This is NOT my code; was posted on Project Hub. I tried to use the code (humidity controller) but it returns an error on line 270:
Error: expected primary-expression before '.' token
The OP is not responding to comments and I'm no expert. Would appreciate if someone could help debug the code; Thanks!
//HUMIDITY CONTROLLER 1.1
//written for NANO
//controls and displays relative humidity
//sesnor used is DHT11
//uses active-low relay module to control live lines for 2 standard electrical outlets
//uses i2c lcd to display humidity and humidity setting
//turns display off during inactivity
//setting is adjustable from 10%-90% using 2 buttons
//backlight of LCD is controlled by pin 4, connected to top LED jumper pin on i2c backpack
//serial communications to monitor to ensure all code is working.
//added: "system off" function - allows both outlets to be turned off
// █ G █ L █ O █ B █ A █ L █ S █
#include <Wire.h>
#include <DHT.h>
// set the LCD address to 0x27 for a 16 chars and 2 line display
LiquidCrystal_I2C lcd(0x3F, 16, 2);
DHT DHT_sens(10, DHT22);
#define DHT22_PIN A2
//buttons and variables to adjust calibration
int calupbtn = A0;
int calup;
int caldownbtn = A1;
int caldown;
//i2c PINS A4, A5
//pin for turning on humidifier relay
int humidifier = 3;
//pin for turning on the fan relay
int fan = 2;
//pin for turning on LCD backlights
int lcdlight = 4;
//calibration variable
int setpoint = 50; //feedback setpoint.
bool calstate = false; //enables calibration adjustments only when LCD is ON.
//backlight timing variables
int displtime = 12000; //amount of time the display is to be on before turning off
unsigned long displtimeon; //last recorded time display timer was reset
int calunlock = 0; //loop counter for unlocking calibration
//sensor timing variables
unsigned long lastcheck; //last time DHT was read
long interval = 30000; //time between DHT readings
//system variables
bool syson = true; //reference for system on/off.
byte systog = 2; //even number toggles on, odds toggle off
int syslock = 0; //loop counter for unlocking system toggle
// █ S █ E █ T █ U █ P █
Serial.begin(9600); //serial communication used to ensure code is working correctly.
lcd.init(); //initialize LCD
lcd.backlight(); //enable LCD backlight, but doesn't turn it on
lastcheck = 0;
digitalWrite(lcdlight, HIGH);
Serial.println("STARTING");
lcd.print(" STARTING");
//pin assignments
pinMode(calupbtn, INPUT);
pinMode(caldownbtn, INPUT);
pinMode(humidifier, OUTPUT);
pinMode(fan, OUTPUT);
pinMode(lcdlight, OUTPUT);
//test fan
lcd.setCursor(0, 1);
lcd.print("<FAN> HMDFR ");
digitalWrite(fan, LOW);
digitalWrite(humidifier, HIGH);
delay(6000);
//test humidifier
lcd.print(" FAN <HMDFR> ");
digitalWrite(fan, HIGH);
digitalWrite(humidifier, LOW);
delay(6000);
//stop startup test
lcd.clear();
displtimeon = millis();
int chk = DHT.read11(DHT11_PIN);
lastcheck = millis();
lcd.setCursor(0, 0);
lcd.print("Humidity: ");
lcd.setCursor(13, 0);
lcd.print(DHT.humidity);
lcd.setCursor(15, 0);
lcd.print("% ");
lcd.print("setting: ");
lcd.setCursor(13, 1);
lcd.print(setpoint);
lcd.setCursor(15, 1);
lcd.print("% ");
delay(100);
// █ L █ O █ O █ P █
//check calibration buttons
calup = digitalRead(calupbtn);
caldown = digitalRead(caldownbtn);
if (calup == HIGH and caldown == HIGH) { //--------SYSTEM TOGGLE
syslock ++;
Serial.println(syslock);
if (syslock == 20) { //if both buttons held down for this many loops
systog++;
if (systog % 2 == 1) { //--------SYSTEM OFF
syson = false;
Serial.println("SYSTEM TURNED OFF");
lcd.clear();
lcd.print(" SYSTEM OFF");
lcd.print(" hold both btns");
delay(2000);
lcd.print(" to turn on ");
if (systog % 2 == 0) { //--------SYSTEM ON
syson = true;
Serial.println("SYSTEM TURNED ON");
lcd.clear();
lcd.print(" SYSTEM ON");
delay(2000);
lcd.clear();
syslock = 0;
else(syslock = 0);
//read humidity at appropriate intervals
if (millis() > lastcheck + interval and syson == true) { //read the DHT humidity
Serial.print("DHT read = ");
Serial.print(DHT.humidity);
Serial.print("%");
Serial.println(" ");
//turn on the led lights when calibration buttons are pressed
if (calup == HIGH xor caldown == HIGH) {
calstate = true;
displtimeon = millis(); //set display timer
Serial.println("cal btn ACTIVE");
if (syson == false) {
lcd.clear();
delay(3000);
if (calstate == true and syson == true) { //--------DISPLAY ROUTINE
Serial.println("printing display");
//display variables on LCD
lcd.print("% ");
lcd.print("% ");
delay(100);
calunlock ++;
//keeps calibration locked until display cycles 5 times after initially turned on
//prevents adjustments on initial button press.
//--------CALIBRATION ADJUSTMENTS
if (calup == HIGH and caldown == LOW and calstate == true and syson == true) {
if (setpoint < 90 and calunlock > 5) {
setpoint = setpoint + 5; //increase setpoint
Serial.println("adj setpoint up");
Serial.println(setpoint);
delay(100);
displtimeon = millis(); //reset backlight timeout
if (caldown == HIGH and calup == LOW and calstate == true and syson == true) {
if (setpoint > 10 and calunlock > 5) {
setpoint = setpoint - 5; //decrease setpoint
Serial.println("adj setpoint dn");
delay(100);
if (millis() > displtimeon + displtime) { //-----------------BACKLIGHT TIMEOUT
digitalWrite(lcdlight, LOW); //turn off the screen
calstate = false;
Serial.println("displ + backlights off");
lcd.clear();
calunlock = 0; //lock calibration
if (millis() < lastcheck) {
lastcheck = millis(); //reset timers in a millisecond rollover
//--------SETPOINT ERROR PROCEDURE
if (setpoint > 91 or setpoint < 9) { //in case setpoint is ever out of bounds
Serial.println("O/B ERROR");
lcd.clear();
lcd.print("O/B ERROR"); //display error message on lcd
lcd.print("RESETTING");
for (int count = 9; count >= 0; count = count - 1) {
lcd.print(count); //count down from 10
setpoint = 50; //reset setpoint at 50.
//turn on humidifier relay if below setpoint --------RELAY CONTROL
//RELAY MODULE IS ACTIVE LOW
if (DHT.humidity <= setpoint - 3 and syson == true) { //if humidity is 3% lower than setpoint
Serial.println("humidifier ON, fan OFF");
digitalWrite(humidifier, LOW); //turn on humidifier
else if (DHT.humidity >= setpoint + 3 and syson == true) { //if humidity is 3% above setpoint
Serial.println("humidifier OFF, fan ON");
digitalWrite(humidifier, HIGH); //turn on fan
else {
Serial.println("all off"); //if humidity is within 3% of setpoint
digitalWrite(humidifier, HIGH); //turn both off
//delay(700); //un-comment for serial debugging
Serial.print("setpoint = ");
