HttpClient::responseStatusCode() returns -3
I'm using ESP32 with ENC28J60 ethernet connector.
I'm trying to retrieve HTTP get from server, but after a few response, http.responseStatusCode() always returns -3, TIMEOUT.
Please let me know how to fix it. Any answer would be greatly appreciated.
#include <WiFi.h>
#include <HttpClient.h>
#include <EthernetENC.h>
String sChipID;
char cChipID[40];
byte mac[6];
bool isConnected = false;
// Number of milliseconds to wait without receiving any data before we give up
const int kNetworkTimeout = 30*1000;
// Number of milliseconds to wait if no data is available before trying again
const int kNetworkDelay = 100;
  uint8_t chipid[6] = "";
  int ethernetresult;
  WiFi.macAddress(chipid);
  sprintf(cChipID, "%02X%02X%02X%02X%02X%02X", chipid[5], chipid[4], chipid[3], chipid[2], chipid[1], chipid[0]);
  memcpy(mac, chipid, 6);
  Serial.println("Trying DHCP...");
  ethernetresult = Ethernet.begin(mac);// Use DHCP
  if( ethernetresult != 0 )
    Serial.print("Local IP : ");
    Serial.println(Ethernet.localIP());
    Serial.print("Subnet Mask : ");
    Serial.println(Ethernet.subnetMask());
    Serial.print("Gateway IP : ");
    Serial.println(Ethernet.gatewayIP());
    Serial.print("DNS Server : ");
    Serial.println(Ethernet.dnsServerIP());
    isConnected = true;
    Serial.println("DHCP not available.");
  EthernetClient eclient;
  HttpClient http(eclient);
  String response = "";
  String httpServer = "192.168.10.250";
  String httpURI = "/webjob/";
  String http_request = "broker_wakeup.jsp?sn=Q123A-DA305-0008";
  uint16_t httpPort = 8080;
  int err;
  int curmillis;
  bool ret = false;
  err = http.get(httpServer.c_str(), httpPort, (httpURI + http_request).c_str());
  if( err == 0 )
    Serial.println("startedRequest ok");
    err = http.responseStatusCode();
    if (err >= 0)
      Serial.print("Got status code: ");
      Serial.println(err);
      // Usually you'd check that the response code is 200 or a
      // similar "success" code (200-299) before carrying on,
      // but we'll print out whatever response we get
      err = http.skipResponseHeaders();
      if (err >= 0)
        int bodyLen = http.contentLength();
        Serial.print("Response length: ");
        Serial.println(bodyLen);
        // Now we've got to the body, so we can print it out
        unsigned long timeoutStart = millis();
        char c;
        // Whilst we haven't timed out & haven't reached the end of the body
        while ( (http.connected() || http.available()) &&
               ((millis() - timeoutStart) < kNetworkTimeout) &&
               (bodyLen > 0) )
          if (http.available())
            c = http.read();
            response += c;
            bodyLen--;
            // We read something, reset the timeout counter
            // We haven't got any data, so let's pause to allow some to
            // arrive
            delay(kNetworkDelay);
        if( bodyLen == 0 )
          ret = true;
        Serial.print("Failed to skip response headers: ");
      Serial.print("Getting response failed: ");
    Serial.print("Connect failed: ");
  http.stop();
  if( err <= 0 )
  if( ret )
    Serial.println(response);
Output:
Trying DHCP...
16:44:13.495 -> Local IP : 192.168.10.64
16:44:13.541 -> Subnet Mask : 255.255.255.0
16:44:13.541 -> Gateway IP : 192.168.10.1
16:44:13.587 -> DNS Server : 203.248.252.2
16:44:14.011 -> startedRequest ok
16:44:17.029 -> Got status code: 200
16:44:17.075 -> Response length: 44
16:44:17.075 ->
16:44:17.075 ->
16:44:17.075 -> INTERVAL=1
16:44:17.075 -> TIME=2022-12-12 16:44:14
16:44:17.121 ->
16:44:17.121 ->
16:44:18.255 -> startedRequest ok
16:44:21.234 -> Got status code: 200
16:44:21.281 -> Response length: 44
16:44:21.281 ->
16:44:21.281 ->
16:44:21.281 -> INTERVAL=1
16:44:21.328 -> TIME=2022-12-12 16:44:18
16:44:21.328 ->
16:44:21.328 ->
16:44:22.460 -> startedRequest ok
16:44:25.461 -> Got status code: 200
16:44:25.461 -> Response length: 44
16:44:25.507 ->
16:44:25.507 ->
16:44:25.507 -> INTERVAL=1
16:44:25.507 -> TIME=2022-12-12 16:44:22
16:44:25.554 ->
16:44:25.554 ->
16:44:26.683 -> startedRequest ok
16:44:29.655 -> Got status code: 200
16:44:29.701 -> Response length: 44
16:44:29.701 ->
16:44:29.701 ->
16:44:29.701 -> INTERVAL=1
16:44:29.701 -> TIME=2022-12-12 16:44:26
16:44:29.748 ->
16:44:29.748 ->
16:44:30.868 -> startedRequest ok
16:45:00.886 -> Getting response failed: -3
16:45:02.066 -> startedRequest ok
16:45:32.077 -> Getting response failed: -3
16:45:33.250 -> startedRequest ok
ESP32 has a fully equipped WiFi stack in a board, why do not use it and has troubles with not quite stable ENC28J60 module, ?
Using ethernet is a customer requirement. :slight_smile:
Could the problem be on the server? If it runs out of some resource it might stop responding, causing a timeout.
I've tried the same address with WIFI in same ESP32. There was no problem.
I once read that the ENC28J60 module has a problem - it does not clear itself the sockets after the connection is closed. And there are only 8 sockets, if I am not mistaken... so the sockets end very quickly. Your case is like this
Wow! That's a great hint.
Your advise was essential!
I've coded a subclass of HttpClient, which sends "Keep-Alive" instead of "close" for connection header and now it works well.
Thank you very much.
// Class to simplify HTTP fetching on Arduino
// (c) Copyright MCQN Ltd. 2010-2012
// Released under Apache License, version 2.0
#ifndef HttpClientKA_h
#define HttpClientKA_h
#define HTTP_HEADER_KAOPTION     "Keep-Alive"
class HttpClientKA : public HttpClient
public:
    HttpClientKA(Client& aClient): HttpClient(aClient) {}
    /** Connect to the server and start to send a GET request with keep alive
      @param aServerName  Name of the server being connected to.  If NULL, the
                          "Host" header line won't be sent
      @param aServerPort  Port to connect to on the server
      @param aURLPath     Url to request
      @param aUserAgent   User-Agent string to send.  If NULL the default
                          user-agent kUserAgent will be sent
      @return 0 if successful, else error
    int getKA(const char* aServerName, uint16_t aServerPort, const char* aURLPath,
              const char* aUserAgent = NULL)
      { return startRequestKA(aServerName, aServerPort, aURLPath, HTTP_METHOD_GET, aUserAgent); }
protected:
  int startRequestKA(const char* aServerName, uint16_t aServerPort, const char* aURLPath, const char* aHttpMethod, const char* aUserAgent);
  int sendInitialHeadersKA(const char* aServerName, IPAddress aServerIP, uint16_t aPort, const char* aURLPath, const char* aHttpMethod, const char* aUserAgent);
#endif
#include "HttpClientKA.h"
int HttpClientKA::startRequestKA(const char* aServerName, uint16_t aServerPort, const char* aURLPath, const char* aHttpMethod, const char* aUserAgent)
    tHttpState initialState = iState;
    if ((eIdle != iState) && (eRequestStarted != iState))
        return HTTP_ERROR_API;
    if( !iClient->connected() )
#ifdef PROXY_ENABLED
      if (iProxyPort)
          if (!iClient->connect(iProxyAddress, iProxyPort) > 0)
#ifdef LOGGING
              Serial.println("Proxy connection failed");
#endif
              return HTTP_ERROR_CONNECTION_FAILED;
#endif
          if (!iClient->connect(aServerName, aServerPort) > 0)
#ifdef LOGGING
            Serial.println("Connection failed");
#endif
    // Now we're connected, send the first part of the request
    int ret = sendInitialHeadersKA(aServerName, IPAddress(0,0,0,0), aServerPort, aURLPath, aHttpMethod, aUserAgent);
    if ((initialState == eIdle) && (HTTP_SUCCESS == ret))
        // This was a simple version of the API, so terminate the headers now
        finishHeaders();
    // else we'll call it in endRequest or in the first call to print, etc.
    return ret;
int HttpClientKA::sendInitialHeadersKA(const char* aServerName, IPAddress aServerIP, uint16_t aPort, const char* aURLPath, const char* aHttpMethod, const char* aUserAgent)
#ifdef LOGGING
    Serial.println("Connected");
#endif
    // Send the HTTP command, i.e. "GET /somepath/ HTTP/1.0"
    iClient->print(aHttpMethod);
    iClient->print(" ");
    if (iProxyPort)
      // We're going through a proxy, send a full URL
      iClient->print("http://");
      if (aServerName)
        // We've got a server name, so use it
        iClient->print(aServerName);
        // We'll have to use the IP address
        iClient->print(aServerIP);
      if (aPort != kHttpPort)
        iClient->print(":");
        iClient->print(aPort);
#endif
    iClient->print(aURLPath);
    iClient->println(" HTTP/1.1");
    // The host header, if required
    if (aServerName)
        iClient->print("Host: ");
        iClient->println();
    // And user-agent string
    if (aUserAgent)
        sendHeader(HTTP_HEADER_USER_AGENT, aUserAgent);
        sendHeader(HTTP_HEADER_USER_AGENT, kUserAgent);
    // We don't support persistent connections, so tell the server to
    // close this connection after we're done
    sendHeader(HTTP_HEADER_CONNECTION, "Keep-Alive");
    sendHeader(HTTP_HEADER_KAOPTION, "timeout=30, max=0");
    isConnected = true;
    // Everything has gone well
    iState = eRequestStarted;
    return HTTP_SUCCESS;
