Huge data, 2inputs to one output conversion
Hello,
I have two inputs (numbers), and output(one number) on LCD,
Input one has numbers 0-100,
Input two has numbers 0-380,
The output number is a data I have.
say input one is 50. input two is 300, the corresponding data output is 453.
I was going to use array, but that is going to be like array[100]={}; which didn't work.
And if i use 2d array, there isn't any space.
Can someone please tell me a simpler way to solve the issue?
I was thinking of a mathematical formula, but the output data is not linear.
So you're looking at 101 x 381 x 2 bytes = 76292 bytes of data.
Which Arduino board are you using?
I'm using arduino Mega
cpp333:
.. which has 8192 bytes of RAM
AWOL:
So you must put the table in PROGMEM. The Arduino Meah 2560 has 256kb of PROGMEM so 76kB should not be a problem.
What is the range of output values?
Did the numbers come from some formula that you could use instead of a lookup table?
Is there not an algorithm which defines the output as a function of the 2 inputs?
Bit slower, but far less space consuming.
Allan
Range of output values are 0-255. No formula for the numbers, experimental values.
The PROGMEM works, but 101 x 381 is too large, I had to split it into two.
Thank you
No algorithm relates to input output values.
If the output range is 0-255 use 'unsigned char' and your array will only be 38,481 bytes.
so that's why I assumed 2 bytes would be necessary for each output item. I guess 453 was a typo?
well, I was trying to show an example.
Thanks for the help :slight_smile:
