot() {
  // Send HTML code for input page
 server.send(200, "text/html", "<html><body><h1>Input Page</h1><form action='/input1'><label for='input1'>Input 1:</label><input type='number' id='input1' name='input1'><br><label for='input2'>Input 2:</label><input type='number' id='input2' name='input2'><br><input type='submit' value='Submit'></form></body></html>");
// Handle input 1 page request
void handleInput1() {
  // Get input 1 value from URL parameter
  input1 = server.arg("input1").toInt();
  // Send HTML code for success page
  server.send(200, "text/html", "<html><body><h1>Success!</h1><p>Input 1 value set to " + String(input1) + " milliseconds.</p></body></html>");
 lcd.clear();
 lcd.print("Purge:");
 lcd.setCursor(7, 0);
 lcd.print(input1);
 lcd.print(" m/Sec");
// Handle input 2 page request
void handleInput2() {
  // Get input 2 value from URL parameter
  input2 = server.arg("input2").toInt();
  server.send(200, "text/html", "<html><body><h1>Success!</h1><p>Input 2 value set to " + String(input2) + " milliseconds.</p></body></html>");
 lcd.print("Beer :");
 lcd.setCursor(7, 1);
 lcd.print(input2);
 // Handle web server requests
  server.handleClient();
 // Check if input 1 button is pressed
  if (digitalRead(inputPin1) == HIGH) {
    Serial.println("button 1 pressed");
    Serial.println(input1);
  //Start timer for output 1
    timer1 = millis();
  //Turn on output 1
    digitalWrite(output1, HIGH);
  // Check if input 2 button is pressed
  if (digitalRead(inputPin2) == HIGH) {
     //Start timer for output 2
    timer2 = millis();
    // Turn on output 2
    digitalWrite(output2, HIGH);
 // Check if timer for output 1 has reached input 1 value
  if (millis() - timer1 >= input1) {
    // Turn off output 1
    digitalWrite(output1, LOW);
  // Check if timer for output 2 has reached input 2 value
  if (millis() - timer2 >= input2) {
    // Turn off output 2
    digitalWrite(output2, LOW);
An HTML form sends data with a single request. If you create a page with 100 input elements, your web server won’t have to handle 100 different requests, but a single request that passes 100 different parameters. Your endpoint on the microcontroller that will handle this request will then process each parameter individually.
Since the form is set to call the /input1 endpoint:
// Handle HTML form request
  // etc etc
void handleInput2() is completely useless.
It would also be good practice to check whether the request actually contains the required parameter using the hasArg("argname") method.
  if (server.hasArg("input1"))
  if (server.hasArg("input2"))
  // etc etc
Perfect....Works a treat now...Thanks so much.....and obvious once it was pointed out....I was just stuck in a loop myself....Cheers
