HTTP response size (Esp8266)
Hello!
I've been at this for a couple of days and I'm having trouble understanding a solution. I'm doing an http request on my esp8266 expecting a json file that i'll parse for later use. But the problem I'm encountering is that the "http.getString()" returns only a sliver of the json file. I'm having a hard time finding documentation regarding size of the return and I'm at my wits end.
Here is the relevant parts of the code:
#include <ESP8266WiFi.h>
#include <ESP8266HTTPClient.h>
const char *ssid     = "xxx";
const char *password = "xxx";
const char* serverName = "http://............";
WiFiClient wifiClient;
void setup(){
  WiFi.begin(ssid, password);
  while ( WiFi.status() != WL_CONNECTED ) {
    delay ( 500 );
    Serial.print ( "." );
  Serial.println("Wifi Connected");
  int urgency;
  String jsonFile;
  HTTPClient http;
  http.begin(wifiClient, serverName);
  int httpResponseCode = http.GET();
  if (httpResponseCode>0) {
    Serial.print("HTTP Response code: ");
    Serial.println(httpResponseCode);
    jsonFile = http.getString();
    Serial.println(jsonFile);
  delay(10000);
The usual length of a response I'm expecting could be roughly 12000 chars but I'm usually only getting < 10%
Is there another way to get the data, maybe as a bytestream or anything else. As long as i can get the full message.
I think you can treat the client as a stream:
    while (http.available())
      Serial.print(http.read();
When the time comes to deserialize your JSON, you can do that directly into a JSON document:
StaticJsonDocument<999> doc;
DeserializationError error = deserializeJson(doc, http);
if (error) {
  Serial.print("deserializeJson() failed: ");
  Serial.println(error.c_str());
  return;
Given an example of the JSON, the ArduinoJson 'Assistant' can write the code for you:
Unfortunantly it seems like the http library im using for the Esp8266 (<ESP8266HTTPClient.h>) doesnt have a http.available (or any similar function as to what i can see). I've tried using the <ArduinoHttpClient.h> library as well but it is not behaving well (or at all).
But thanks for the deserialization that might come in handy if i manage to fix my first problem
