[HTTP-Client] failed to connect to localhost
Hello,
I'm working on a project to connect an node mcu esp8266 to wifi and then execute a post request of a website hosted on localhost. I managed to connect the esp8266 to wifi but the post request always end up failing.
this is the sketch I'm using :
#include <ESP8266HTTPClient.h>
#include <ESP8266WiFi.h>
#include <WiFiClient.h>
 WiFiClient Wificlient;
  Serial.begin(9600);                 //Serial connection
  WiFi.begin("AndroidAP1234", "00224455");   //WiFi connection
  while (WiFi.status() != WL_CONNECTED) {  //Wait for the WiFI connection completion
    Serial.println("Waiting for connection");
  if (WiFi.status() == WL_CONNECTED) { //Check WiFi connection status
    HTTPClient http;    //Declare object of class HTTPClient
 String url = "http://127.0.0.1/Nodemcu_db_record_view/test1.php";
  http.begin(Wificlient,url);      //Specify request destination
    http.addHeader("Content-Type", "application/x-www-form-urlencoded");  //Specify content-type header
   int httpCode = http.POST("valeur=0");   //Send the request
    String payload = http.getString();                  //Get the response payload
    Serial.println(httpCode);   //Print HTTP return code
    Serial.println(payload);    //Print request response payload
    http.end();  //Close connection
    Serial.println("Error in WiFi connection");
  delay(30000);  //Send a request every 30 seconds
and this is the log I'm getting :
[HTTP-Client][begin] url: http://127.0.0.1/Nodemcu_db_record_view/test1.php
[HTTP-Client][begin] host: 127.0.0.1 port: 80 url: /Nodemcu_db_record_view/test1.php
[HTTP-Client][sendRequest] type: 'POST' redirCount: 0
[HTTP-Client] failed connect to 127.0.0.1:80
[HTTP-Client][returnError] error(-1): connection failed
[HTTP-Client][end] tcp is closed
-1
Can you please help me?
Thanks
@soumiail, your topic has been moved to a more suitable location on the forum. Installation and Troubleshooting is not for problems with your project :wink: See About the Installation & Troubleshooting category.
127.0.0.1 is the IP of the localhost. So your code (as it currently stands) needs to run on the same system as where the web server is running.
If the web server is on e.g. your PC and you want to connect to it, you need to use the IP address of the PC.
If the web server is on the NodeMCU and you want to connect from a browser on e.g. the PC or phone, you will need to use the IP address of the NodeMCU in the browser.
