HttpClient Request Results in Status Code "-2"
Hi all
I am trying to send measuring data from my "Arduino Uni Wifi Rev. 2" over Wifi to a Web Server via HTTP Request, have been stuck for weeks with this issue now and would be insanely grateful for any help.
My Hardware:
  • Arduino Uni Wifi Rev. 2
My Libraries:
The Problem:
Every web request I send, no matter where (e.g. a Simple GET to google.ch or POST with data to grafana.net, which is my end goal), results in an empty response and error status code of -2. I can not figure out any details on what the cause for this error message is.
  • The Wifi Connection seems successful based on the logs, I can also visually see that it successfully connects to my iPhone Hotspot based on the blue indicator.
  • The request URL, Port, HTTP Post Types are correct and result in a valid response, I have tested that with Postman.
Serial Monitor Log Info:
1.4.3
** Scan Networks **
number of available networks:9
0) itsfrdm	Signal: -34 dBm	Encryption: WPA2
7) yts-32771	Signal: -92 dBm	Encryption: WPA2
WiFi Status - WL_IDLE_STATUS: 0
WiFi Status - WL_SCAN_COMPLETED: 2
Attempting to connect to WPA SSID: itsfrdm
WiFi Status - WL_CONNECTED: 3
You're connected to the network
IP Address: 172.20.10.4
172.20.10.4
MAC address: 24:62:AB:B9:22:68
SSID: itsfrdm
BSSID: F2:7:97:47:70:A0
signal strength (RSSI):-30
Encryption Type:4
Initialize NTPClient to get time
DHTxx test!
!wifiClient.connected()
Humidity: 52.00%  Temperature: 22.00°C 71.60°F  Heat index: 21.61°C 70.90°F
1
### sendGoogleGET() ###
Sending GET...
Request Status - HTTP_ERROR_API: -2
Humidity: 52.20%  Temperature: 22.00°C 71.60°F  Heat index: 21.62°C 70.91°F
1
Sending GET...
Relevant Code:
main code file
#include <SPI.h>
#include <NTPClient.h>
#include <ArduinoHttpClient.h>
#include "DHT.h"
#include "config.h"
#include "util.h"
#include "wifi.h"
DHT dht(DHTPIN, DHTTYPE);
// NTP Client
WiFiUDP ntpUDP;
NTPClient ntpClient(ntpUDP);
// WiFi Client
WiFiClient wifiClient;
// HTTP Clients
HttpClient googleAPI = HttpClient(wifiClient, "http://google.ch", 80);
// HTTP Requests
void sendGoogleGET() {
  Serial.println(googleAPI);
  Serial.println("### sendGoogleGET() ###");
  // Submit POST request
  Serial.println("Sending GET...");
  googleAPI.get("/");
  int statusCodeG = googleAPI.responseStatusCode();
  String responseG = googleAPI.responseBody();
  printHTTPRequestStatus(statusCodeG);
  Serial.println(responseG);
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  Serial.println(F("Attempting Wifi Connection!"));
  setupWiFi();
  Serial.println(F("Initialize NTPClient to get time"));
  ntpClient.begin();
  Serial.println(F("DHTxx test!"));
  dht.begin();
  if (wifiClient.available()) {
    char c = wifiClient.read();
    Serial.print(c);
  if (!wifiClient.connected()) {
    Serial.println("!wifiClient.connected()");
    wifiClient.stop();
    for(;;)
  // Time Server - This one works!
  while (!ntpClient.update()) {
    yield();
    ntpClient.forceUpdate();
  unsigned long ts = ntpClient.getEpochTime();
  // *** Here  I perform sensor readings...)
  sendGoogleGET();
  // Pause
  delay(2000);
wifi.h
void setupWiFi() {
  if (WiFi.status() == WL_NO_MODULE) {
    Serial.println("Communication with WiFi module failed!");
    while (true); // don't continue
  Serial.println(WIFI_FIRMWARE_LATEST_VERSION);
  String fv = WiFi.firmwareVersion();
  if (fv < WIFI_FIRMWARE_LATEST_VERSION) {
    Serial.println("Please upgrade the firmware");
  listNetworks();
  printWiFiStatus(status);
  printWiFiStatus(WiFi.status());
  while (status != WL_CONNECTED) {
    Serial.print("Attempting to connect to WPA SSID: ");
    Serial.println(ssid);
    // Connect to WPA/WPA2 network:
    status = WiFi.begin(ssid, password);
    delay(10000);
  Serial.println("You're connected to the network");
  printWifiData();
  printCurrentNet();
let the HttpClient object read the data from wifiClient. remove all code accessing wifiClient
Thanks for you answer!
Not sure what exactly I am supposed to change. Aren't I letting the HttpClient object read the data from wifiClient by passing it at the beginning of my main code file? And where in my code am I accessing wifiClient and should not do it?
// WiFi Client
// HTTP Clients
see what you do in loop() as first
Aren’t I supposed to check the WiFi status? I tried commenting out that part but did not make a difference. Would really appreciate some context/more details in your answer, thanks!
    Serial.print(c);
try to change
to
HttpClient googleAPI = HttpClient(wifiClient, "google.ch", 80);
Yes, thanks, that was exactly it! :partying_face: Looks like HttpClient doesn't like the protocol then, makes sense when I think about it, as the Port is defined in the third parameter...
