HTML page uploading the readings of temperature sensor in continuously
Hello, I have been using Adafruit Feather board with the Temperature sensor and while trying to upload my readings on the HTML page it is showing the value, running in the loop continuously
#include <ESP8266WiFi.h>
#include <Wire.h>
#include <ESP8266WebServer.h>
// SHT31 I2C address is 0x44(68)
#define Addr 0x44
// Replace with your network credentials
const char* ssid     = "DcubeAirtel";
const char* password = "D@Airtel190";
float Ctemp,Ftemp,humid;
// Set web server port number to 80
WiFiServer server(80);
// Variable to store the HTTP request
String header;
  Wire.begin(2,14);
  // Connect to Wi-Fi network with SSID and password
  Serial.print("Connecting to ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
  Serial.print(".");
  // Print local IP address and start web server
  Serial.println("");
  Serial.println("WiFi connected.");
  Serial.println("IP address: ");
  server.begin();
void loop(){
  temptask();
  WiFiClient client = server.available();   // Listen for incoming clients
  if (client)
   {                             // If a new client connects,
    Serial.println("New Client.");          // print a message out in the serial port
    String currentLine = "";                // make a String to hold incoming data
     from the client
    while (client.connected()) {            // loop while the client's connected
      if (client.available()) {             // if there's bytes to read from the
     client,
       String c = client.readStringUntil('\r');             // read a byte, then
       Serial.println(c);
     }                    // print it out the serial monitor
       // if the current line is blank, you got two newline characters in a row.
       // that's the end of the client HTTP request, so send a response:
        // HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
        // and a content-type so the client knows what's coming, then a blank line:
        client.println("Content-type:text/html");
        client.println("Connection: close");
        client.println();
          String PAGE2 =
 "<!DOCTYPE html>"
 "<html>"
 "<head>"
 "<meta charset=\"utf-8\">"
 "<meta name = \"viewport\" content = \"width = device-width, initial-scale = 1.0\">"
 "<title> My first HTML page</title>"
 "</head>"
 "<body style= \"background-color:#EDEEF2\">"
 "<h1 style= \"color:blue\">Temperature and Humidity</h1>"
 "<h3 style= \"font-family:verdana; color:blue\">Temperature in Celcius:</h3>"
 "<p style=\"font-size:160%; font-family:Lucida Console\">"+String(Ctemp,1)+
 "</p>"
 "<h3 style= \"font-family:verdana; color:blue\">Temperature in Fahrenheit:</h3>"
 "<p style=\"font-size:160%; font-family:Lucida Console\">"+String(Ftemp,1)+
 "</p>"
 "<h3 style= \"font-family:verdana; color:blue\">Humidity:</h3>"
 "<p style=\"font-size:160%; font-family:Lucida Console\">"+String(humid,1)+
 "</p>"
 "</body>"
 "</html>";
        // Display the HTML web page
        client.println(PAGE2);
// Clear the header variable
// Close the connection
client.stop();
Serial.println("Client disconnected.");
Serial.println("");
void temptask(){
  unsigned int data[6];
  // Start I2C Transmission
  Wire.beginTransmission(Addr);
  // Send 16-bit command byte
  Wire.write(0x2C);
  Wire.write(0x06);
  // Stop I2C transmission
  Wire.endTransmission();
  delay(300);
  // Stop I2C Transmission
  // Request 6 bytes of data
  Wire.requestFrom(Addr, 6);
 // Read 6 bytes of data
 // temp msb, temp lsb, temp crc, hum msb, hum lsb, hum crc
 if (Wire.available() == 6)
   data[0] = Wire.read();
   data[1] = Wire.read();
   data[2] = Wire.read();
   data[3] = Wire.read();
   data[4] = Wire.read();
   data[5] = Wire.read();
  // Convert the data
  int temp = (data[0] * 256) + data[1];
  float cTemp = -45.0 + (175.0 * temp / 65535.0);
  float fTemp = (cTemp * 1.8) + 32.0;
  float humidity = (100.0 * ((data[3] * 256.0) + data[4])) / 65535.0;
  Ctemp = cTemp;
  Ftemp = fTemp;
  humidity = humid;
  Serial.print("Temperature in C:\t");
  Serial.println(String(cTemp,1));
  Serial.print("Temperature in F:\t");
  Serial.println(String(fTemp,1));
  Serial.print("Humidity:\t ");
  Serial.println(String(humidity,1));
but I am using the break command at end of while loop then it is not uploading HTML page.
     client,
       Serial.println(c);
        client.println();
          String PAGE2 =
 "<!DOCTYPE html>"
 "<html>"
 "<head>"
 "</head>"
 "</p>"
 "</p>"
 "</p>"
 "</body>"
 "</html>";
If anyone knows where is the issue, please do give your advice .
