Hello everyone,
im trying to do an async webserver with access point using an ESP32.
Its a little bit of a mix between this tutorial for AP and async and this tutorial since its also with an async webserver and it uses inputs which i desperatly need.
The part i dont understand is i included all the necessary libraries and i still got this error. If i copy paste the code in one block everything is fine. So whats wrong?
These are my errors:
In file included from C:\..\Arduino\libraries\ESPAsyncWebServer-master\src/ESPAsyncWebServer.h:467:0,
from C:\..\AppData\Local\Temp\arduino_build_497972\sketch\webserver.h:5,
from C:\..\Async Webserver ESP32\main\main.ino:3:
C:\..\Arduino\libraries\ESPAsyncWebServer-master\src/WebHandlerImpl.h: In constructor 'AsyncCallbackWebHandler::AsyncCallbackWebHandler()':
C:\..\Arduino\libraries\ESPAsyncWebServer-master\src/WebHandlerImpl.h:76:49: error: 'HTTP_ANY' was not declared in this scope
AsyncCallbackWebHandler() : _uri(), _method(HTTP_ANY), _onRequest(NULL), _onUpload(NULL), _onBody(NULL), _isRegex(false) {}
from C:\..\AppData\Local\Temp\arduino_build_497972\sketch\webserver.cpp:1:
C:\Users\Valentin\AppData\Local\Temp\arduino_build_497972\sketch\webserver.cpp: In function 'void setup_server(AsyncWebServer)':
webserver.cpp:6:18: error: 'HTTP_GET' was not declared in this scope
server.on("/", HTTP_GET, [](AsyncWebServerRequest * request) {
Multiple libraries were found for "WiFi.h"
Used: C:\..\Arduino15\packages\firebeetle32\hardware\esp32\0.1.1\libraries\WiFi
Not used: C:\Program Files (x86)\Arduino\libraries\WiFi
Using library ESPAsyncWebServer-master at version 1.2.3 in folder: C:\..\Arduino\libraries\ESPAsyncWebServer-master
Using library FS at version 1.0 in folder: C:\..\Arduino15\packages\firebeetle32\hardware\esp32\0.1.1\libraries\FS
Using library WiFi at version 1.0 in folder: C:\..\Arduino15\packages\firebeetle32\hardware\esp32\0.1.1\libraries\WiFi
Using library AsyncTCP-master at version 1.1.1 in folder: C:\..\Arduino\libraries\AsyncTCP-master
exit status 1
I already tried to use the standard arduino WiFi library which resulted just in more errors so i switched it back.
I split up the code into three pieces for better visibility.
main.ino
#include <Arduino.h>
#include "webserver.h"
// REPLACE WITH YOUR NETWORK CREDENTIALS
const char* ssid = "blabla";
const char* password = "blabla";
WiFi.softAP(ssid, password);
IP = WiFi.softAPIP();
Serial.print("IP Address: ");
Serial.println(IP);
setup_server(server);
webserver.cpp
void setup_server(AsyncWebServer server) {
// Send web page with input fields to client
request->send_P(200, "text/html", index_html);
// Send a GET request to <ESP_IP>/get?input1=<inputMessage>
server.on("/get", HTTP_GET, [] (AsyncWebServerRequest * request) {
// GET input1 value on <ESP_IP>/get?input1=<inputMessage>
if (request->hasParam(PARAM_INPUT_1)) {
inputMessage = request->getParam(PARAM_INPUT_1)->value();
inputParam = PARAM_INPUT_1;
// GET input2 value on <ESP_IP>/get?input2=<inputMessage>
else if (request->hasParam(PARAM_INPUT_2)) {
inputMessage = request->getParam(PARAM_INPUT_2)->value();
inputParam = PARAM_INPUT_2;
// GET input3 value on <ESP_IP>/get?input3=<inputMessage>
else if (request->hasParam(PARAM_INPUT_3)) {
inputMessage = request->getParam(PARAM_INPUT_3)->value();
inputParam = PARAM_INPUT_3;
else {
inputMessage = "No message sent";
inputParam = "none";
Serial.println(inputMessage);
request->send(200, "text/html", "HTTP GET request sent to your ESP on input field ("
+ inputParam + ") with value: " + inputMessage +
<a href=\"/\">Return to Home Page</a>");
server.onNotFound(notFound);
server.begin();
void notFound(AsyncWebServerRequest *request) {
request->send(404, "text/plain", "Not found");
webserver.h
#ifndef WEBSERVER_H
#define WEBSERVER_H
#include "Arduino.h"
#include "ESPAsyncWebServer.h"
#include "AsyncTCP.h"
#include <WiFi.h>
const char* PARAM_INPUT_1 = "input1";
const char* PARAM_INPUT_2 = "input2";
const char* PARAM_INPUT_3 = "input3";
AsyncWebServer server(80);
String music_state;
IPAddress IP;
String inputMessage;
String inputParam;
// HTML web page to handle 3 input fields (input1, input2, input3)
const char index_html[] PROGMEM = R"rawliteral(
<!DOCTYPE HTML><html><head>
<title>ESP Input Form</title>
<meta name="viewport" content="width=device-width, initial-scale=1">
</head><body>
<form action="/get">
input1: <input type="text" name="input1">
<input type="submit" value="Submit">
</form>
input2: <input type="text" name="input2">
</form>
input3: <input type="text" name="input3">
</form>
</body></html>)rawliteral";
void setup_server(AsyncWebServer server);
void notFound(AsyncWebServerRequest *request);
#endif
Thanks for the input, i will check back tomorrow and answer all questions and test every suggestion
