HTPA32x32d I2C sensor not connected
Hi, I am trying to connect the htpa32x32d thermopile array from heimann sensors to my lattepanda arduino. I connected my circuits as shown in the schematic without the capacitors and used 10k instead of 4.7k pullup resistors. Then I used jumper wire to connect the SDA, SCL, Vdd and Gnd to arduino. However when I Wire.read(), I keep getting 255. I did a scan and found out that there are no I2C device connected. Can anyone tell me if my connection or code is wrong? Thank you very much!
More links please ! and show the sketch as text between code-tags.
So the LattePanda is a mini computer running Windows 10 with a onboard ATmega32u4 (as used in the Arduino Leonardo). Is it running at 5V and 16MHz ? Then it has a 5V I2C bus. Are there pullup resistors for the I2C bus, is that mentioned somewhere ? Is there a schematic for the LattePanda where I can see pullup resistors ?
Manufacturer's page of the HTPA32x32d: https://www.heimannsensor.com/32x32.
I can not find any specification for the I2C bus or the registers.
It is a 3.3V sensor, it might get damaged when connecting the SDA and SCL to a 5V I2C bus.
Use a I2C Scanner sketch to find the address.
Can you get a 3.3V Arduino board with SAMD processor. Such as the Arduino Zero or MKR board ?
Your code is okay to read a byte from register 0.
However, if you are not communicating with the sensor, then Wire.endTransmission() returns an error and reading data will return -1, and that converted to a byte will be 255.
Thanks for the quick reply :slight_smile: . I tried it on an arduino uno replica board and ran the I2C scanner sketch and no I2C devices were detected. In the datasheet that I was given, it says: "The chip uses the 7-bit I²C address 0x1A for configuration and sensor data and the 7-bit I²C address 0x50 to access the internal EEPROM. The address byte is followed by a W/R bit and an 8-bit command". I assume the address of the i2c slave is 0x1A?
I am new to I2C and I am not sure if I connected the circuit correctly. My replica arduino's pin config is slightly different than the original arduino uno's.
