HTTP GET MySQL syntax
I am using the following SIM800L library:
I am attempting to GET a field in a MySQL database.
I am using the "HTTPS_GET_HardwareSerial" example from the library.
The example has:
const char URL[] = "https://postman-echo.com/get?foo1=bar1&foo2=bar2";
Which I have edited to:
const char URL[] = "197.xxx.xxx.xx:3306/get?SELECT track FROM inv.devices"; // My Server IP
Here I attempt to GET field "track" from table "devices" in MySQL database "inv".
However, this does not work.
My complete code:
 * Example of HTTPS GET with Serial1 (Mega2560) and Arduino-SIM800L-driver      *
 * Author: Olivier Staquet                                                      *
 * Last version available on https://github.com/ostaquet/Arduino-SIM800L-driver *
 * MIT License
 * Copyright (c) 2019 Olivier Staquet
 * Permission is hereby granted, free of charge, to any person obtaining a copy
 * of this software and associated documentation files (the "Software"), to deal
 * in the Software without restriction, including without limitation the rights
 * to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
 * copies of the Software, and to permit persons to whom the Software is
 * furnished to do so, subject to the following conditions:
 * The above copyright notice and this permission notice shall be included in all
 * copies or substantial portions of the Software.
 * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
 * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
 * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
 * AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
 * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
 * OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
 * SOFTWARE.
#include "SIM800L.h"
#define SIM800_RST_PIN 11
const char APN[] = "flick.";
//const char URL[] = "https://postman-echo.com/get?foo1=bar1&foo2=bar2";
SIM800L* sim800l;
  // Initialize Serial Monitor for debugging
  while(!Serial);
  // Initialize the hardware Serial1
  Serial1.begin(9600);
  // Initialize SIM800L driver with an internal buffer of 200 bytes and a reception buffer of 512 bytes, debug disabled
//  sim800l = new SIM800L((Stream *)&Serial1, SIM800_RST_PIN, 200, 512);
  // Equivalent line with the debug enabled on the Serial
   sim800l = new SIM800L((Stream *)&Serial1, SIM800_RST_PIN, 200, 512, (Stream *)&Serial);
  // Setup module for GPRS communication
  setupModule();
  // Establish GPRS connectivity (5 trials)
  bool connected = false;
  for(uint8_t i = 0; i < 5 && !connected; i++) {
    connected = sim800l->connectGPRS();
  // Check if connected, if not reset the module and setup the config again
  if(connected) {
    Serial.print(F("GPRS connected with IP "));
    Serial.println(sim800l->getIP());
    Serial.println(F("GPRS not connected !"));
    Serial.println(F("Reset the module."));
    sim800l->reset();
    setupModule();
    return;
  Serial.println(F("Start HTTP GET..."));
  // Do HTTP GET communication with 10s for the timeout (read)
  uint16_t rc = sim800l->doGet(URL, 10000);
   if(rc == 200) {
    // Success, output the data received on the serial
    Serial.print(F("HTTP GET successful ("));
    Serial.print(sim800l->getDataSizeReceived());
    Serial.println(F(" bytes)"));
    Serial.print(F("Received : "));
    Serial.println(sim800l->getDataReceived());
    // Failed...
    Serial.print(F("HTTP GET error "));
    Serial.println(rc);
  // Close GPRS connectivity (5 trials)
  bool disconnected = sim800l->disconnectGPRS();
  if(disconnected) {
    Serial.println(F("GPRS disconnected !"));
    Serial.println(F("GPRS still connected !"));
  // Go into low power mode
  bool lowPowerMode = sim800l->setPowerMode(MINIMUM);
  if(lowPowerMode) {
    Serial.println(F("Module in low power mode"));
    Serial.println(F("Failed to switch module to low power mode"));
  // End of program... wait...
  while(1);
void setupModule() {
    // Wait until the module is ready to accept AT commands
  while(!sim800l->isReady()) {
    Serial.println(F("Problem to initialize AT command, retry in 1 sec"));
  Serial.println(F("Setup Complete!"));
  // Wait for the GSM signal
  uint8_t signal = sim800l->getSignal();
  while(signal <= 0) {
  Serial.print(F("Signal OK (strenght: "));
  Serial.print(signal);
  Serial.println(F(")"));
  // Wait for operator network registration (national or roaming network)
  NetworkRegistration network = sim800l->getRegistrationStatus();
  while(network != REGISTERED_HOME && network != REGISTERED_ROAMING) {
  Serial.println(F("Network registration OK"));
  // Setup APN for GPRS configuration
  bool success = sim800l->setupGPRS(APN);
  while(!success) {
    delay(5000);
  Serial.println(F("GPRS config OK"));
I suspect that there is some error in my URL GET command syntax.
Have you tested that GET request from the browser on your PC/laptop?
Yes, I get nothing
Not even a "404: not found" ?
I think that means the problem is not related your Arduino code. I think the problem is, as you suspect, the GET request that's being sent to the server. You need to get that working in the browser, first. Then you can go back to your Arduino code.
The URL seems unusual to me, with the SQL query being passed as a GET parameter. Are you sure that's allowed?
When I have done similar things, I have done it by creating a PHP script on the server. The client sends a GET request for the PHP script. The PHP script runs, connects to the database and sends the SQL query. When the results are returned, the PHP script formats them into the body of the response to the client.
Have you seen working examples doing a similar thing in the way you are attempting?
Yes, I have tried the numerous examples using this.
However, when I install XAMPP on my server, my current MySQL stops working.
Great. I suggest you do it that way. I don't think putting SQL query into the GET request works.
How is that related to the problem you are asking about?
I have a problem with the XAMPP on my server - I stops my current MySQL connection.
That is the reason I am exploring alternatives to sending a GET request with PHP script.
Perhaps it's using the same port?
Anyways, while you might get some help with that on this forum, there may be other other forums that would be better.
Once you have fixed the problems with your server, if you are still having problems with the Arduino, you can pick up on this topic again. Good luck!
