HTTP GET using Ethernet shield getting interrupted
Hello all,
I'm using Arduino UNO with Ethernet Shield to send data to a data base with the aid of a php script.
The database is a paid subscription so it doesn't have the problems that often come from free hosting.
Arduino collects data from multiple sensors and sends them to the cloud every 1 minute (later i will make it 5 but for now i need it to be 1)
So the problem is that i am able to upload data for once or twice and then it will fail for a couple of times and then it will upload again, so i really cannot understand that behavior and what is causing it.....
I can't afford to lose any data from the project i'm building, and it seems the code isn't able to keep on uploading
Also, please note that i tried to execute the HTTP GET for big amount of time using just a browser to figure out if the issue is from the server, but when using the browser i get all of them which means the server is ok
Here is an example of what the serial monitor shows:
8:22:51.886 -> connecting to realtimepv.alcoholdatabase.net...
18:22:51.974 -> Connected to server
18:22:51.974 -> GET /PVInsert.php?voltage=20.57&current=0.21&lux=10.71&AmbTemp=28.00&SurTemp=10&Power=10 HTTP/1.1
18:22:52.069 -> HTTP/1.1 400 Bad Request
18:22:52.119 -> Con
18:22:52.119 -> disconnected
18:22:58.073 -> connecting to realtimepv.alcoholdatabase.net...
18:22:58.317 -> Connected to server
18:22:58.364 -> GET /PVInsert.php?voltage=20.57&current=0.21&lux=10.71&AmbTemp=28.00&SurTemp=10&Power=10 HTTP/1.1
18:22:58.552 -> HTTP/1.1 200 OK
18:22:58.599 -> Connection: close
18:22:58.599 -> x-powered-by: PHP/7.4.30
18:22:58.646 -> content-type: text/html; charset=UTF-8
18:22:58.693 -> content-length: 33
18:22:58.693 -> date: Fri, 08 Jul 2022 10:22:59 GMT
18:22:58.740 -> server: LiteSpeed
18:22:58.740 ->
18:22:58.740 ->
18:22:58.740 -> New record created successfully
18:22:58.895 -> disconnected
18:23:04.915 -> connecting to realtimepv.alcoholdatabase.net...
18:23:04.962 -> connection failed
18:23:05.008 -> connecting to realtimepv.alcoholdatabase.net...
18:23:05.054 -> connection failed
18:23:05.102 -> connecting to realtimepv.alcoholdatabase.net...
18:23:05.149 -> connection failed
18:23:05.193 -> connecting to realtimepv.alcoholdatabase.net...
18:23:05.427 -> Connected to server
18:23:05.427 -> GET /PVInsert.php?voltage=20.57&current=0.25&lux=10.71&AmbTemp=28.00&SurTemp=10&Power=10 HTTP/1.1
18:23:05.663 -> HTTP/1.1 400 Bad Request
18:23:05.663 -> Connection: close
18:23:05.709 -> cache-control: private, no-cache, no-store, must-revalidate, max-age=0
18:23:05.755 -> pragma: no-cache
18:23:05.802 -> content-type: text/html
18:23:05.802 -> content-length: 681
18:23:05.849 -> date: Fri, 08 Jul 2022 10:23:06 GMT
18:23:05.897 -> server: LiteSpeed
18:23:05.897 ->
18:23:05.897 -> disconnected
18:23:11.890 -> connecting to realtimepv.alcoholdatabase.net...
18:23:12.123 -> Connected to server
18:23:12.123 -> GET /PVInsert.php?voltage=20.57&current=0.21&lux=10.71&AmbTemp=28.00&SurTemp=10&Power=10 HTTP/1.1
18:23:12.355 -> HTTP/1.1 200 OK
18:23:12.355 -> Connection: close
18:23:12.401 -> x-powered-by: PHP/7.4.30
18:23:12.401 -> content-type: text/html; charset=UTF-8
18:23:12.448 -> content-length: 33
18:23:12.495 -> date: Fri, 08 Jul 2022 10:23>12 GMT
18:23:12.542 -> server: LiteSpeed
18:23:12.542 ->
18:23:12.542 ->
18:23:12.542 -> New record created successfully
18:23:12.683 -> disconnected
I need some ideas and thoughts on how to solve this issue
Here is my code
#include <Ethernet.h>
EthernetClient client;
#include <DFRobot_B_LUX_V30B.h>
DFRobot_B_LUX_V30B    myLux(13);//The sensor chip is set to 13 pins, SCL and SDA adopt default configuration
#include <dht.h>
#define dataPin 3 // Defines pin number to which the sensor is connected
dht DHT; // Creats a DHT object
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
int STATE = 0 ;
int sending = 1;
int tryingagain = 2;
int delaying = 3;
// Set the static IP address to use if the DHCP fails to assign
IPAddress ip(192, 168, 0, 177);
IPAddress myDns(192, 168, 0, 1);
int HTTP_PORT = 80;
String HTTP_METHOD = "GET";
char HOST_NAME[] = "realtimepv.alcoholdatabase.net";
String PATH_NAME = "/PVInsert.php?";
int SurTemp = 10;
int Power = 10;
  ethernetsetup();
  STATE = sending;
  myLux.begin();
  Ethernet.maintain();
  float lux = myLux.lightStrengthLux();
  // read the input on analog pin 0 & 1:
  int sensorVol = analogRead(A0);
  int sensorAmp = analogRead(A1);
  // Convert the analog reading (which goes from 0 - 1023) to a voltage (0 - 5V):
  float voltage = 13.07 * sensorVol * (5.0 / 1023.0);
  float current = 8.4 * sensorAmp * (5.0 / 1023.0);
  /* // print out the value you read:
    Serial.print("Voltage: ");
    Serial.print(voltage, 2); //print the voltge
    Serial.print("V\t\t");
    Serial.print("Current: ");
    Serial.print(current, 3); //print the voltge
    Serial.println("A");
    //Serial.print("Analog Reading: ");
    //Serial.println(sensorValue);//print the voltge
    delay(500);*/
  int readData = DHT.read22(dataPin); // Reads the data from the sensor
  float AmbTemp = DHT.temperature; // Gets the values of the temperature
  if (STATE == sending) {
    String queryString = String("voltage=" + String(voltage) + String("&current=") + String(current) + String("&lux=") + String(lux) + String("&AmbTemp=") + String(AmbTemp) + String("&SurTemp=") + String(SurTemp) + String("&Power=") + String(Power));
    //////////////////////////ethernet code///////////////////////////////
    Serial.print("connecting to ");
    Serial.print(HOST_NAME);
    Serial.println("...");
    // connect to web server on port 80:
    if (client.connect(HOST_NAME, HTTP_PORT)) {
      // if connected:
      Serial.println("Connected to server");
      // make a HTTP request:
      // send HTTP header
      client.println(HTTP_METHOD + " " + PATH_NAME + queryString + " HTTP/1.1");
      Serial.println(HTTP_METHOD + " " + PATH_NAME + queryString + " HTTP/1.1");
      client.println("Host: " + String(HOST_NAME));
      client.println("Connection: close");
      client.println(); // end HTTP header
      while (client.connected()) {
        if (client.available()) {
          // read an incoming byte from the server and print it to serial monitor:
          char c = client.read();
          Serial.print(c);
      // the server's disconnected, stop the client:
      client.stop();
      Serial.println("disconnected");
      client.flush();
      STATE = delaying;
    else {// if not connected:
      client.flush();
      Serial.println("connection failed");
      STATE = tryingagain;
  else if (STATE == delaying) { //reporting once every minute
    delay (60000);
    STATE = sending;
  else if (STATE == tryingagain) {// when i get a fail, though it is not fixing my issue, it is still returning bad request
    delay(1);
    STATE = sending;
void ethernetsetup() {
  // initialize the Ethernet shield using DHCP:
  // start the Ethernet connection:
  Serial.println("Initialize Ethernet with DHCP:");
  Serial.println("HI");
  if (Ethernet.begin(mac) == 0) {
    Serial.println("Failed to configure Ethernet using DHCP");
    // Check for Ethernet hardware present
    if (Ethernet.hardwareStatus() == EthernetNoHardware) {
      Serial.println("Ethernet shield was not found.  Sorry, can't run without hardware. :(");
      while (true) {
        delay(1); // do nothing, no point running without Ethernet hardware
    if (Ethernet.linkStatus() == LinkOFF) {
      Serial.println("Ethernet cable is not connected.");
    // try to configure using IP address instead of DHCP:
    Ethernet.begin(mac, ip, myDns);
  else {
    Serial.print("  DHCP assigned IP ");
    Serial.println(Ethernet.localIP());
What does the server logs say? For me this looks like a very bad connection to that server or a server very picky about how small or big network packets must be.
Just because it's paid doesn't ensure good quality, unfortunately.
this is the response I get
i got it from HOSTINGER
This is what you get on the client. Don't you have access to the server logs?
It looks like your server answers with a 400 result code before it got the complete request. Without server logs you probably won't be able to find the reason for this.
