I'm doing something similar and I also need advice on getting the Arduino code to work. I only want the HTTP Call to occur when the switch is closed (buttonState == HIGH). I have this Arduino code currently:
Connect();
startup();
loopConnect();
#include <SPI.h>
#include <WiFi.h>
char ssid[] = "Verizon-SM-G935V-5E4D"; // your network SSID (name)
char pass[] = "TaintedLove"; // your network password (use for WPA, or use as key for WEP)
int keyIndex = 0; // your network key Index number (needed only for WEP)
int status = WL_IDLE_STATUS;
// if you don't want to use DNS (and reduce your sketch size)
// use the numeric IP instead of the name for the server:
IPAddress server(192,168,43,236); // numeric IP for Google (no DNS)
//char server[] = "https://.com"; // name address for Google (using DNS)
// Initialize the Ethernet client library
// with the IP address and port of the server
// that you want to connect to (port 80 is default for HTTP):
WiFiClient client;
const int buttonPin = 4;
int buttonState = 0;
void startup() {
// check for the presence of the shield:
if (WiFi.status() == WL_NO_SHIELD) {
Serial.println("WiFi shield not present");
// don't continue:
while(true);
// attempt to connect to Wifi network:
while (status != WL_CONNECTED) {
Serial.print("Attempting to connect to SSID: ");
Serial.println(ssid);
// Connect to WPA/WPA2 network. Change this line if using open or WEP network:
status = WiFi.begin(ssid, pass);
// wait 10 seconds for connection:
delay(10000);
Serial.println("Connected to wifi");
printWifiStatus();
void Connect() {
//Initialize serial and wait for port to open:
Serial.println("\nStarting connection to server...");
// if you get a connection, report back via serial:
if (client.connect(server, 3000)) {
Serial.println("connected to server");
// Make a HTTP request:
client.println("POST /Page1 HTTP/1.1");
//client.println("Host: ");
client.println("Connection: close");
client.println();
void loopConnect() {
buttonState = digitalRead(buttonPin);
if (buttonState == HIGH) {
Connect();
// if there are incoming bytes available
// from the server, read them and print them:
while (client.available()) {
char c = client.read();
Serial.write(c);
// if the server's disconnected, stop the client:
if (!client.connected()) {
Serial.println("disconnecting from server.");
client.stop();
// do nothing forevermore:
while(true);
void printWifiStatus() {
// print the SSID of the network you're attached to:
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print your WiFi shield's IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
// print the received signal strength:
long rssi = WiFi.RSSI();
Serial.print("signal strength (RSSI):");
Serial.print(rssi);
Serial.println(" dBm");
