Hi everyone. I am a rookie with the Arduino and more a java programmer yet then C++. I have a connect issue with this sensor so I went to look around the web, on Youtube, forums and still can't correct this issue. I am not even sure anymore that the sensor might be a factory defect.
I am using the DHTlib as posted on the manufacturer website. There is a slight difference between the + and Signal which are inverted as opposed to the majority of sensor I saw on the website.
I have attached screenshots to this topic. I am using many test examples from Rob Tillaart DHT lib but changing the PIN to 0. I did try to move to another analog pin and even digital.
I hope this is enough information to get help. If you think more is needed, please let me know. Thanks everyone in advance for your time and help.
