Working on a Uno with a shield and writing back to a Asp.net API and I'm running into a weird issue that I can't figure out. Either of the request below will run when I call it the first time but any subsequent runs of the same method or different will fail with http 400 invalid url. I can spam both API calls through postman without issue so it's something to do with how I'm handling the client and for the life of me I can't figure it out. I changed the connection test portion on the Limits call just to verify I was actually disconnecting and based on serial output everything looks good.
Loaded libraries are
#include <Adafruit_ADS1X15.h>
#include <SPI.h>
#include <Ethernet.h>
#include <AsyncDelay.h>
#include <ArduinoJson.h> //Not yet in use
void GetArduinoLimits() {
String PostData = "ArduinoID=" + String(ArduinoID);
// Serial.println("Inside Limit Check");
if(!client.connected()){
Serial.println("Not Connected");
client.connect(server, 80);
if(client.connected()){
Serial.println("Connected");
client.println("GET /NIC-API-Dev/api/EWI/ArduinoLimit?ArduinoID=" + String(ArduinoID) + " HTTP/1.1");
client.println("Host: XX.XX.XX.XX");
client.println("Connection: close");
client.println("Content-Length: 0");
client.println("Content-Type: application/x-www-form-urlencoded");
client.println();
while (client.connected() && !client.available()) delay(1);
while (client.connected() || client.available()) {
char c = client.read(); //gets byte from ethernet buffer
readString += c;
Serial.print(c);
if (!client.connected()) {
client.stop();
void GetArduinoIsSetup() {
String PostData = "ArduinoID=" + String(ArduinoID) + "?isSetupRun=1";
if (client.connect(server, 80)) {
Serial.println("isSetup Connected");
client.println("GET /NIC-API-Dev/api/EWI/ArduinoIsSetup?ArduinoID=" + String(ArduinoID) + "&isSetupRun=1" + " HTTP/1.1");
client.println();
readString += c;
Serial.print(c);
client.stop();
Serial.println("---------End of Response Header---------");
Serial.println(readString.substring(readString.indexOf('{')));
readString = "";
// readString = readString.substring(readString.indexOf('{'));
// deserializeJson(jdoc,readString);
// const char* tst = jdoc["result"];
// Serial.println(tst);
