HTTP Bad Request from Arduino missing separator ':'
Hi guys,
Im getting an error after posting to a web server.
This is my php code:
<?php
$conex = mysql_connect("localhost", "user", "pwd");
if(!$conex){
    die("Couldn't connect to the server...
".mysql_error());
$db = mysql_select_db("test", $conex);
if(!$db){
    die("Couldn't connect to the database...
".mysql_error());
$Estado_Boton = $_POST["Estado_Boton"];
$sql = "INSERT INTO example (name) VALUES ('$Estado_Boton') ";
$res = mysql_query($sql, $conex);
This is my Request code:
if (wifly.open(site, 80)) {
       Serial.print("Connected to ");
	Serial.println(site);
        /* Send the request */
	//wifly.println("GET /query.php HTTP/1.0");
	wifly.println("POST /arduino/data_process.php HTTP/1.0");
	wifly.println("Host: www.santiapps.com"); // SERVER ADDRESS HERE TOO
        wifly.println("Content-Type: text/html; charset=utf-8");
        wifly.println("Content-Length: ");
        wifly.println(data.length());
        wifly.println("Connnection: close");
	wifly.println();
        wifly.print(data);
       Serial.println("Failed to connect");
This is the server response:
HTTP Bad Request from Arduino missing separator ‘:’
I’ve looked around the web but all i found is some httpd related posts.
Anybody ever get this?
You are printing the data length on a separate line from the Content-Length: Shouldn't they be on the same line?
Pete
You mean it should be:
wifly.println("Content-Length: " + data.length());
Im not at desk right now so I can't try it. I just looked up an example and found that one. I just found a different one that doesn't even use Content-Length. So Ill try both options when I get back.
Im also not sure as to the order of the calls. The Connection: close being before the print(data)
Oh, I also just noticed that Content-Length is only using print, without new line. So that may be why its being printed like that.
