Ciao a tutti, ho scritto co l'aiuto di alcuni esempi lo skatch seguente e l'ho caricato.
#include <Bridge.h>
#include <YunServer.h>
#include <YunClient.h>
// Listen on default port 5555, the webserver on the Yun
// will forward there all the HTTP requests for us.
YunServer server;
// Bridge startup
pinMode(13,OUTPUT);
digitalWrite(13, LOW);
Bridge.begin();
digitalWrite(13, HIGH);
// Listen for incoming connection only from localhost
// (no one from the external network could connect)
server.listenOnLocalhost();
server.begin();
// Get clients coming from server
YunClient client = server.accept();
// There is a new client?
if (client) {
// Process request
process(client);
// Close connection and free resources.
client.stop();
delay(50); // Poll every 50ms
void process(YunClient client) {
// read the command
String command = client.readStringUntil('/');
// is "digital" command?
if (command == "digital") {
digitalCommand(client);
// is "analog" command?
if (command == "analog") {
analogCommand(client);
// is "mode" command?
if (command == "mode") {
modeCommand(client);
void digitalCommand(YunClient client) {
int pin, value;
// Read pin number
pin = client.parseInt();
// If the next character is a '/' it means we have an URL
// with a value like: "/digital/13/1"
if (client.read() == '/') {
value = client.parseInt();
digitalWrite(pin, value);
else {
value = digitalRead(pin);
// Send feedback to client
client.print(F("Pin D"));
client.print(pin);
client.print(F(" set to "));
client.println(value);
// Update datastore key with the current pin value
String key = "D";
key += pin;
Bridge.put(key, String(value));
void analogCommand(YunClient client) {
int pin, value;
// Read pin number
// with a value like: "/analog/5/120"
// Read value and execute command
analogWrite(pin, value);
client.print(pin);
client.print(F(" set to analog "));
String key = "D";
key += pin;
else {
// Read analog pin
value = analogRead(pin);
client.print(F("Pin A"));
client.print(pin);
client.print(F(" reads analog "));
String key = "A";
key += pin;
void modeCommand(YunClient client) {
int pin;
// Read pin number
// If the next character is not a '/' we have a malformed URL
if (client.read() != '/') {
client.println(F("error"));
return;
String mode = client.readStringUntil('\r');
if (mode == "input") {
pinMode(pin, INPUT);
client.print(pin);
client.print(F(" configured as INPUT!"));
return;
if (mode == "output") {
pinMode(pin, OUTPUT);
client.print(pin);
client.print(F(" configured as OUTPUT!"));
return;
client.print(F("error: invalid mode "));
client.print(mode);
Poi sempre con lo stesso metodo ho cresto il codice HTML sotto descritto e l'ho salvato con nome index.htm nella cartella www.
<html>
<head>
<title>Arduino Yún I/O shield</title>
<script type="text/lavascript">
window.onload=caricastatoPin;
function CaricastatoPin () {
leggistato () ;
function leggiStato () {
setTimeout (leggiStato, 2000);
document.getElementById("descrizione").innerHTML = "---Attendi ... ---";
server = "/arduino/stato/99";
richiesta = new XMLHttpRequest ();
richiesta.onreadystatechange = upateasincronoStato;
richiesta.open("GET",server, true);
richiesta.send(null);
function upateasincronoAnalog() {
if ((richiesta.readystate == 4) && (richiesta.status == 200))
esito = richiesta.responseText;
iparr = esito.split(",");
PinType = iparr[0];
PinNum = iparr[1];
AnalogNum ="Analog" + PinNum;
document.getElementById(AnalogNum).value = PinVal;
document.getElementById("descrizione").innerHTML = esito;
</script>
</head>
<input type="text" name="analogNum" id="analog0" value="0" readonly/>
</html>
Il tutto viene caricato correttamente all'interno della sd, e digitando su url adrduino.local/sd/davide (davide è il nome dello skatch) visualizzo la pagina html caricata ma non aggiorna il dato.
Mi potete dare una mano epr cortesia indicandomi dove ho sbagliato..
Grazie a tutti e buona domenica
