I am trying to make an HTML page that can read the filenames on the SD card.
This is working when I type the HTML code in the Arduino IDE, but I want to have the HTML file on the SD card and let the Arduino read the file.
Here is the full code:
#include <SPI.h>
#include <Ethernet.h>
#include <SD.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(172, 30, 107, 24);
EthernetServer server(80);
String fileNames[13];
int f;
while (!Serial) {
Ethernet.begin(mac, ip);
Serial.print("Initializing SD card...");
if (!SD.begin(4)) {
Serial.println("initialization failed!");
return;
Serial.println("initialization done.");
server.begin();
searchSDFiles();
for (int i = 0; i < f; i++) {
Serial.println(fileNames[i]);
if (client) {
// an http request ends with a blank line
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) {
char c = client.read();
// if you've gotten to the end of the line (received a newline
// character) and the line is blank, the http request has ended,
// so you can send a reply
if (c == '\n' && currentLineIsBlank) {
// send a standard http response header
client.println("Content-Type: text/html");
client.println("Connection: close"); // the connection will be closed after completion of the response
client.println();
client.println("<!DOCTYPE HTML>");
client.println("<html>");
client.println("<head>");
client.println("</head>");
client.println("<body>");
client.println("<select class=\"files\">");
client.println("<option value=\"" + String(i) + "\">");
client.println(fileNames[i]);
client.println("</option>");
client.println("</select>");
client.println("
client.println("<textarea id=\"fileText\">");
client.println("</textarea>");
client.println("</body>");
client.println("</html>");
if (c == '\n') {
// you're starting a new line
} else if (c != '\r') {
// you've gotten a character on the current line
currentLineIsBlank = false;
// give the web browser time to receive the data
delay(1);
// close the connection:
client.stop();
void searchSDFiles() {
File logFile = SD.open("/");
File entry = logFile.openNextFile();
f = 0;
while (true) {
if (! entry) {
// no more files
fileNames[f] = String(entry.name());
entry.close();
f++;
PS: does anyone know why I can't read as many files on the SD card as I want?
when I try to read 20 files, I get no output. And when I try to read 17 files, I get strange characters in the file name.
azerty2001:
I need to have the filenames stored in an array, because i need them later.
thanks for your help Juraj, but how can I send a string from the arduino to the HTML file(from the SD card) as an option.
you would need some template engine to combine a web page template from SD card with data on Arduino. other options are to concatenate the page from constant strings and data, or send a static page to browser and let it request data from arduino and merge this data into web page in browser
azerty2001:
what is the best option? and how do I do it, because I don't know how to start.
simplest is what you have.
template engines are only for bigger MCUs.
best is, to let the work be done by the browser on a client device. but then you code it for browser in Java Script or similar
I don't really understand what you mean. Could you give me a link where I can see an example of how it's done?
PS: Do you mean with template engine mysql and php?
azerty2001:
you know what is a template.
template engine is a general name for function/library that takes template and data and produces the output document/report
i have watched a video about the esp8266 and that is maybe a good solution for my problem. But does they exist so I can use a network cable, instead of wifi?
azerty2001:
yes, but it would be strange to use a chip with build-in WiFi with Ethernet
