Http error code
The function below sends a string to a database through a php code.
However, when run it, I get an error code but I'm not sure what I'm doing wrong.
httpRequestData: api_key=tPmAT5Ab3j7F9&value1=182.3.217.63
Error code: -1
If in place of the extIP I use a string like "123", it works fine.
Surely is the ip address which is the cause of the problem.
Any help is appreciated.
TIA
void db_send() {
  //Check WiFi connection status
  if (WiFi.status() == WL_CONNECTED) {
    HTTPClient http;
    // Your Domain name with URL path or IP address with path
    http.begin(serverName);
    // Specify content-type header
    http.addHeader("Content-Type", "application/x-www-form-urlencoded");
    // Prepare your HTTP POST request data
    String httpRequestData = "api_key=" + apiKeyValue + "&value1=" + extIP + "&value2=" + 0 + "&value3=" + 0 + "";
    Serial.print("httpRequestData: ");
    Serial.println(httpRequestData);
    // Send HTTP POST request
    int httpResponseCode = http.POST(httpRequestData);
    if (httpResponseCode > 0) {
      Serial.print("HTTP Response code: ");
      Serial.println(httpResponseCode);
    else {
      Serial.print("Error code: ");
    // Free resources
    http.end();
  else {
    Serial.println("WiFi Disconnected");
You may need to encode your URL by replacing special characters (i.e. periods) with certain codes. In your case you would replace the periods with %2E.
URL Encoding Reference
