Hello guys!
Im working on a webserver with my esp32-s2-wrover-i and most of my functions are working with http. now i would like to add https connection and i faced some problems. I saw an external library which can be found at the library manager under the name: "esp32_https_server" and "esp32_https_server_compat". the compat version is a wrapper so that you can use the same API as the default webserver.h library.
If I compile the Example HelloServer i get the following error message:
Arduino: 1.8.17 Hourly Build 2021/09/06 02:33 (Windows 10), Board: "ESP32S2 Dev Module, Disabled, Disabled, Disabled, UART0, Disabled, Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS), 240MHz (WiFi), DIO, 40MHz, 4MB (32Mb), 115200, None"
Mehrere Bibliotheken wurden für "ESPWebServer.hpp" gefunden
In file included from C:\Users\Student\Documents\Arduino\libraries\esp32_https_server-1.0.0\src/HTTPServer.hpp:23,
Benutzt: C:\Users\Student\Documents\Arduino\libraries\esp32_https_server_compat
Nicht benutzt: C:\Users\Student\Desktop\arduino-nightly\libraries\esp32_https_server_compat-1.0.0
Mehrere Bibliotheken wurden für "HTTPServer.hpp" gefunden
from C:\Users\Student\Documents\Arduino\libraries\esp32_https_server_compat\src/ESPWebServer.hpp:10,
Benutzt: C:\Users\Student\Documents\Arduino\libraries\esp32_https_server-1.0.0
Nicht benutzt: C:\Users\Student\Desktop\arduino-nightly\libraries\esp32_https_server-1.0.0
Mehrere Bibliotheken wurden für "WiFi.h" gefunden
from C:\Users\Student\Documents\Arduino\libraries\esp32_https_server_compat\examples\HelloServer\HelloServer.ino:8:
Benutzt: C:\Users\Student\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.0\libraries\WiFi
C:\Users\Student\Documents\Arduino\libraries\esp32_https_server-1.0.0\src/HTTPConnection.hpp:9:10: fatal error: hwcrypto/sha.h: No such file or directory
Nicht benutzt: C:\Users\Student\Desktop\arduino-nightly\libraries\WiFi
#include <hwcrypto/sha.h>
compilation terminated.
exit status 1
Fehler beim Kompilieren für das Board ESP32S2 Dev Module.
its in german. hopefully its still understandable. it basically tells me, that an error occured for the board ESP32S2 Dev Module.
did anyone inlcuded this library and can share some experience and does the problem lay on my side and not on the library side?
thanks in advance!
example code:
#include <WiFi.h>
#include <WiFiClient.h>
#include <ESPmDNS.h>
#ifdef USE_DEFAULT_WEBSERVER
#include <WebServer.h>
typedef WebServer ESPWebServer;
#else
#include <ESPWebServer.hpp>
#endif
const char* ssid = "........";
const char* password = "........";
ESPWebServer server(80);
const int led = 13;
void handleRoot() {
digitalWrite(led, 1);
server.send(200, "text/plain", "hello from esp32! See /form and /inline too!");
digitalWrite(led, 0);
void handleForm() {
String line = server.arg("line");
Serial.print("line: ");
Serial.println(line);
String multi = server.arg("multi");
Serial.print("multi: ");
Serial.println(multi);
line.toLowerCase();
multi.toUpperCase();
String rv;
rv = "<html><head><title>Test Form</title></head><body>";
rv += "<p>Single line will be converted to lowercase, multi line to uppercase. You can submit the form with three different methods.</p>";
rv += "<h2>Form using GET</h2>";
rv += "<form method='GET'>";
rv += "Single line:<br><input name='line' value='" + line + "'><br>";
rv += "Multi line:<br><textarea name='multi' rows='8' cols='40'>" + multi + "</textarea><br>";
rv += "<input type='submit' value='upper+lower case'>";
rv += "</form>";
rv += "<h2>Form using POST urlencoded</h2>";
rv += "<form method='POST' action='/form'>";
rv += "</form>";
rv += "<h2>Form using POST with multipart</h2>";
rv += "<form method='POST' enctype=\"multipart/form-data\">";
rv += "</form></body></html>";
server.send(200, "text/html", rv);
void handleNotFound() {
String message = "File Not Found\n\n";
message += "URI: ";
message += server.uri();
message += "\nMethod: ";
message += (server.method() == HTTP_GET) ? "GET" : "POST";
message += "\nArguments: ";
message += server.args();
message += "\n";
for (uint8_t i = 0; i < server.args(); i++) {
message += " " + server.argName(i) + ": " + server.arg(i) + "\n";
server.send(404, "text/plain", message);
void setup(void) {
pinMode(led, OUTPUT);
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
Serial.println("");
// Wait for connection
Serial.print(".");
Serial.println("");
Serial.print("Connected to ");
Serial.println(ssid);
Serial.print("IP address: ");
if (MDNS.begin("esp32")) {
Serial.println("MDNS responder started");
server.on("/", handleRoot);
server.on("/form", handleForm);
server.on("/form", HTTP_POST, handleForm);
server.on("/inline", []() {
server.send(200, "text/plain", "this works as well");
server.onNotFound(handleNotFound);
server.begin();
Serial.println("HTTP server started");
void loop(void) {
server.handleClient();
followup question. Is there a easier way to implement https with no external library?
