The following is a "minimal reproducible example" from a larger program that has the same problem: running the function with HTTP GET via 192.168.1.210/showTSgdd kills subsequent attempts to upload OTA (but the GET returns the expected values).
I can upload OTA just fine if I only do the root call (192.168.1.210) and don't do the /showTSgdd.
But after doing the GET, OTA uploads get to 100% and then die with the following:
Uploading: [===================] 100% Done...
19:22:31 [ERROR]: Error receiving result: timed out
Failed uploading: uploading error: exit status 1
XIAO-ESP32S3
default partition
Arduino IDE v2.3.4
ESP32 core v3.1.3
#include <WiFi.h>
#include <WiFiClient.h>
#include <ArduinoOTA.h>
#include <HTTPClient.h>
#include <WebServer.h>
WebServer myServer(80);
char ssid[] = "abc";
char pass[] = "xyz";
char* TSserverGET = "http://api.thingspeak.com/channels/2879857/fields/z/last.txt?api_key=abc";
float lastGDDfromTS;
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, pass);
myServer.on("/", handleRoot);
myServer.on("/showTSgdd", showTSgdd); // get last posted values from ThingSpeak
myServer.begin();
ArduinoOTA.begin();
ArduinoOTA.handle();
myServer.handleClient();
int16_t readFromTS(uint8_t myField) {
//field 4 = GDD42A, 5 = GDD42B, 6 = GDD42C
//TSserverGET[] = "http://api.thingspeak.com/channels/2879857/fields/z/last.txt?api_key=xyz";
// 012345678901234567890123456789012345678901234567890
// 0 1 2 3 4 5
// replace z (in position 50) with 4, 5, or 6 (from myField)
// using brute force and ignorance method:
switch (myField) {
case 4:
TSserverGET[50] = '4';
case 5:
TSserverGET[50] = '5';
case 6:
TSserverGET[50] = '6';
HTTPClient httpForGet;
httpForGet.begin(TSserverGET);
int16_t httpResponseCode = httpForGet.GET();
if (httpResponseCode == 200) {
// success
lastGDDfromTS = httpForGet.getString().toFloat();
// fail
lastGDDfromTS = 0;
httpForGet.end();
return httpResponseCode;
void handleRoot() {
myServer.send(200, "text/plain", "hello world .210 OTA test v3");
void showTSgdd() {
char myCstr[55];
readFromTS(4); // returns response code (int)
float gddA = lastGDDfromTS;
readFromTS(5);
float gddB = lastGDDfromTS;
readFromTS(6);
float gddC = lastGDDfromTS;
snprintf(myCstr, 55, "GDD42A = %.2f GDD42B = %.2f GDD42C = %.2f", gddA, gddB, gddC);
myServer.send(200, "text/plain", myCstr);
The problems doesn't seem to be related to the web server, because this has the same problem:
XIAO-ESP32S3
default partition
Arduino IDE v2.3.4
ESP32 core v3.1.3
#include <WiFi.h>
char pass[] = "123";
// the following code replaces field "z" with the correct field ID (4, 5, or 6)
// the above URL can be used in a browser, too
ArduinoOTA.begin();
static uint8_t i;
if (!i) {
readFromTS(4);
Serial.println(lastGDDfromTS, 2);
i++;
// field 4 = GDD42A, 5 = GDD42B, 6 = GDD42C
// 0 1 2 3 4 5
switch (myField) {
case 4:
case 5:
case 6:
// success
// fail
lastGDDfromTS = 0;
httpForGet.end();
Am I doing something wrong with the HTTP GET (even tho' it returns the expected values)? Any other ideas?
