HTTPS in Arduino Pro Mini
Is it possible to make web client, that used https protocol in Arduino Pro Mini?
Vitaliy_Livnov:
No. The Arduino doesn't have enough memory or speed to support https.
Thank you.
PaulS:
Can we modificate Arduino to work with https? Or we must use another boards for it?
Vitaliy_Livnov:
How would you modify the Arduino to increase the processing speed and memory?
Vitaliy_Livnov:
Can you multiply the 2KB RAM of the Atmega328 by 100 or more, so that you have a minimum of 200 KB RAM at least, instead of just 2 kilobytes?
If not, you better try to use strong encryption with systems that have a lot more of RAM (megabytes or gigabytes), such as perhaps a Raspberry Pi.
Not sure what you trying to do but if you want to see your arduino data/sensors thru internet you can try
reading the data from arduino and create your https with another software sending them thru internet.
Thanks for all!
