Hi
I used this Original-Sketch to get the NTP-Time:
* Time_NTP.pde
* Example showing time sync to NTP time source
* Also shows how to handle DST automatically.
* This sketch uses the EtherCard library:
* http://jeelabs.org/pub/docs/ethercard/
#include <TimeLib.h>
#include <EtherCard.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
// NTP Server
const char timeServer[] PROGMEM = "pool.ntp.org";
const int utcOffset = 1; // Central European Time
//const int utcOffset = -5; // Eastern Standard Time (USA)
//const int utcOffset = -4; // Eastern Daylight Time (USA)
//const int utcOffset = -8; // Pacific Standard Time (USA)
//const int utcOffset = -7; // Pacific Daylight Time (USA)
// Packet buffer, must be big enough to packet and payload
#define BUFFER_SIZE 550
byte Ethernet::buffer[BUFFER_SIZE];
const unsigned int remotePort = 123;
while (!Serial) // Needed for Leonardo only
delay(250);
Serial.println("TimeNTP_ENC28J60 Example");
if (ether.begin(BUFFER_SIZE, mac) == 0) {
// no point in carrying on, so do nothing forevermore:
while (1) {
Serial.println("Failed to access Ethernet controller");
delay(10000);
if (!ether.dhcpSetup()) {
while (1) {
Serial.println("Failed to configure Ethernet using DHCP");
delay(10000);
ether.printIp("IP number assigned by DHCP is ", ether.myip);
Serial.println("waiting for sync");
//setSyncProvider(getNtpTime); // Use this for GMT time
setSyncProvider(getDstCorrectedTime); // Use this for local, DST-corrected time
time_t prevDisplay = 0; // when the digital clock was displayed
if (timeStatus() != timeNotSet) {
if (now() != prevDisplay) { //update the display only if time has changed
prevDisplay = now();
digitalClockDisplay();
void digitalClockDisplay(){
// digital clock display of the time
Serial.print(hour());
printDigits(minute());
printDigits(second());
Serial.print(" ");
Serial.print(day());
Serial.print(" ");
Serial.print(month());
Serial.print(" ");
Serial.print(year());
void printDigits(int digits){
// utility for digital clock display: prints preceding colon and leading 0
Serial.print(":");
if(digits < 10)
Serial.print('0');
Serial.print(digits);
/*-------- NTP code ----------*/
// SyncProvider that returns UTC time
time_t getNtpTime()
// Send request
Serial.println("Transmit NTP Request");
if (!ether.dnsLookup(timeServer)) {
Serial.println("DNS failed");
return 0; // return 0 if unable to get the time
//ether.printIp("SRV: ", ether.hisip);
ether.ntpRequest(ether.hisip, remotePort);
// Wait for reply
uint32_t beginWait = millis();
while (millis() - beginWait < 1500) {
word len = ether.packetReceive();
ether.packetLoop(len);
unsigned long secsSince1900 = 0L;
if (len > 0 && ether.ntpProcessAnswer(&secsSince1900, remotePort)) {
Serial.println("Receive NTP Response");
return secsSince1900 - 2208988800UL;
Serial.println("No NTP Response :-(");
return 0;
/* Alternative SyncProvider that automatically handles Daylight Saving Time (DST) periods,
* at least in Europe, see below.
time_t getDstCorrectedTime (void) {
time_t t = getNtpTime ();
if (t > 0) {
TimeElements tm;
breakTime (t, tm);
t += (utcOffset + dstOffset (tm.Day, tm.Month, tm.Year + 1970, tm.Hour)) * SECS_PER_HOUR;
return t;
/* This function returns the DST offset for the current UTC time.
* This is valid for the EU, for other places see
* http://www.webexhibits.org/daylightsaving/i.html
* Results have been checked for 2012-2030 (but should work since
* 1996 to 2099) against the following references:
* - http://www.uniquevisitor.it/magazine/ora-legale-italia.php
* - http://www.calendario-365.it/ora-legale-orario-invernale.html
byte dstOffset (byte d, byte m, unsigned int y, byte h) {
// Day in March that DST starts on, at 1 am
byte dstOn = (31 - (5 * y / 4 + 4) % 7);
// Day in October that DST ends on, at 2 am
byte dstOff = (31 - (5 * y / 4 + 1) % 7);
if ((m > 3 && m < 10) ||
(m == 3 && (d > dstOn || (d == dstOn && h >= 1))) ||
(m == 10 && (d < dstOff || (d == dstOff && h <= 1))))
return 1;
return 0;
This Sketch works perfectly and I put it into my Sketch:
//#include <Wire.h>
//#include <SPI.h>
#include <DS3231.h>
DS3231 clock;
RTCDateTime dt;
//String outdate = "";
const unsigned int DISPLAY_TIMEOUT = 8000;
bool displayIsOn;
unsigned long displayTimeout;
#include <SoftwareSerial.h>
SoftwareSerial BTserial(2, 3);
// BTconnected will = false when not connected and true when connected
boolean BTconnected = false;
// connect the STATE pin to Arduino pin D4
const byte BTpin = 4;
#include <Adafruit_GFX.h>
#include <Adafruit_ILI9341.h>
// BLK an 3,3V VCC
#define TFT_CLK 13
#define TFT_MISO 12
#define TFT_MOSI 11
#define TFT_DC 5
#define TFT_CS -1 //erforderlich!
#define TFT_RST 8
#define TFT_BLK 9
Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC, TFT_RST);
// NTP Server
boolean IPconnected = true;
//unsigned long currentMillis = 0;
//unsigned long previousMillis = 0;
const long interval = 3000;
//int Blight = 0;
byte trigger = 7; //Trigger-Pin des Ultraschallsensors an Pin7 des Arduino-Boards
byte echo = 6; // Echo-Pim des Ultraschallsensors an Pin6 des Arduino-Boards
long dauer = 0; // Das Wort dauer ist jetzt eine Variable, unter der die Zeit gespeichert wird, die eine Schallwelle bis zur Reflektion und zurück benötigt. Startwert ist hier 0.
long entfernung = 0; // Das Wort „entfernung“ ist jetzt die variable, unter der die berechnete Entfernung gespeichert wird. Info: Anstelle von „int“ steht hier vor den beiden Variablen „long“. Das hat den Vorteil, dass eine größere Zahl gespeichert werden kann. Nachteil: Die Variable benötigt mehr Platz im Speicher.
byte zl1 = 0;
byte zl2 = 31;
byte zl3 = 62;
byte zl4 = 93;
byte zl5 = 124;
byte zl6 = 155;
byte zl7 = 186;
byte zl8 = 217;
clock.begin();
// Nur zum Setzen der Zeit einmal freisetzen
// Manual (YYYY, MM, DD, HH, II, SS
//clock.setDateTime(2024, 1, 20, 13, 23, 00);
//Serial.begin(9600);
tft.begin();
tft.setRotation(1);
tft.fillScreen(ILI9341_BLACK);
tft.setTextSize(3);
tft.setTextColor(ILI9341_WHITE, ILI9341_BLACK);
tft.setCursor(0, zl3);
tft.print(F("Balkon:"));
tft.setCursor(0, zl5);
tft.print(F("Innen:"));
if (digitalRead(BTpin) == HIGH) {
analogWrite(TFT_BLK, 0);
displayIsOn = false;
analogWrite(TFT_BLK, 200);
displayIsOn = true;
tft.setTextColor(ILI9341_RED, ILI9341_BLACK);
tft.setCursor(0, zl8);
tft.print(F("Warte auf IP"));
IPconnected = false;
if (IPconnected = true) {
char* myTemplate = "";
char resultip[64] = {};
myTemplate = "%d:%d:%d:%d";
sprintf(resultip, myTemplate, ether.myip[0], ether.myip[1], ether.myip[2], ether.myip[3]);
//ether.printIp("IP number assigned by DHCP is ", ether.myip);
tft.setCursor(0, zl6);
tft.print(resultip);
//digitalClockDisplay();
tft.print("No IP ");
BTserial.begin(38400);
pinMode(trigger, OUTPUT); // Trigger-Pin ist ein Ausgang
pinMode(echo, INPUT); // Echo-Pin ist ein Eingang
digitalWrite(trigger, LOW);
delay(5);
digitalWrite(trigger, HIGH); //Jetzt sendet man eine Ultraschallwelle los.
delay(10); //Dieser „Ton“ erklingt für 10 Millisekunden.
digitalWrite(trigger, LOW); //Dann wird der „Ton“ abgeschaltet.
dauer = pulseIn(echo, HIGH); //Mit dem Befehl „pulseIn“ zählt der Mikrokontroller die Zeit in Mikrosekunden, bis der Schall zum Ultraschallsensor zurückkehrt.
entfernung = (dauer / 2) * 0.03432; //Nun berechnet man die Entfernung in Zentimetern. Man teilt zunächst die Zeit durch zwei (Weil man ja nur eine Strecke berechnen möchte und nicht die Strecke hin- und zurück). Den Wert multipliziert man mit der Schallgeschwindigkeit in der Einheit Zentimeter/Mikrosekunde und erhält dann den Wert in Zentimetern.
//if (digitalRead(BTpin) == HIGH) { displayBacklight(); }
displayBacklight();
dt = clock.getDateTime();
char timebuffer[8];
char datebuffer[5];
sprintf(datebuffer, "%02u.%02u", dt.day, dt.month);
tft.setTextColor(ILI9341_PINK, ILI9341_BLACK);
tft.setCursor(0, zl1);
tft.print(datebuffer);
tft.print(".");
tft.print(String(dt.year).substring(2, 4));
sprintf(timebuffer, "%02u:%02u:%02u", dt.hour, dt.minute, dt.second);
tft.print(" " + String(timebuffer));
tft.setCursor(0, zl2);
switch (dt.dayOfWeek) {
case 1: tft.print(F("Montag ")); break;
case 2: tft.print(F("Dienstag ")); break;
case 3: tft.print(F("Mittwoch ")); break;
case 4: tft.print(F("Donnerstag ")); break;
case 5: tft.print(F("Freitag ")); break;
case 6: tft.print(F("Samstag ")); break;
case 7: tft.print(F("Sonntag ")); break;
default: tft.print(F("Wochentag ?"));
tft.setTextColor(ILI9341_CYAN, ILI9341_BLACK);
tft.setCursor(126, zl5);
tft.print(clock.readTemperature());
tft.print("C ");
if (BTserial.available() > 0) {
delay(100);
String readString = BTserial.readString();
int firstClosingBracket = readString.indexOf('<');
int secondClosingBracket = readString.indexOf('>', firstClosingBracket + 1);
String readString1 = readString.substring(firstClosingBracket + 1, secondClosingBracket);
if (readString1.length() > 17) { readString1.remove(17); }
tft.setTextColor(ILI9341_GREEN, ILI9341_BLACK);
tft.setCursor(0, zl4);
tft.print(readString1);
readString = "";
readString1 = "";
tft.print("Kein Signal ");
tft.setCursor(120, zl7);
//tft.print(" ");
void displayBacklight() {
if (displayIsOn && (millis() - displayTimeout <= DISPLAY_TIMEOUT)) {
tft.setTextColor(ILI9341_ORANGE, ILI9341_BLACK);
unsigned long count1 = ((millis() - displayTimeout) / 1000) + 1;
unsigned long count2 = (DISPLAY_TIMEOUT / 1000) + 1;
tft.print(String(abs(int(count1) - int(count2))) + " Sek.");
//tft.print(String(((millis() - displayTimeout) / 1000) + 1) + " Sek.");
if (entfernung > 0 && entfernung <= 10) {
displayTimeout = millis();
if (!displayIsOn) {
displayIsOn = true;
return;
if (displayIsOn && (millis() - displayTimeout > DISPLAY_TIMEOUT)) {
tft.print(" ");
void digitalClockDisplay() {
tft.print(day());
tft.print(".");
tft.print(month());
tft.print(".");
/*tft.print(String(year()).substring(2, 4));
tft.print(" ");
printDigits(hour());
tft.print(":");
tft.print(":");
void printDigits(int digits) {
if (digits < 10)
tft.print('0');
tft.print(digits);
time_t getNtpTime() {
// Send request
tft.print("NTP Request");
tft.print(" failed");
// Wait for reply
tft.print("Receive NTP");
tft.print("No NTP Response");
return 0;
time_t getDstCorrectedTime(void) {
time_t t = getNtpTime();
if (t > 0) {
TimeElements tm;
breakTime(t, tm);
t += (utcOffset + dstOffset(tm.Day, tm.Month, tm.Year + 1970, tm.Hour)) * SECS_PER_HOUR;
return t;
byte dstOffset(byte d, byte m, unsigned int y, byte h) {
if ((m > 3 && m < 10) || (m == 3 && (d > dstOn || (d == dstOn && h >= 1))) || (m == 10 && (d < dstOff || (d == dstOff && h <= 1))))
return 1;
return 0;
And it works ... except for the Day and Month at digitalClockDisplay().
I get something like 35 for the Day and 13 for the Month.
I compared and checked both Sketches over and over but I can't figure out what's wrong.
I get a correct Unix-Time back from the Functions.
I know this is a big Request but I don't know what to do next. So I would really appreciate it if someone could have a Look at the Sketches and can maybe find out what's the Problem.
