I (hope) I'm just being a complete idiot, but I can't find a single way of actually getting HTTP requests to work with the iot cloud. Correct me if I'm wrong, but its somewhat the first thing I'd expect an iot device to do, and with arduino I was hoping for it to just work.
After a few weeks of trying random stuff on and off, I've made enough progress that it can just fail to connect now
(I got past all the millions of compile fails with the crappy non functional libraries)
I'm currently running out of a new unmodified (apart from the main file) arduino IOT cloud "thing". I need to still be in the iot cloud, because I've got other things running through it.
here is my code so far, please help asap
#include "thingProperties.h"
uint8_t httpGet(char result[], int len, char* server, char* path, uint16_t read_timeout) {
// Prepare the client
WiFiSSLClient client;
// Connect to the server
Serial.print(F("Attempt to connect "));
Serial.print(server);
Serial.println(F(":443 ..."));
if(client.connect(server, 443)) {
// Connection established
Serial.println(F("Connection to server established"));
client.print("GET ");
client.print(path);
client.println(" HTTP/1.1");
client.print("Host: ");
client.println(server);
client.println("User-Agent: ArduinoWiFiNINA/1.4.0");
client.println("Connection: close");
client.println();
Serial.println(F("Unable to connect to the server"));
return 2;
// Listen and manage a timeout
unsigned long startTime = millis();
bool received = false;
int index = 0;
while ((millis() - startTime < read_timeout) && !received) {
while(client.available() && index < len - 1) {
received = true;
char c = client.read();
Serial.write(c);
result[index] = c;
if(!received) {
Serial.println(F("Read timeout"));
return 1;
// Return OK
return 0;
delay(1500);
// Defined in thingProperties.h
initProperties();
// Connect to Arduino IoT Cloud
ArduinoCloud.begin(ArduinoIoTPreferredConnection);
setDebugMessageLevel(4);
ArduinoCloud.printDebugInfo();
ArduinoCloud.update();
char url[256]; // Adjust size as needed
strcpy(url, "/v1/forecast?latitude=50.0000&longitude=-0.0000&hourly=temperature_2m,relative_humidity_2m,precipitation,weather_code,wind_speed_10m&forecast_days=1");
char response[512];
httpGet(response, 512, "api.open-meteo.com", url, 1000);
Serial.print("Response: ");
Serial.println(strlen(response));
Serial.println(response);
this is the vague "stuff doesn't work" output mess of combinations of all the connections failing that it outputs currently
Attempt to connect api.open-meteo.com:443 ...
Response: 1
ArduinoIoTCloudTCP::handle_ConnectMqttBroker could not connect to iot.arduino.cc:8883
ArduinoIoTCloudTCP::handle_ConnectMqttBroker 3 connection attempt at tick time 387694
Response: 1
WiFi.status(): 6
