Humidifier: change wiring/code for DHT11 to AHT11
Hi, question for my very first Arduino project. I'm trying to build a humidity controller for growing mushrooms. The basic idea is to turn on an atomization disc until the humidity sensor reads 90% and then shut off. I found one online and bought the parts, but when I went to order the humidity sensor (DHT11), the part offered instead was an AHT10, which apparently is more accurate. However, it has a different pin configuration, which throws off the schematic, and the code must be different as well.
Unfortunately, I really don't understand what I'm doing well enough to make the adjustments. I'll include the schematic and code. I'm hoping to learn as I go, so if you could explain what the changes are and what they do, I'd really appreciate it.
#include "U8glib.h"
U8GLIB_SSD1306_128X64 u8g(U8G_I2C_OPT_NONE);//Set the device name: I2C-SSD1306-128*64 (OLED)
#include "DHT.h"
#define DHTPIN A0
#define DHTTYPE DHT11
#define jiashi 2
#define button 12
DHT dht(DHTPIN, DHTTYPE);
  pinMode(jiashi,OUTPUT);
  pinMode(button,INPUT);
  dht.begin();
  float Humid = dht.readHumidity();
  float Temp = dht.readTemperature();
  Serial.print("Temp");
  Serial.print(Temp);
  Serial.print("Humid");
  Serial.print(Humid);
  u8g.firstPage();
  do
    u8g.setFont(u8g_font_gdr14r);
    u8g.setPrintPos(25,18);
    u8g.print("DKARDU");
    u8g.setFont(u8g_font_9x18);
    u8g.setPrintPos(1,40);
    u8g.print("Temp: ");
    u8g.print(Temp);
    u8g.print("'C");
    u8g.setPrintPos(1,60);
    u8g.print("Humid: ");
    u8g.print(Humid);
    u8g.print("%");
  }while(u8g.nextPage());
if(Humid<80){
  digitalWrite(jiashi,LOW);
}else
  digitalWrite(jiashi,HIGH);
The AHT10 seems to be "I2C", so you will have the Arduino 5V pin go to AHT10 Vcc, Arduino GND to AHT10 GND, Arduino A4 go to AHT10 SDA and Arduino A5 go to AHT10 SCL.
Find an AHT10 sketch. Compare it to the DHT11 sketch. You will need to remove (or comment-out) many "DHT" lines and modify (or add) many AHT10 lines. Here is a sketch to compare.
