HTTPSReDirect - Time of day to Arduino Program
IMost of the functions I need are working.
My basic program produces data which will be put to a Google spreadsheet.
I have been following a "cookbook" program from the website
This uses the function/library HTTPSReDirect and a Google script and the Arduino code.
My last problem is how to get the current time of day (and date) when a run is finished, to associate it with the results. (I can put these at the top of the sheet, but I need it for each line.)
I include here the entire program as well as the Google script here. It MAY be of some help.
I suspect that my solution is just a line or two, but I have already spent too much time trying to understand things. Any help will be appreciated. (I have truncated a lot to fit within the 9000 char. limit.)
  • Matt
Google Web App Script:
// BB_Sterilizer_101_19Mar20  -  Google App Script
  var SS = SpreadsheetApp.openById('1xl22gxR-V3r28mesihZJiPkojStyKqch1Yu1PijdSss');
  var sheet = SS.getSheetByName('Data_2020');      // Above changed - 19 Mar 2020
  var str = "";
function doPost(e) {
  var parsedData;
  var result = {};
  try {
    parsedData = JSON.parse(e.postData.contents);
  catch(f){
    return ContentService.createTextOutput("Error in parsing request body: " + f.message);
  if (parsedData !== undefined){
      var flag = parsedData.format;
      if (flag === undefined){
      flag = 0;
    switch (parsedData.command) {
      case "appendRow":
         var tmp = SS.getSheetByName(parsedData.sheet_name);
         var nextFreeRow = tmp.getLastRow() + 1;
         var dataArr = parsedData.values.split(",");
         tmp.appendRow(dataArr);
         str = "Success";
         SpreadsheetApp.flush();
        return ContentService.createTextOutput(str);
    else{
    return ContentService.createTextOutput("Error! Request body empty or in incorrect format.");
function doGet(e){
  var val = e.parameter.value;
  var cal = e.parameter.cal;
  var read = e.parameter.read;
  if (cal !== undefined){
    return ContentService.createTextOutput(GetEventsOneWeek());
  if (read !== undefined){
      var now = Utilities.formatDate(new Date(), "EDT", "yyyy-MM-dd'T'hh:mm a'Z'").slice(11,19);
    sheet.getRange('D1').setValue(now);  // mcb
    sheet.getRange('C1').setValue(count);
    return ContentService.createTextOutput(sheet.getRange('A1').getValue());
  if (e.parameter.value === undefined)
    return ContentService.createTextOutput("No value passed as argument to script Url.");
  var range = sheet.getRange('A1');
  var retval = range.setValue(val).getValue();
    var datenow = Utilities.formatDate(new Date(), "EST", "yyyy-MM-dd'T'hh:mm a'Z'").slice(0,10);  // mcb
    var timenow = Utilities.formatDate(new Date(), "EST", "yyyy-MM-dd'T'hh:mm a'Z'").slice(11,19);  // mcb
  sheet.getRange('C1').setValue(datenow);
  sheet.getRange('D1').setValue(timenow);
  sheet.getRange('B1').setValue("Sterilizer:");
  if (retval == e.parameter.value)
    return ContentService.createTextOutput("Successfully wrote: " + e.parameter.value + "\ninto spreadsheet.");
    return ContentService.createTextOutput("Unable to write into spreadsheet.\nCheck authentication and make sure the cursor is not on cell 'A1'." + retval + ' ' + e.parameter.value);
function GetEventsOneWeek(){
  //Deleted - not used
  //Logger.log(str);
  return str;
Arduino NodeMCU 8266 Code:
//AA_Sterilizer_101_19Mar20
#include <ESP8266WiFi.h>
#include "HTTPSRedirect.h"
#include "DebugMacros.h"
float x ;
float h;
float t;
String sheetHumid = "";
String sheetTemp = "";
String sheetData_2020 = "";
String sheetXXX  = "";
String sheetYYY  = "";
String sheetZZZ  = "";
String datastring = "";
const char* ssid = "A47FB0";                //replace with our wifi ssid
const char* password = "96880104";         //replace with your wifi password
const char* host = "script.google.com";
String url = String("/macros/s/") + GScriptId + "/exec?value=Steri.";  // Write Teperature to Google Spreadsheet at cell A1
// Fetch Google Calendar events for 1 week ahead
  String url2 = String("/macros/s/") + GScriptId + "/exec?cal";  // Write to Cell A continuosly
String payload_base =  "{\"command\": \"appendRow\", \
                    \"sheet_name\": \"Data_2020\", \
                       \"values\": ";
String payload = "";
String  state = "   ";  // This compiled. Room for three characters??
HTTPSRedirect* client = nullptr;
    delay(100);
  Serial.print("Connecting to wifi: ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  Serial.println("IP address: ");
  // Use HTTPSRedirect class to create a new TLS connection
  client = new HTTPSRedirect(httpsPort);
  client->setInsecure();
  client->setPrintResponseBody(true);
  client->setContentTypeHeader("application/json");
  Serial.print("Connecting to ");
  Serial.println(host);          //try to connect with "script.google.com"
  // Try to connect for a maximum of 5 times then exit
  bool flag = false;
  for (int i = 0; i < 5; i++) {
    int retval = client->connect(host, httpsPort);
    if (retval == 1) {
      flag = true;
      Serial.println("Connection failed. Retrying...");
  if (!flag) {
    Serial.print("Could not connect to server: ");
    Serial.println("Exiting...");
    return;
// Finish setup() function in 1 second since it will fire watchdog timer and will reset the chip.
//So avoid too many requests in setup()
  Serial.println("\nWrite into cell 'A1'");
  Serial.println("------>");
  // fetch spreadsheet data
    client->GET(url, host);
 // client->GET(url2, host);
  Serial.print(client->GET(url, host));
//Serial.print(client->GET(url2, host));
  Serial.println("\nGET: Fetch Google Calendar Data:");
  delete client;
  client = nullptr;
}  // End of setup
  static int error_count = 0;
  static int connect_count = 0;
  const unsigned int MAX_CONNECT = 20;
  static bool flag = false;
int T;
int H;
Serial.println("Start to assemble for sheet");
// orig:  payload = payload_base + "\"" + sheetData-2020 + "," + sheetXXX ;
 payload = payload_base + "\"" ;
// payload = payload_base ;
 for (int  j = 0; j < 20; j++)
  T = (( 10 + j) * 10 + 100);  // Actually will be temperaure.
  H = (j % 3) + 1; //  H is used here ONLY for phony state value!
    state = " WU";
       CDC[j] = String( T ) + " " + state; // T = temperature
String Timedate = "";
payload = payload +  ","   + CDC[j] ;
  Serial.print(payload);
    }  // end of for loop
 payload = payload + "\"}";  // to finish it up.
    Serial.println("End of For Loop");
Serial.println("Payload is complete here");
  if (!flag) {
    flag = true;
  if (client != nullptr) {
    if (!client->connected()) {
      client->POST(url2, host, payload, false);
      Serial.print("Sent : ");  Serial.println("Temp and Humid");
  else {
      error_count = 5;
  if (connect_count > MAX_CONNECT) {
    connect_count = 0;
    flag = false;
    delete client;
    return;
  if (client->POST(url2, host, payload)) {
  else {
    ++error_count;
  if (error_count > 3) {
    delete client;
    client = nullptr;
    ESP.deepSleep(0);
  delay(3000);
}  // loopend
Are any options of interest to you? Do you want to get it from an HTTP header or NTP server?
Does this script actually work the way you want it to apart from the missing time? If you can post the link to the original working example you started from it would be helpful.
Assuming it does I would ask the google server for the time rather than try to derive it on the ESP8266.
      case "appendRow":
         dataArr.unshift(now);  // put time in first column.
         str = "Success";
And add it to the row along with the data.
"Assuming it does I would ask the google server for the time rather than try to derive it on the ESP8266."
That's exactly what I'd like to do! (I used the NTP method separately in a different program.)
I can get it using the "now" function, and display the time & date on the first line of the sheet as a part of the "onOpen" function. My problem is that I want to be able to manipulate it (actually just format the time & date) in displaying the results of my calculations - done elsewhere in a program function not included here.
Incidentally, the website from which I started with this program is:
aarg said:
"Are any options of interest to you? Do you want to get it from an HTTP header or NTP server?"
I would prefer to get the time from the Google server to which I connect in another part of the program (not necessarily on the next line).
I can do this in the associated Google web app, where the function doGet(e) produces the time and puts it onto the first line of the Google Sheet.
My problem is that I want to save this as a variable, which I can then use in an expression and put it somewhere else.
This should be simple - but since I don't really understand all of how the sample program works, I have not been able to do it.
Someone familiar with these things should find it simple to do!
Hello rw950431
I realized that putting the date and time into the first two columns, as you suggest, will be sufficient to solve my problem..
HOWEVER, when I implement the code you suggested,
case "appendRow":
I get the combined date and time string from the "now" function in the first column.
I've tried a number of simple statements, but have not been able to split this up, so as to put the date and the time separately into the first two columns of each appended row. There must be something simple that I am missing here.
Can you please help me out?
  • Matt
