(http1.1) text save together with value to database
Hi, as previous topic I had solved the problem by adding a line code as below (cliente.println("HTTP/1.1");):
sensors.requestTemperatures();
  Celcius = sensors.getTempCByIndex(0);
  if (cliente.connect(serv, 80)) { //Connecting at the IP address and port we saved before
    Serial.println("temp-connected");
    cliente.print("GET /garden/Components/insertwtemp?"); //Connecting and Sending values to database
    cliente.print("wtemperature=");
    cliente.print(Celcius);
    //Printing the values on the serial monitor
    Serial.print("Water Temperature= ");
    Serial.println(Celcius);
    cliente.stop(); //Closing the connection
  else {
    // if you didn't get a connection to the server:
    Serial.println("connection failed");
But the outcome in database as shown in picture below, without this line code I cant save my data to database
Is there any solution to solve it? Much appreciate
