So i have a eight channel relay board which I m wanting to control via internet through a ethernet shield for my arduino
And i got this code from the net which works very well when I m controlling three to four relays of the eight channel board
but when i add buttons on the html page for more than four to five relays, the html page dosent load
Is there a way u can show me how can i include additional buttons in the code to control the entire eight channel relay board without exceeding the space which can be used for the html page
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = { 0x00, 0xAA, 0xBB, 0xCC, 0xDA, 0x02 };
IPAddress ip(192,168,1,177);
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
EthernetServer server(80);
String readString = String(100); //string for fetching data from address
pinMode(6, OUTPUT);
pinMode(5, OUTPUT);
pinMode(7, OUTPUT);
// start the Ethernet connection and the server
Serial.println("Initiaizing ethernet...");
// this uses a fixed address
Ethernet.begin(mac, ip);
// get an address with DHCP
//if (Ethernet.begin(mac) == 0)
// Serial.println("Failed to configure Ethernet using DHCP");
// give the card a second to initialize
server.begin();
Serial.print("Home Automation Control Ready at IP address ");
Serial.println(Ethernet.localIP());
// command received (one character) '1' - activate garage door button
char cmd = 0; // 1 - pulse button
boolean done = false; // set to indicate that response is complete
// listen for incoming clients
if (client) {
Serial.println("new client");
readString = "";
while (client.connected()) {
if (client.available()) {
char c = client.read();
Serial.write(c);
//int i = c;
//Serial.print("(");
//Serial.print(i);
//Serial.print(")");
// store character received in receive string
if (readString.length() < 100) {
readString += (c);
// check for end of line
if (c == '\n') {
//Serial.print("Receved line: ");
//Serial.print(readString);
// process line if its the "GET" request
// a request looks like "GET /?1" or "GET /?2"
if (readString.indexOf("GET") != -1) {
if (readString.indexOf("?1") != -1)
cmd = '1';
if (readString.indexOf("?2") != -1)
cmd = '2';
if (readString.indexOf("?3") != -1)
cmd = '3';
if (readString.indexOf("?4") != -1)
cmd = '4';
if (readString.indexOf("?5") != -1)
cmd = '5';
if (readString.indexOf("?6") != -1)
cmd = '6';
// check for other commands here. ie turn on light, etc.
//if (readString.indexOf("?2") != -1)
// cmd = '2';
// if a blank line was received (just cr lf, length of 2), then its the end of the request
if (readString.length() == 2) {
if (cmd == '1'){
Serial.println("Activate Button");
digitalWrite(6, HIGH);
if (cmd == '2'){
digitalWrite(6, LOW);
if (cmd == '3'){
digitalWrite(5, HIGH);
if (cmd == '4'){
digitalWrite(5, LOW);
if (cmd == '5'){
digitalWrite(7, HIGH);
if (cmd == '6'){
digitalWrite(7, LOW);
// add other commands here
// send web page back to client
Serial.println("sending web page");
SendWebPage(client);
Serial.println("web page sent");
cmd = 0;
// break out and disconnect. This will tell the browser the request is complete without having to specify content-length
} // end of request reached
// start line over
readString = "";
} // end of line reached
} // end data is available from client
} // end cient is connected
// give the web browser time to receive the data
Serial.println("delay before disconnect");
delay(100);
// close the connection:
client.stop();
Serial.println("client disonnected");
} // end client has been created
// send web page
void SendWebPage(EthernetClient client)
client.println("Content-Type: text/html");
// to specify the length, wooul have to construct the entire string and then get its length
//client.println("Content-Length: 1234");
client.println("Connnection: close");
client.println();
client.println("<!DOCTYPE HTML>");
client.println("<html>");
client.println("<head>");
client.println("<title>Garage Door Control</title>");
client.println("<style type='text/css'>");
client.println(".label {font-size: 40px; text-align:center;}");
client.println("button {width: 200px; height: 100px; font-size: 40px; -webkit-appearance: none; background-color:white; }");
client.println("</style>");
client.println("<script type='text/javascript'>");
client.println("function OnButtonClicked(parm) { window.location.href=\"X?\" + parm; }");
client.println("</script>");
client.println("</head>");
client.println("<body style=\"background-color:orange\">");
client.println("<div class=\"label\">");
client.println("Garage Door Control
// future idea: could read a limit switch on the garage door here and tell the user if the door is currently open or closed
if (digitalRead(DOOR_OPEN_INPUT) == HIGH)
client.println("Door is Open");
client.println("Door is Closed");
client.println("
// door open / close button
client.println("<button onclick=\"OnButtonClicked('1');\">Light ON</button>
client.println("<div style=\"height:20px\"></div>");
client.println("<button onclick=\"OnButtonClicked('2');\">Light Off</button>");
client.println("<button onclick=\"OnButtonClicked('3');\">Fan ON</button>");
client.println("<button onclick=\"OnButtonClicked('4');\">FAN OFF</button>");
client.println("<button onclick=\"OnButtonClicked('5');\">Fan ON</button>");
client.println("<button onclick=\"OnButtonClicked('6');\">FAN OFF</button>");
// add more buttons here
// button separator
//client.println("<div style=\"height:20px\"></div>");
//client.println("<button onclick=\"OnButtonClicked('2');\">Off</button>");
client.println("</div>");
client.println("</body>");
client.println("</html>");
client.println("");
GarageDoorStackOverflow.ino (7.25 KB)
