HTTP POST request timeout when using iPhone hotspot
I am attempting to make an HTTP POST request to my server. I get the expected response when my MKR1000 is connected to my home wifi network. However, when I connect the MKR1000 to my iPhone 6s hotspot the request always times out.
Arduino MKR1000 code:
#define BLYNK_PRINT Serial
#include <WiFi101.h>
#include <ArduinoHttpClient.h>
#include <BlynkSimpleMKR1000.h>
const int button_pin = 7;
const char ssid[] = "****";
const char pass[] = "****";
const char server[] = "****";
const int port = 80;
WiFiClient wifi;
HttpClient client = HttpClient(wifi, server, port);
const char auth[] = "****";
int status = WL_IDLE_STATUS;
float x;
float y;
float z;
float dx;
float dy;
float dz;
float lng;
float lat;
  pinMode(button_pin, INPUT);
  pinMode(LED_BUILTIN, OUTPUT);
  digitalWrite(LED_BUILTIN, HIGH);
  while (status != WL_CONNECTED) {
    Serial.print("Connecting to: ");
    Serial.println(ssid);
    status = WiFi.begin(ssid, pass);
  Blynk.begin(auth, ssid, pass);
  digitalWrite(LED_BUILTIN, LOW);
  Blynk.run();
  if (digitalRead(button_pin)) {
    String route = "/";
    String contentType = "application/json";
    String postData = "{\"latitude\":" + String(lat, 6) + ",\"longitude\":" + String(lng, 6) + "}";
    Serial.print("Data: ");
    Serial.println(postData);
    client.post(route, contentType, postData);
    int statusCode = client.responseStatusCode();
    String response = client.responseBody();
    Serial.print("Status code: ");
    Serial.println(statusCode);
    Serial.print("Response: ");
    Serial.println(response);
BLYNK_WRITE(V0)
  dx = param[0].asFloat() - x;
  dy = param[1].asFloat() - y;
  dz = param[2].asFloat() + 1 - y;
  x = param[0].asFloat();
  y = param[1].asFloat();
  z = param[2].asFloat() + 1;
  Serial.println("acc data updated");
BLYNK_WRITE(V1)
  lat = param[0].asFloat();
  lng = param[1].asFloat();
  Serial.println("gps data updated");
It is important for it to work on my iPhone hotspot because the MKR1000 will not be within range of my home wifi network. Thanks in advance for the help.
I solved the problem. I was attempting to make the request to my server using its local IP address which is only accessible on my home network.
