I am trying to run this HTTPClient Library but no matter what I do, I keep getting this error message:
C:\Users\Username\Documents\Arduino\libraries\HTTPClient\src\HTTPClient.cpp:30:10: fatal error: esp32-hal-log.h: No such file or directory
30 | #include <esp32-hal-log.h>
compilation terminated.
exit status 1
Error compiling for board LOLIN(WEMOS) D1 R2 & mini.
I've tried replacing the library but still get the error when compiling the code. Help would be appreciated.
I always include the following libraries
#include "sdkconfig.h"
#include "esp_system.h"
to get log printing.
void fReadCurrent( void * parameter )
const TickType_t xFrequency = 1000; //delay for mS
const float mVperAmp = 185.0f;
float ADbits = 4096.0f;
float ref_voltage = 3.3f;
float mA = 0.0f;
float adcValue = 0.0f;
float Voltage = 0.0f;
float Power = 0.0f;
float offSET = 0.0f;
int printCount = 0;
uint64_t TimePastKalman = esp_timer_get_time(); // used by the Kalman filter UpdateProcessNoise, time since last kalman calculation
SimpleKalmanFilter KF_I( 1.0f, 1.0f, .01f );
185mv/A = 5 AMP MODULE
100mv/A = 20 amp module
66mv/A = 30 amp module
String powerInfo = "";
powerInfo.reserve( 150 );
while ( !MQTTclient.connected() )
vTaskDelay( 250 );
TickType_t xLastWakeTime = xTaskGetTickCount();
for (;;)
adc1_get_raw(ADC1_CHANNEL_3); // read once discard reading
adcValue = ( (float)adc1_get_raw(ADC1_CHANNEL_3) );
//log_i( "adcValue I = %f", adcValue );
Voltage = ( (adcValue * ref_voltage) / ADbits ) + offSET; // Gets you mV
mA = Voltage / mVperAmp; // get amps
KF_I.setProcessNoise( (esp_timer_get_time() - TimePastKalman) / 1000000.0f ); //get time, in microsecods, since last readings
mA = KF_I.updateEstimate( mA ); // apply simple Kalman filter
TimePastKalman = esp_timer_get_time(); // time of update complete
printCount++;
if ( printCount == 60 )
xSemaphoreTake( sema_CalculatedVoltage, portMAX_DELAY);
Power = CalculatedVoltage * mA;
log_i( "Voltage=%f mA=%f Power=%f", CalculatedVoltage, mA, Power );
printCount = 0;
powerInfo.concat( String(CalculatedVoltage, 2) );
xSemaphoreGive( sema_CalculatedVoltage );
powerInfo.concat( ",");
powerInfo.concat( String(mA, 4) );
powerInfo.concat( String(Power, 4) );
xSemaphoreTake( sema_MQTT_KeepAlive, portMAX_DELAY );
MQTTclient.publish( topicPower, powerInfo.c_str() );
xSemaphoreGive( sema_MQTT_KeepAlive );
powerInfo = "";
vTaskDelayUntil( &xLastWakeTime, xFrequency );
vTaskDelete( NULL );
} //void fReadCurrent( void * parameter )
In the above task, I am using log_i
@rangobeans, your topic has been moved to a more suitable location on the forum as this has nothing to do with Avrdude, stk500 or Bootloader.
system
Closed
4
