HTTP GET with Arduino serial and SIM900 module.
Thanks for taking the time to read my post and help me out hopefully : )
I'm trying to send data from my Arduino with a SIM900 module to a http address .php file which will put the data from the http address into a database.
I think my problem is how i'm sending and receiving the serial communication, when i send/receive a long line it gets cut short in the serial monitor. I'm not sure if i'm sending the command short or receiving a short echo in the serial monitor.
To clarify its the response from HTTPPARA='URL' and HTTPREAD that are not displaying correctly.
Here is the function i'm using to read/write to the SIM:
void printSerialData() {  //send/read the SIM Module
  while(myGsm.available()) {
  if (myGsm.available()) {
     delay(100);
    String c = myGsm.readString();
       Serial.println(c);
  while (Serial.available()) {
      myGsm.write(Serial.read());
      delay(100);
And the code im using to send the commands. It runs once when the board is first turned on.
void httpConnect() {
    myGsm.println("AT+SAPBR=3,1,\"CONTYPE\",\"GPRS\""); // Set Connection to GPRS context
    Serial.println(" setting connection type");
    printSerialData();
    myGsm.println("AT+SAPBR=3,1,\"APN\",\"WWW.vodafone.net.nz\""); // Open a GPRS context
    delay(3000);
    printSerialData();
    myGsm.println("AT+SAPBR=1,1"); // Open a GPRS context
    delay(2000);
    printSerialData();
    myGsm.println("AT+SAPBR=2,1");  // To query the GPRS context, check connection status
    printSerialData();
    myGsm.println("AT+HTTPINIT");                  // Initialize HTTP
    delay(5000);
    printSerialData();
    myGsm.println("AT+HTTPPARA=\"CID\",1");    // End the PARA
    delay(5000);
    printSerialData();
    myGsm.print("AT+HTTPPARA=\"URL\",\"http://nordickindustries.epizy.com/send.php?sen1=5\""); // Send PARA command, set url to send data
    delay(2000);
    printSerialData();
    delay(2000);
    printSerialData();
    myGsm.println("");   // close url
    Serial.println("");
    delay(5000);
    printSerialData();
    delay(5000);
    myGsm.println("AT+HTTPACTION=0"); //send GET command
    delay(5000);
    printSerialData();
        delay(5000);
    printSerialData();
        delay(5000);
    printSerialData();
    myGsm.println("AT+HTTPREAD");
            delay(5000);
    printSerialData();
        delay(5000);
    printSerialData();
    myGsm.println("AT+HTTPTERM");
    delay(2000);
    printSerialData();
And a screenshot of the serial monitor:
Any help appreciated!!
It may depend on several things. After you send the command, you delay for several seconds before you even check the serial port of data. If the response is very quick and massive, you could overrun the serial buffer before you even begin reading. On the other hand, if you start reading immediately, it very well could be empty since the response has not begun yet. Also, the readString() function reads data until a newline.
I would implement a timer and try reading until the port is quiet for the timeout amount.
void printSerialData(unsigned long timeout) {  //send/read the SIM Module
  unsigned long startTime = millis();
  while(1) {
      char c = myGsm.read();
      Serial.print(c);
    else {
      if ( millis() - startTime >= timeout ) break;
      delay(100);
    delay(100);
