HTTP GET response time slow
Hi all,
I have an application where there are multiple edge devices (32 devices) connected to the master device and communicating over RS485 Protocol. Application flow -
The master devices has the Internet facility over Ethernet with W5500 Module and communicating with edge devices and get the data based the GET request it receives from Server. The edge device has an ultrasonic sensor with each one of them, reading the sensor data and sending it to the master based on the request received. I have attached the codes for both slave and master device.
The problem I am facing is the response time to get the data. It is a local server, there is no traffic on that network, the network connection is pretty stable but to receive the data, it takes variable amount of time - sometimes 80ms, sometimes 300ms and going up to 1 sec also.
Our application requirement is to get the data in less than 100 ms everytime.
Can you please let me know what I am doing wrong in the code or it is not possible to get the response in less than 100 ms ?
Minimal code for Slave Device - ATMEGA328PB
#include "Ultrasonic.h"
#include <EEPROM.h>
#include <SoftwareSerial.h>
#include <avr/wdt.h>
#include <avr/pgmspace.h>
#define DEVICE_ID_LOCATION_1               1
#define DEVICE_ID_LOCATION_2               2
#define DEVICE_ID_LOCATION_3               3
#define DEVICE_HEIGHT_LOCATION             5
#define DEVICE_VACATE_LED_COLOR_LOCATION   6
#define DEVICE_OCCUPIED_LED_COLOR_LOCATION 7
   Default Values for below parameters
const uint16_t health_check_led_blink_interval = 2000;
   Reading 50 samples of sensor data periodically at 200ms and averaging it every 10 sec to get the accurate result
const uint16_t sensor_status_read_interval = 2000;
const uint8_t sensor_sample_count = 5;
const uint8_t sensor_read_height_hysteresis = 7; //+/- 7cm considerable for object detection
   Timer interrupt variable to hold the elapsed time value
unsigned long previous_health_check_led_millis = 0;
unsigned long previous_occupancy_sensor_millis = 0;
long prev_sensor_status_read_in_cm = 0;
long current_sensor_status_read_in_cm = 0;
uint8_t occupancy_detected_status = 0;
uint8_t sensor_send_distance_measured = 0;
byte current_led_color = 0;
uint8_t Current_sensor_sample = 0;
byte data_received_from_zonal[15];
int rcv_data_index = 0;
byte crc1, crc2;
bool data_rcv_flag = false;
enum sensor_req_cmd_frame {
  GET_DEVICE_STATUS = 0,
  GET_DEVICE_CONFIG,
  SET_DEVICE_CONFIG,
Ultrasonic ultrasonic(occupancy_sensor_Pin);
// Set up a new SoftwareSerial object
SoftwareSerial mySerial(8, 9);
void sensor_send_data_over_modbus(uint8_t req_data_type, uint8_t data[] = {0}, uint8_t size_of_data = 0);
void update_health_check_led_state() {
  unsigned long current_led_check_time = millis();
  if (health_check_led_state == LOW) {
    //If the led is OFF, we must wait for the interval to expire before turning it ON
    if (current_led_check_time - previous_health_check_led_millis >= health_check_led_blink_interval) {
      //time is up so change the state to HIGH
      health_check_led_state = HIGH;
      digitalWrite(health_check_led_Pin, health_check_led_state);
      //and save the time when we made the changes
      previous_health_check_led_millis = current_led_check_time;
  else { //i.e. if health_check_led_state is HIGH
    //if led is ON, we must wait for the interval to expire before turning it OFF
      //time is up so change the state to LOW
      health_check_led_state = LOW;
void occupancy_sensor_Status_read() {
  unsigned long current_sensor_read_time = millis();
  uint8_t vacate_led_color = EEPROM.read(DEVICE_VACATE_LED_COLOR_LOCATION);
  uint8_t occupied_led_color = EEPROM.read(DEVICE_OCCUPIED_LED_COLOR_LOCATION);
  uint16_t sensor_height_read = EEPROM.read(DEVICE_HEIGHT_LOCATION);
  sensor_height_read = sensor_height_read * 10; //to get the height in cm
  uint16_t min_sensor_height_read = sensor_height_read - sensor_read_height_hysteresis;
  uint16_t max_sensor_height_read = sensor_height_read + sensor_read_height_hysteresis;
     This only reads sensor state after the sensor interval has elapsed
     this also avoids multiple flashes if the sensor bounces
  if (current_sensor_read_time - previous_occupancy_sensor_millis > sensor_status_read_interval) {
    previous_occupancy_sensor_millis = current_sensor_read_time;
    if(data_rcv_flag == false){
      current_sensor_status_read_in_cm = ultrasonic.MeasureInCentimeters(500000);
    if (Current_sensor_sample < sensor_sample_count) {
      prev_sensor_status_read_in_cm += current_sensor_status_read_in_cm;
      Current_sensor_sample++;
    else if (Current_sensor_sample == sensor_sample_count) {
      prev_sensor_status_read_in_cm = prev_sensor_status_read_in_cm / sensor_sample_count;
      mySerial.print("Total Distance read in cm: ");
      mySerial.println(prev_sensor_status_read_in_cm);
      sensor_send_distance_measured = prev_sensor_status_read_in_cm / 10;
      //if object detected
      if ( prev_sensor_status_read_in_cm <= min_sensor_height_read) {
        occupancy_detected_status = sensor_slot_occupied_data_frame;
        current_led_color = occupied_led_color;
        if ( occupied_led_color == sensor_green_led_color_data_frame ) {
          digitalWrite( led_indicator_red_Pin, LOW );
          digitalWrite( led_indicator_green_Pin, HIGH );
        else if ( occupied_led_color == sensor_red_led_color_data_frame ) {
          digitalWrite( led_indicator_green_Pin, LOW );
          digitalWrite( led_indicator_red_Pin, HIGH );
      //if object isn't detected
      else if (prev_sensor_status_read_in_cm >= max_sensor_height_read) {
        occupancy_detected_status = sensor_slot_empty_data_frame;
        current_led_color = vacate_led_color;
        if ( vacate_led_color == sensor_green_led_color_data_frame ) {
        else if ( vacate_led_color == sensor_red_led_color_data_frame ) {
void zonal_recv_data_over_modbus() {
  rcv_data_index = 0;
  while (Serial.available()) {
    byte byteArray[sizeof(byte)];
    Serial.readBytes(byteArray, sizeof(byteArray));
    mySerial.println(byteArray[0], HEX);
    if (byteArray[0] == zonal_start_frame) {
      data_rcv_flag = true;
      rcv_data_index = 0;
    data_received_from_zonal[rcv_data_index] = byteArray[0];
    rcv_data_index = rcv_data_index + 1;
    if (byteArray[0] == zonal_stop_frame) {
  if (rcv_data_index >= zonal_get_req_frame_size && rcv_data_index <= zonal_set_req_frame_size && data_rcv_flag == true ) {
      uint8_t device_id[] = {device_id_1, device_id_2, device_id_3};
    if ( data_received_from_zonal[0] == zonal_start_frame and data_received_from_zonal[rcv_data_index - 1] == zonal_stop_frame ) {
      if (data_received_from_zonal[1] == device_id_1 && data_received_from_zonal[2] == device_id_2 && data_received_from_zonal[3] == device_id_3 ) {
        if (rcv_data_index == zonal_get_req_frame_size) {
          if ( data_received_from_zonal[4] == zonal_get_status_cmd_frame && data_received_from_zonal[5] == zonal_default_get_request_data ) {
            uint8_t data[] = {zonal_default_get_request_data};
            zonal_sensor_crc_calculation(&crc1, &crc2, device_id, zonal_get_status_cmd_frame, data, sizeof(data));
            if (crc1 == data_received_from_zonal[6] && crc2 == data_received_from_zonal[7]) {
              sensor_send_data_over_modbus(GET_DEVICE_STATUS);
          else if (data_received_from_zonal[4] == zonal_get_config_cmd_frame && data_received_from_zonal[5] == zonal_default_get_request_data ) {
            zonal_sensor_crc_calculation(&crc1, &crc2, device_id, zonal_get_config_cmd_frame, data, sizeof(data));
              sensor_send_data_over_modbus(GET_DEVICE_CONFIG);
        else if (rcv_data_index == zonal_set_req_frame_size && data_received_from_zonal[4] == zonal_set_config_cmd_frame) {
          byte height_threshold_value = data_received_from_zonal[5];
          byte vacate_led_color = data_received_from_zonal[6];
          byte occupied_led_color = data_received_from_zonal[7];
          uint8_t data[] = {height_threshold_value, vacate_led_color, occupied_led_color};
          zonal_sensor_crc_calculation(&crc1, &crc2, device_id, zonal_set_config_cmd_frame, data, sizeof(data));
          if (crc1 == data_received_from_zonal[8] && crc2 == data_received_from_zonal[9]) {
            //mySerial.println(sensor_min_height_threshold);
            //mySerial.println(height_threshold_value);
            if (height_threshold_value >= sensor_min_height_threshold && height_threshold_value <= sensor_max_height_threshold) {
              EEPROM.update(DEVICE_HEIGHT_LOCATION, height_threshold_value);
            else {
              data[0] = sensor_fail_write_data_response;
            if (vacate_led_color == sensor_green_led_color_data_frame || vacate_led_color == sensor_red_led_color_data_frame ) {
              EEPROM.update(DEVICE_VACATE_LED_COLOR_LOCATION, vacate_led_color);
            else {
              data[1] = sensor_fail_write_data_response;
            if (occupied_led_color == sensor_green_led_color_data_frame || occupied_led_color == sensor_red_led_color_data_frame) {
              EEPROM.update(DEVICE_OCCUPIED_LED_COLOR_LOCATION, occupied_led_color);
            else {
              data[2] = sensor_fail_write_data_response;
            uint8_t size_of_data = sizeof(data);
            sensor_send_data_over_modbus(SET_DEVICE_CONFIG, data, size_of_data);
void sensor_send_data_over_modbus(uint8_t req_data_type, uint8_t data[], uint8_t size_of_data) {
  uint8_t device_id[] = {device_id_1, device_id_2, device_id_3} ;
  delay(10);
  digitalWrite(modbus_enable_Pin, HIGH);
  if (req_data_type == GET_DEVICE_STATUS) {
    char distance_measured_hex[5];
    sprintf(distance_measured_hex, "%2X", sensor_send_distance_measured);
    uint8_t data_to_be_send[] = {occupancy_detected_status, sensor_send_distance_measured, current_led_color};
    zonal_sensor_crc_calculation(&crc1, &crc2, device_id, zonal_get_status_cmd_frame, data_to_be_send, sizeof(data_to_be_send));
    byte sendData[] = {sensor_start_frame, device_id_1, device_id_2, device_id_3, zonal_get_status_cmd_frame, data_to_be_send[0], data_to_be_send[1], data_to_be_send[2], crc1, crc2, sensor_stop_frame};
    for (int i = 0; i < sizeof(sendData); i++) {
      Serial.write(sendData[i]);
  else if (req_data_type == GET_DEVICE_CONFIG) {
    byte height_threshold = EEPROM.read(DEVICE_HEIGHT_LOCATION);
    byte vacate_led_color = EEPROM.read(DEVICE_VACATE_LED_COLOR_LOCATION);
    byte occupied_led_color = EEPROM.read(DEVICE_OCCUPIED_LED_COLOR_LOCATION);
    uint8_t data_to_be_send[] = {height_threshold, vacate_led_color, occupied_led_color};
    zonal_sensor_crc_calculation(&crc1, &crc2, device_id, zonal_get_config_cmd_frame, data_to_be_send, sizeof(data_to_be_send));
    byte sendData[] = {sensor_start_frame, device_id_1, device_id_2, device_id_3, zonal_get_config_cmd_frame, data_to_be_send[0], data_to_be_send[1], data_to_be_send[2], crc1, crc2, sensor_stop_frame};
  else if (req_data_type == SET_DEVICE_CONFIG and size_of_data == 3) {
    zonal_sensor_crc_calculation(&crc1, &crc2, device_id, zonal_set_config_cmd_frame, data, size_of_data);
    byte sendData[] = {sensor_start_frame, device_id_1, device_id_2, device_id_3, zonal_set_config_cmd_frame, data[0], data[1], data[2], crc1, crc2, sensor_stop_frame};
  Serial.flush();
  digitalWrite(modbus_enable_Pin, LOW);
  mySerial.begin(9600);
  Serial.flush();
  pinMode(occupancy_sensor_Pin, INPUT);
  pinMode(led_indicator_red_Pin, OUTPUT);
  pinMode(led_indicator_green_Pin, OUTPUT);
  pinMode(health_check_led_Pin, OUTPUT);
  pinMode(modbus_enable_Pin, OUTPUT);
  delay(10);
  delayMicroseconds(50);
  //Read the sensor address from the eeprom location
  device_id_1 = EEPROM.read(DEVICE_ID_LOCATION_1);
  device_id_2 = EEPROM.read(DEVICE_ID_LOCATION_2);
  device_id_3 = EEPROM.read(DEVICE_ID_LOCATION_3);
  mySerial.print("Device ID is: ");
  mySerial.println(String(device_id_1, HEX) + String(device_id_2, HEX) + String(device_id_3, HEX));
  update_health_check_led_state();
  occupancy_sensor_Status_read();
  zonal_recv_data_over_modbus();
Master Code - Minimal (ATMEGA2560)
#include <SPI.h>
#include <Ethernet.h>
#include <ArduinoJson.h>
#include <avr/io.h>
#include <util/delay.h>
#define RS485Transmit HIGH
#define RS485Receive  LOW
const int modbus_enable_pin = 2;
const int ethernet_cs_pin = 53;
byte mac[] = {
  0x00, 0xAA, 0xBB, 0xCC, 0xDE, 0x02
const int MAX_HEX_VALUES = 15; // Adjust this based on the maximum number of hex values you expect to receive
byte json_get_status_data[MAX_HEX_VALUES];
byte data_received_from_sensor[30];
uint8_t rcv_data_index = 0;
bool data_send_rcv_flag = false;
EthernetServer server(4812);
IPAddress zonal_ip;
IPAddress local_server_IP(192, 168, 4, x);
int local_server_port = 80;
unsigned long previousMillis = 0;
const long interval = 300000; // Interval in milliseconds (e.g., 5000ms = 5 seconds)
  Serial1.begin(9600);
  pinMode(modbus_enable_pin, OUTPUT);
  Ethernet.init(ethernet_cs_pin);
  Serial.println("Zonal started");
  // start the Ethernet connection and the server:
  if (Ethernet.begin(mac) == 0) {
    Serial.println("Failed to configure Ethernet using DHCP");
    if (Ethernet.hardwareStatus() == EthernetNoHardware) {
      Serial.println("Ethernet shield was not found.  Sorry, can't run without hardware. :(");
    } else if (Ethernet.linkStatus() == LinkOFF) {
      Serial.println("Ethernet cable is not connected.");
    while (true) {
      delay(1);
  // start the server
  server.begin();
  zonal_ip = Ethernet.localIP();
  Serial.println(zonal_ip);
  // listen for incoming clients
  zonal_rcv_data_from_server(client);
  // Check if it's time to send health check data
  if (currentMillis - previousMillis >= interval) {
    // Send health check data to the client
    Serial.println("Health check send");
    sendHealthCheckData();
void zonal_rcv_data_from_server(EthernetClient client) {
  if (client) {
    client.setTimeout(10);
    String request = client.readStringUntil('\r');
    client.flush();
    if (request.indexOf("/get-zonal-mac-ip") != -1) {
       sendZonalMacIpJsonResponse(client);
    } else if (request.indexOf("/get-zonal-data-status") != -1) {
      zonal_send_data_to_sensor(client);
    } else if (request.indexOf("/get-zonal-data-config") != -1) {
    } else if (request.indexOf("/set-zonal-data-config") != -1) {
      // Send a default response for other URLs
      sendDefaultJsonResponse(client);
    // Close the connection
    delay(1);
    client.stop();
void zonal_send_data_to_sensor(EthernetClient client) {
  // Read the JSON data from the request
  String jsonData = "";
  rcv_data_index = 0;
  while (client.available()) {
    jsonData = client.readStringUntil('\n');
    if (jsonData == "\r") {
  jsonData = client.readString(); //PAYLOAD
  //const size_t bufferSize = JSON_OBJECT_SIZE(1) + JSON_ARRAY_SIZE(32) + 32 * JSON_ARRAY_SIZE(9);
  // Parse the JSON data
  StaticJsonDocument<200> jsonDoc;
  DeserializationError error = deserializeJson(jsonDoc, jsonData);
  if (error) {
    Serial.println("Error processing json");
    Serial.println(error.f_str());
    return;
  const char* value = jsonDoc["data"];
  Serial.println(value);
  // Print the key and value
  int hexCount = 9; //byte_calculate(value);
  // Allocate memory for the byte array
  byte sendByte[hexCount];
  // Convert the string to a byte array
  char* token;
  char* rest = (char*)value;
  int index = 0;
  while ((token = strtok_r(rest, ", ", &rest))) {
    sendByte[index++] = strtol(token, NULL, 0);
  Serial.println('2');
  digitalWrite(modbus_enable_pin, RS485Transmit);
  Serial1.write(sendByte, hexCount);
  Serial1.flush();
  delay(5);
  digitalWrite(modbus_enable_pin, RS485Receive);
  delay(10);
  bool flag = false;
  Serial.println('3');
  while (Serial1.available() > 0) {
    byte receivedByte = Serial1.read();
    Serial.println(receivedByte, HEX);
    if (receivedByte == 0xEE) {
      flag = false;
      rcv_data_index = 0;
    if (flag == false) {
      data_received_from_sensor[rcv_data_index] = receivedByte;
    if (receivedByte == 0xAA) {
      flag = true;
  if (data_rcv_flag ==  true and rcv_data_index == 11) {
    StaticJsonDocument<200> recvJson;
    String byteArrayString = byteArrayToString(data_received_from_sensor, rcv_data_index);
    recvJson["status"] = "1";
    recvJson["sensor_data"] = byteArrayString;
    String jsonString;
    serializeJson(recvJson, jsonString);
    client.println("Content-Type: application/json");
    client.println();
    client.println(jsonString);
  else {
    jsonDoc["status"] = "1";
    jsonDoc["sensor_data"] = "";
    String jsonString;
    serializeJson(jsonDoc, jsonString);
    client.println();
int byte_calculate(char* value) {
  // Count the number of bytes based on the number of comma separators + 1
  int numBytes = 1;
  for (int i = 0; value[i] != '\0'; i++) {
    if (value[i] == ',') {
      numBytes++;
  return numBytes;
String byteArrayToString(byte* byteArray, int size) {
  String result = "";
  for (int i = 0; i < size; i++) {
    // Convert each byte to a two-digit hexadecimal representation
    if (byteArray[i] < 0x10) {
      result += "0"; // Add leading zero for single-digit values
    result += String(byteArray[i], HEX);
    result += ","; // Add a space separator
  result.toUpperCase();
  return result;
void sendZonalMacIpJsonResponse(EthernetClient client) {
  char macStr[18];
  snprintf(macStr, sizeof(macStr), "%02X:%02X:%02X:%02X:%02X:%02X",
           mac[0], mac[1], mac[2], mac[3], mac[4], mac[5]);
  // Create a JSON object for zonal MAC and IP
  jsonDoc["mac"] = macStr;
  jsonDoc["zonal_ip"] = zonal_ip;
  // Serialize the JSON object to a string
  String jsonString;
  // Send HTTP headers
  //client.println("Connection: close");
  client.println();
  // Send the JSON response
void sendDefaultJsonResponse(EthernetClient client) {
  // Create a JSON object for default response
  jsonDoc["message"] = "Invalid URL";
  jsonDoc["error"] = "The requested URL is not supported";
  String jsonString;
  client.println("HTTP/1.1 404 Not Found");
  client.println();
void sendHealthCheckData() {
  EthernetClient client;
  char macStr[18];
  jsonDoc["mac_address"] = macStr;
  jsonDoc["ip_address"] = zonal_ip;
  String jsonString;
  if (client.connect(local_server_IP, local_server_port)) {
    Serial.println("connected");
    client.println("POST http://192.168.4.x:80/api/v1/pgs/mac_ip HTTP/1.1");
    client.println("Host: 192.168.4.x");
    client.println("User-Agent: Arduino/1.0");
    client.print("Content-Length: ");
    client.println(jsonString.length());
    client.println();
    Serial.println("connection failed");
  client.stop();
Any help will be appreciated. Also, sometimes, getting the blank data also if fetching in less time.
Could it help to use a higher speed for the serial communication? 9600 is a rather low speed.
Hi @Railroader , thanks for looking into the problem statement and providing the solution. However, when I am increasing the baudrate to 115200, I have to increase the switching time for MAX485 enable pin to receive the data otherwise most of the times, master is not able to receive the data.
And for HTTP response time, it is not making much difference as getting the response in variable amount of time - sometimes 80ms, and sometimes 400ms.
Any higher baudrate ought to improve the resonse time. 115200 might be too high but something in between could help.
As I don't know the protocol used I'm guessing. A request might consist of some ping pong before the actual data can be sent, all affected by the baudrate....
