HTTP POST to MySQL a Float Array
Hi all, currently I am trying to create a code to simulate how an Arduino Sensor will transmit a float array of 1 X 32 values to MySQL Database for it to store it via POST.
Below is the Arduino code for reference:
#include <SPI.h>
#include <WiFi.h>
const char* ssid = "Router";
const char* pass = "PASSWORD";
int status = WL_IDLE_STATUS;
IPAddress server(192,164,0,100);  // Localhost
long previousMillis = 0;
unsigned long currentMillis = 0;
long interval = 250000; // READING INTERVAL
int i;
//float my_array[32];
String data[32];
// Initialize the client library
WiFiClient client;
  Serial.println("Attempting to connect to WPA network...");
  Serial.print("SSID: ");
  Serial.println(ssid);
  WiFi.begin(ssid, pass);
    Serial.println("Connecting to WiFi..");
    Serial.println("Connected to wifi");
    Serial.println("\nStarting connection...");
    Serial.print("IP Address: ");
    Serial.print("Gateway: ");
    Serial.println(WiFi.gatewayIP());
    Serial.print("Signal strength: ");
    Serial.print(WiFi.RSSI());
    Serial.println(" dBm");
for (i = 0; i < 32; i++) {
    data[i]=String(random(200,400));
  if (client.connect(server,80)) { // REPLACE WITH YOUR SERVER ADDRESS
    client.println("POST /newfolder/test.php HTTP/1.1");
    client.println("Host: 192.188.0.204"); // SERVER ADDRESS HERE TOO
    client.println("User-Agent: ESP32");
    client.println("Connection: Keep-Alive");
    client.println("Content-Type: application/x-www-form-urlencoded");
    client.print("Content-Length: ");
    //client.println(data.length());
    client.println();
    client.println(data);
    client.println();
    Serial.println(data);
  } else{
    Serial.println("Not working");
  if (client.connected()) {
    client.stop();  // DISCONNECT FROM THE SERVER
  delay(10000);
  • So far, is it possible to send a string array of 32 values to the MySQL ? If not, do I have to use a string variable instead ? Like this:
#include <SPI.h>
#include <WiFi.h>
const char* ssid = "TP-LINK_9BB34C";
const char* pass = "18645378";
IPAddress server(192,168,0,100);  // Localhost
int i;
float my_array[32];
String data="";
WiFiClient client;
    my_array[i]=random(200,400);
    data=data + String(my_array[i]) + " ";
//  if (client.connect(server,80)) { // REPLACE WITH YOUR SERVER ADDRESS
    client.println("POST /server_check/add.php HTTP/1.1");
    client.println("Host: 192.180.0.100"); // SERVER ADDRESS HERE TOO
    Serial.println(data.length());
    client.println();
    client.print(data);
    client.println();
    data="\0";
  delay(5000);
  1. If I send it as a string to the MySQL, how do I actually write the query to actually update the tables with the 32 values into 32 columns? Would it be similar to the solution in this link sql - How to get only Digits from String in mysql? - Stack Overflow
