Hi.
I have a account in Voipraider and it´s possible to send a SMS via url like this:
https://www.voipraider.com/myaccount/sendsms.php?username=myusername&password=mypassword&from=xxxxxxxxxx&to=phonenumber&text=ARDUINO
If I paste this url in any browser with my login, password and the destination phone number, all works ok.
The message ARDUINO is sent to phone.
I´m trying to send this via Arduino Ethernet Shield with this code but nothing happens. The server connects ok but the message dont arrive. What am I doing wrong? Please if you can help me I appreciate it.
Thank you
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
char server[] = "www.voipraider.com";
// Set the static IP address to use if the DHCP fails to assign
IPAddress ip(192,168,0,108);
// Initialize the Ethernet client library
// with the IP address and port of the server
// that you want to connect to (port 80 is default for HTTP):
EthernetClient client;
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
// start the Ethernet connection:
if (Ethernet.begin(mac) == 0) {
Serial.println("Failed to configure Ethernet using DHCP");
// no point in carrying on, so do nothing forevermore:
// try to congifure using IP address instead of DHCP:
Ethernet.begin(mac, ip);
// give the Ethernet shield a second to initialize:
Serial.println("connecting...");
// if you get a connection, report back via serial:
if (client.connect(server, 80)) {
Serial.println("connected");
// Make a HTTP request:
client.println("GET /myaccount/sendsms.php?username=myusername&password=mypassword&from=xxxxxxxxxx&to=phonenumber&text=arduino HTTP/1.1");
client.println("Host: www.voipraider.com");
client.println("Connection: close");
client.println();
else {
// kf you didn't get a connection to the server:
Serial.println("connection failed");
// if there are incoming bytes available
// from the server, read them and print them:
if (client.available()) {
char c = client.read();
Serial.print(c);
// if the server's disconnected, stop the client:
if (!client.connected()) {
Serial.println("disconnecting.");
client.stop();
// do nothing forevermore:
while(true);
