I'm very new with Arduino code.
I tried to call webpage with input parameters
It's works 3 times and after it's finished....
Did you have a idea ?
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address for your controller below.
// Newer Ethernet shields have a MAC address printed on a sticker on the shield
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress server(192,168,2,114); // Google
// Initialize the Ethernet client library
// with the IP address and port of the server
// that you want to connect to (port 80 is default for HTTP):
EthernetClient client;
// start the serial library:
// start the Ethernet connection:
if (Ethernet.begin(mac) == 0) {
Serial.println("Failed to configure Ethernet using DHCP");
// no point in carrying on, so do nothing forevermore:
for(;;)
connectWS();
// give the Ethernet shield a second to initialize:
//Read input
int val = Serial.read() - '0';
switch(val) {
case 0:
Serial.println("OFF");
client.println("GET /index.php?action=off HTTP/1.0");
client.println();
case 1:
Serial.println("ON");
// Make a HTTP request:
client.println("GET /index.php?action=on HTTP/1.0");
client.println();
default:
Serial.println("wainting action");
String connectWS(){
//port 80 is typical of a www page
if (!client | !client.connected()) {
if (client.connect(server, 80)) {
Serial.println("connected");
client.println();
}else{
return "connection failed";
Serial.println("Already connected");
String disconnectWS() {
if(client) {
client.stop();
Serial.println("disconnecting.");
