When compiling code for upload to card, I get error that stops upload the code SimpleHttpExample included in latest library file from GitHub. I am using Arduino:1.8.19 , Card "NodeMCU 1.0 (ESP-12E Module).
I dont find solution of error message - """
C:\Users\Trond\Documents\Arduino\libraries\HttpClient\b64.cpp: In function 'int b64_encode(const unsigned char*, int, unsigned char*, int)':
C:\Users\Trond\Documents\Arduino\libraries\HttpClient\b64.cpp:69:1: error: control reaches end of non-void function [-Werror=return-type]
69 | }
cc1plus.exe: some warnings being treated as errors
Uses libraries SPI versjon 1.0 i folders C:\Users\Trond\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SPI
Uses libraries HttpClient ved versjon 2.2.0 in folder C:\Users\Trond\Documents\Arduino\libraries\HttpClient
Uses library Ethernet ved versjon 2.0.1 in folder C:\Users\Trond\Documents\Arduino\libraries\Ethernet
exit status 1
Error when compiling for card NodeMCU 1.0 (ESP-12E Module). """
SimpleHttpExample.ino (3.0 KB)
post the full error message. usually the first one at the top is the one you need to worry about
Hi
post the link where you downloaded the code:
SimpleHttpExample
and libraries:
Ethernet.h and EthernetClient.h.
Hi J-M-L.
Her is the full error message
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Trond\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Trond\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Trond\Documents\Arduino\libraries -fqbn=esp8266:esp8266:nodemcuv2:xtal=80,vt=flash,exception=disabled,stacksmash=disabled,ssl=all,mmu=3232,non32xfer=fast,eesz=4M,led=2,ip=lm2f,dbg=Disabled,lvl=None____,wipe=none,baud=115200 -ide-version=10819 -build-path C:\Users\Trond\AppData\Local\Temp\arduino_build_96563 -warnings=default -build-cache C:\Users\Trond\AppData\Local\Temp\arduino_cache_737968 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\Trond\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.xtensa-lx106-elf-gcc-3.0.4-gcc10.3-1757bed.path=C:\Users\Trond\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.python3.path=C:\Users\Trond\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1 -prefs=runtime.tools.python3-3.7.2-post1.path=C:\Users\Trond\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1 -prefs=runtime.tools.mklittlefs.path=C:\Users\Trond\AppData\Local\Arduino15\packages\esp8266\tools\mklittlefs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mklittlefs-3.0.4-gcc10.3-1757bed.path=C:\Users\Trond\AppData\Local\Arduino15\packages\esp8266\tools\mklittlefs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mkspiffs.path=C:\Users\Trond\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mkspiffs-3.0.4-gcc10.3-1757bed.path=C:\Users\Trond\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\3.0.4-gcc10.3-1757bed -verbose C:\Program Files (x86)\Arduino\libraries\HttpClient-2.2.0\HttpClient-2.2.0\examples\SimpleHttpExample\SimpleHttpExample.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Trond\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Trond\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Trond\Documents\Arduino\libraries -fqbn=esp8266:esp8266:nodemcuv2:xtal=80,vt=flash,exception=disabled,stacksmash=disabled,ssl=all,mmu=3232,non32xfer=fast,eesz=4M,led=2,ip=lm2f,dbg=Disabled,lvl=None____,wipe=none,baud=115200 -ide-version=10819 -build-path C:\Users\Trond\AppData\Local\Temp\arduino_build_96563 -warnings=default -build-cache C:\Users\Trond\AppData\Local\Temp\arduino_cache_737968 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\Trond\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.xtensa-lx106-elf-gcc-3.0.4-gcc10.3-1757bed.path=C:\Users\Trond\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.python3.path=C:\Users\Trond\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1 -prefs=runtime.tools.python3-3.7.2-post1.path=C:\Users\Trond\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1 -prefs=runtime.tools.mklittlefs.path=C:\Users\Trond\AppData\Local\Arduino15\packages\esp8266\tools\mklittlefs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mklittlefs-3.0.4-gcc10.3-1757bed.path=C:\Users\Trond\AppData\Local\Arduino15\packages\esp8266\tools\mklittlefs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mkspiffs.path=C:\Users\Trond\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mkspiffs-3.0.4-gcc10.3-1757bed.path=C:\Users\Trond\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\3.0.4-gcc10.3-1757bed -verbose C:\Program Files (x86)\Arduino\libraries\HttpClient-2.2.0\HttpClient-2.2.0\examples\SimpleHttpExample\SimpleHttpExample.ino
Using board 'nodemcuv2' from platform in folder: C:\Users\Trond\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2
Using core 'esp8266' from platform in folder: C:\Users\Trond\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2
Detecting libraries used...
"C:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Trond\\AppData\\Local\\Temp\\arduino_build_96563/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\nodemcu" "C:\\Users\\Trond\\AppData\\Local\\Temp\\arduino_build_96563\\sketch\\SimpleHttpExample.ino.cpp" -o nul
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
-> candidates: [SPI@1.0]
"C:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Trond\\AppData\\Local\\Temp\\arduino_build_96563/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\nodemcu" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\SPI" "C:\\Users\\Trond\\AppData\\Local\\Temp\\arduino_build_96563\\sketch\\SimpleHttpExample.ino.cpp" -o nul
Alternatives for HttpClient.h: [HttpClient@2.2.0]
ResolveLibrary(HttpClient.h)
-> candidates: [HttpClient@2.2.0]
"C:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Trond\\AppData\\Local\\Temp\\arduino_build_96563/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\nodemcu" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\SPI" "-IC:\\Users\\Trond\\Documents\\Arduino\\libraries\\HttpClient" "C:\\Users\\Trond\\AppData\\Local\\Temp\\arduino_build_96563\\sketch\\SimpleHttpExample.ino.cpp" -o nul
Alternatives for Ethernet.h: [Ethernet@2.0.1]
ResolveLibrary(Ethernet.h)
-> candidates: [Ethernet@2.0.1]
"C:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Trond\\AppData\\Local\\Temp\\arduino_build_96563/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\nodemcu" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\SPI" "-IC:\\Users\\Trond\\Documents\\Arduino\\libraries\\HttpClient" "-IC:\\Users\\Trond\\Documents\\Arduino\\libraries\\Ethernet\\src" "C:\\Users\\Trond\\AppData\\Local\\Temp\\arduino_build_96563\\sketch\\SimpleHttpExample.ino.cpp" -o nul
"C:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Trond\\AppData\\Local\\Temp\\arduino_build_96563/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\nodemcu" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\SPI" "-IC:\\Users\\Trond\\Documents\\Arduino\\libraries\\HttpClient" "-IC:\\Users\\Trond\\Documents\\Arduino\\libraries\\Ethernet\\src" "C:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\SPI\\SPI.cpp" -o nul
"C:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Trond\\AppData\\Local\\Temp\\arduino_build_96563/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\nodemcu" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\SPI" "-IC:\\Users\\Trond\\Documents\\Arduino\\libraries\\HttpClient" "-IC:\\Users\\Trond\\Documents\\Arduino\\libraries\\Ethernet\\src" "C:\\Users\\Trond\\Documents\\Arduino\\libraries\\HttpClient\\HttpClient.cpp" -o nul
"C:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Trond\\AppData\\Local\\Temp\\arduino_build_96563/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\nodemcu" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\SPI" "-IC:\\Users\\Trond\\Documents\\Arduino\\libraries\\HttpClient" "-IC:\\Users\\Trond\\Documents\\Arduino\\libraries\\Ethernet\\src" "C:\\Users\\Trond\\Documents\\Arduino\\libraries\\HttpClient\\b64.cpp" -o nul
"C:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Trond\\AppData\\Local\\Temp\\arduino_build_96563/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\nodemcu" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\SPI" "-IC:\\Users\\Trond\\Documents\\Arduino\\libraries\\HttpClient" "-IC:\\Users\\Trond\\Documents\\Arduino\\libraries\\Ethernet\\src" "C:\\Users\\Trond\\Documents\\Arduino\\libraries\\Ethernet\\src\\Dhcp.cpp" -o nul
"C:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Trond\\AppData\\Local\\Temp\\arduino_build_96563/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\nodemcu" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\SPI" "-IC:\\Users\\Trond\\Documents\\Arduino\\libraries\\HttpClient" "-IC:\\Users\\Trond\\Documents\\Arduino\\libraries\\Ethernet\\src" "C:\\Users\\Trond\\Documents\\Arduino\\libraries\\Ethernet\\src\\Dns.cpp" -o nul
"C:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Trond\\AppData\\Local\\Temp\\arduino_build_96563/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\nodemcu" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\SPI" "-IC:\\Users\\Trond\\Documents\\Arduino\\libraries\\HttpClient" "-IC:\\Users\\Trond\\Documents\\Arduino\\libraries\\Ethernet\\src" "C:\\Users\\Trond\\Documents\\Arduino\\libraries\\Ethernet\\src\\Ethernet.cpp" -o nul
"C:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Trond\\AppData\\Local\\Temp\\arduino_build_96563/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\nodemcu" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\SPI" "-IC:\\Users\\Trond\\Documents\\Arduino\\libraries\\HttpClient" "-IC:\\Users\\Trond\\Documents\\Arduino\\libraries\\Ethernet\\src" "C:\\Users\\Trond\\Documents\\Arduino\\libraries\\Ethernet\\src\\EthernetClient.cpp" -o nul
"C:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Trond\\AppData\\Local\\Temp\\arduino_build_96563/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\nodemcu" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\SPI" "-IC:\\Users\\Trond\\Documents\\Arduino\\libraries\\HttpClient" "-IC:\\Users\\Trond\\Documents\\Arduino\\libraries\\Ethernet\\src" "C:\\Users\\Trond\\Documents\\Arduino\\libraries\\Ethernet\\src\\EthernetServer.cpp" -o nul
"C:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Trond\\AppData\\Local\\Temp\\arduino_build_96563/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\nodemcu" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\SPI" "-IC:\\Users\\Trond\\Documents\\Arduino\\libraries\\HttpClient" "-IC:\\Users\\Trond\\Documents\\Arduino\\libraries\\Ethernet\\src" "C:\\Users\\Trond\\Documents\\Arduino\\libraries\\Ethernet\\src\\EthernetUdp.cpp" -o nul
"C:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Trond\\AppData\\Local\\Temp\\arduino_build_96563/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\nodemcu" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\SPI" "-IC:\\Users\\Trond\\Documents\\Arduino\\libraries\\HttpClient" "-IC:\\Users\\Trond\\Documents\\Arduino\\libraries\\Ethernet\\src" "C:\\Users\\Trond\\Documents\\Arduino\\libraries\\Ethernet\\src\\socket.cpp" -o nul
"C:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Trond\\AppData\\Local\\Temp\\arduino_build_96563/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\nodemcu" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\SPI" "-IC:\\Users\\Trond\\Documents\\Arduino\\libraries\\HttpClient" "-IC:\\Users\\Trond\\Documents\\Arduino\\libraries\\Ethernet\\src" "C:\\Users\\Trond\\Documents\\Arduino\\libraries\\Ethernet\\src\\utility\\w5100.cpp" -o nul
Generating function prototypes...
"C:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Trond\\AppData\\Local\\Temp\\arduino_build_96563/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\nodemcu" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\SPI" "-IC:\\Users\\Trond\\Documents\\Arduino\\libraries\\HttpClient" "-IC:\\Users\\Trond\\Documents\\Arduino\\libraries\\Ethernet\\src" "C:\\Users\\Trond\\AppData\\Local\\Temp\\arduino_build_96563\\sketch\\SimpleHttpExample.ino.cpp" -o "C:\\Users\\Trond\\AppData\\Local\\Temp\\arduino_build_96563\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\Trond\\AppData\\Local\\Temp\\arduino_build_96563\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Kompilerer skisse...
"C:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\python3\\3.7.2-post1/python3" -I "C:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/signing.py" --mode header --publickey "C:\\Program Files (x86)\\Arduino\\libraries\\HttpClient-2.2.0\\HttpClient-2.2.0\\examples\\SimpleHttpExample/public.key" --out "C:\\Users\\Trond\\AppData\\Local\\Temp\\arduino_build_96563/core/Updater_Signing.h"
"C:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Trond\\AppData\\Local\\Temp\\arduino_build_96563/core" -c -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\nodemcu" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\SPI" "-IC:\\Users\\Trond\\Documents\\Arduino\\libraries\\HttpClient" "-IC:\\Users\\Trond\\Documents\\Arduino\\libraries\\Ethernet\\src" "C:\\Users\\Trond\\AppData\\Local\\Temp\\arduino_build_96563\\sketch\\SimpleHttpExample.ino.cpp" -o "C:\\Users\\Trond\\AppData\\Local\\Temp\\arduino_build_96563\\sketch\\SimpleHttpExample.ino.cpp.o"
Compiling libraries...
Compiling library "SPI"
"C:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Trond\\AppData\\Local\\Temp\\arduino_build_96563/core" -c -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\nodemcu" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\SPI" "-IC:\\Users\\Trond\\Documents\\Arduino\\libraries\\HttpClient" "-IC:\\Users\\Trond\\Documents\\Arduino\\libraries\\Ethernet\\src" "C:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\SPI\\SPI.cpp" -o "C:\\Users\\Trond\\AppData\\Local\\Temp\\arduino_build_96563\\libraries\\SPI\\SPI.cpp.o"
Compiling library "HttpClient"
"C:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Trond\\AppData\\Local\\Temp\\arduino_build_96563/core" -c -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\nodemcu" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\SPI" "-IC:\\Users\\Trond\\Documents\\Arduino\\libraries\\HttpClient" "-IC:\\Users\\Trond\\Documents\\Arduino\\libraries\\Ethernet\\src" "C:\\Users\\Trond\\Documents\\Arduino\\libraries\\HttpClient\\HttpClient.cpp" -o "C:\\Users\\Trond\\AppData\\Local\\Temp\\arduino_build_96563\\libraries\\HttpClient\\HttpClient.cpp.o"
"C:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Trond\\AppData\\Local\\Temp\\arduino_build_96563/core" -c -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\nodemcu" "-IC:\\Users\\Trond\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\SPI" "-IC:\\Users\\Trond\\Documents\\Arduino\\libraries\\HttpClient" "-IC:\\Users\\Trond\\Documents\\Arduino\\libraries\\Ethernet\\src" "C:\\Users\\Trond\\Documents\\Arduino\\libraries\\HttpClient\\b64.cpp" -o "C:\\Users\\Trond\\AppData\\Local\\Temp\\arduino_build_96563\\libraries\\HttpClient\\b64.cpp.o"
69 | }
Bruker bibliotek SPI ved versjon 1.0 i mappe C:\Users\Trond\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SPI
Bruker bibliotek HttpClient ved versjon 2.2.0 i mappe C:\Users\Trond\Documents\Arduino\libraries\HttpClient
Bruker bibliotek Ethernet ved versjon 2.0.1 i mappe C:\Users\Trond\Documents\Arduino\libraries\Ethernet
exit status 1
Feil ved kompilering for kort NodeMCU 1.0 (ESP-12E Module).
Hi ruilviana.
Normaly I download or update libraries from this site Arduino.CC.
I guess I have those library downloaded from GitHub if there was a link from Arduino.CC.
Thanks for helping,
Trond.
I don't have the same error when I try to compile the code but might just be different libraries being installed. My b64.cpp file lives in for me
.../Arduino/libraries/ArduinoHttpClient/src/b64.cpp
can you open
and post the function's code that ends line 69
where did you get this HttpClient ?
also see post #3 - where did you get those?
It looks like "File -> Examples -> ArduinoHttpClient -> Simple HttpExample" is for something like an Arduino WiFi V2, not for a ESP8266 (NodeMCU).
Try this example instead:
"File -> Examples -> ESP8266HTTPClient -> BasicHttpClient"
Hi J-M-L.
Here is b64 h-file:
#ifndef b64_h
#define b64_h
int b64_encode(const unsigned char* aInput, int aInputLen, unsigned char* aOutput, int aOutputLen);
#endif
And here is th Arduino file in lib.
// Simple Base64 code
// (c) Copyright 2010 MCQN Ltd.
// Released under Apache License, version 2.0
#include "b64.h"
/* Simple test program
#include <stdio.h>
void main()
char* in = "amcewen";
char out[22];
b64_encode(in, 15, out, 22);
out[21] = '\0';
printf(out);
// Work out if we've got enough space to encode the input
// Every 6 bits of input becomes a byte of output
if (aOutputLen < (aInputLen*8)/6)
// FIXME Should we return an error here, or just the length
return (aInputLen*8)/6;
// If we get here we've got enough space to do the encoding
const char* b64_dictionary = "ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz0123456789+/";
if (aInputLen == 3)
aOutput[0] = b64_dictionary[aInput[0] >> 2];
aOutput[1] = b64_dictionary[(aInput[0] & 0x3)<<4|(aInput[1]>>4)];
aOutput[2] = b64_dictionary[(aInput[1]&0x0F)<<2|(aInput[2]>>6)];
aOutput[3] = b64_dictionary[aInput[2]&0x3F];
else if (aInputLen == 2)
aOutput[2] = b64_dictionary[(aInput[1]&0x0F)<<2];
aOutput[3] = '=';
else if (aInputLen == 1)
aOutput[1] = b64_dictionary[(aInput[0] & 0x3)<<4];
aOutput[2] = '=';
aOutput[3] = '=';
// Break the input into 3-byte chunks and process each of them
int i;
for (i = 0; i < aInputLen/3; i++)
b64_encode(&aInput[i*3], 3, &aOutput[i*4], 4);
if (aInputLen % 3 > 0)
// It doesn't fit neatly into a 3-byte chunk, so process what's left
b64_encode(&aInput[i*3], aInputLen % 3, &aOutput[i*4], aOutputLen - (i*4));
Hello johnWasser.
I was wondering about that, if its not for NodeMCU, - but were does it say so. Should be some note about what the code and lib. is for ?
I suppose Arduino means the Arduino IDE and not only, the Arduino board. ...Here is the RAED ME for the lib.
# HttpClient
HttpClient is a library to make it easier to interact with web servers from Arduino.
## Dependencies
- Requires the new Ethernet library API (with DHCP and DNS) which is in Arduino 1.0 and later
Thanks for answering
Trond.
J-M-L , I got these lib from GitHub as written here in READ ME file :
## Installation
1. Download the latest version of the library from https://github.com/amcewen/HttpClient/releases and save the file somewhere
1. In the Arduino IDE, go to the Sketch -> Import Library -> Add Library... menu option
1. Find the zip file that you saved in the first step, and choose that
1. Check that it has been successfully added by opening the Sketch -> Import Library menu. You should now see HttpClient listed among the available libraries.
## Usage
In normal usage, handles the outgoing request and Host header. The returned status code is parsed for you, as is the Content-Length header (if present).
Because it expects an object of type Client, you can use it with any of the networking classes that derive from that. Which means it will work with EthernetClient, WiFiClient and GSMClient.
See the examples for more detail on how the library is used.
Thanks for the answers
Trond
the compiler is right the function b64_encode() promised to return an int and it does not always...
that's a bug in the library as not having a return statement when you promised you would do so leads to "Undefined Behavior" according to the C++ standard.
Thank you J-M-L.
Thats something I read in a explanation in some thead at a forum about this, but not sure how to change. And then I have to fix the code with a Return or some other way. Where is the logic place/ line to put the return then ?
Trond
just modify the library and add
return ((aInputLen+2)/3)*4;
just before the function's closing }
the end of the function should look like this
return ((aInputLen+2)/3)*4; // ADDED
Thanks. I'll try that.
man. 17. okt. 2022, 18:57 skrev J-M-L via Arduino Forum <notifications@arduino.discoursemail.com>:
