http.get without headers on serial
Hi.
How can I print response without headers? A use this code:
#include <Arduino.h>
#include <SoftwareSerial.h>
#include <WiFly.h>
#include "HTTPClient.h"
#define SSID      "Your-SSID"
#define KEY       "passphrase"
// WIFLY_AUTH_OPEN / WIFLY_AUTH_WPA1 / WIFLY_AUTH_WPA1_2 / WIFLY_AUTH_WPA2_PSK
#define AUTH      WIFLY_AUTH_WPA2_PSK
#define HTTP_GET_URL "http://httpbin.org/get?hello=world"
#define HTTP_POST_URL "http://httpbin.org/post"
#define HTTP_POST_DATA "Hello world!"
// Pins' connection
// Arduino       WiFly
//  2    <---->    TX
//  3    <---->    RX
WiFly wifly(2, 3);
HTTPClient http;
char get;
  Serial.println("------- WIFLY HTTP --------");
  // Wait WiFly to init
//  delay(3000);
  wifly.reset();
  while (1) {
    Serial.println("Try to join " SSID );
    if (wifly.join(SSID, KEY, AUTH)) {
      Serial.println("Succeed to join " SSID);
      wifly.clear();
      Serial.println("Failed to join " SSID);
      Serial.println("Wait 1 second and try again...");
  Serial.println("\r\nTry to get url - " HTTP_GET_URL);
  Serial.println("------------------------------");
  while (http.get(HTTP_GET_URL, 10000) < 0) {
  while (wifly.receive((uint8_t *)&get, 1, 1000) == 1) {
    Serial.print(get);
  Serial.println("\r\n\r\nTry to post data to url - " HTTP_POST_URL);
  Serial.println("-------------------------------");
  while (http.post(HTTP_POST_URL, HTTP_POST_DATA, 10000) < 0) {
    Serial.print(get);
  if (wifly.commandMode()) {
    Serial.println("\r\n\r\nEnter command mode. Send \"exit\"(with \\r) to exit command mode");
  int c;
  while (wifly.available()) {
    c = wifly.read();
    if (c > 0) {
      Serial.write((char)c);
  while (Serial.available()) {
    c = Serial.read();
    if (c >= 0) {
      wifly.write((char)c);
I get the HTTP header code 200 OK, but I do not want to display the headers… Only clean remote file. :slight_smile: How to do it?
You must wait for the server to send a blank line. That is two newlines (or carriage return/newline) one after the other.
Take a look at the WebServer example included with the IDE. It uses the boolean variable currentLineIsBlank to track the current line status. If currentLineIsBlank evaluates to true and the next non-linefeed character is a newline, then you display everything after that.
THNX 8)
