humidity control - by boiling water
hello everyone,
i'm trying to think of a cheap way to control the level of humidity entering a small size box (about 604050 cm).
the general idea is that i have a box and i'm investigating condensation rates within the box, and i want to do it for a range of input air humidities.
so far i just covered the area surrounding the air entry hole with a nylon and placed underneath it an electric cooker (very weak power) and a pot filled with water.
i want to do something more robust, and i was wondering if it will be possible to program an arduino with a DHT22 at the air entry point to regulate the power of the heater so that i will have steady humidity of input air.
meaning i could just type in the code a specific Relative Humidity and the arduino will start tuning the heating power until it reaches the desired level, then just make sure it stays constant.
i guess my main question is-
what kind of heater do you think i might be able to control using an arduino (and how?)
also, is there anything i'm not thinking about that might interfere with my idea?
thank you very much!
The ability of air to carry water is based on temperature
Humidity can easeasily Be changed by dropping temperature.
If you have a hot box at 50% RH and cool it the humidity will increase.
Lots of ways to change humidity.
Another is to blow air aacross a cotton washrag.
But yes you can play with air flows and temperatures and .watet and heatets with an arduino
I think you will also want to look into a more accurate, faster, and generally more reliable sensor than the DHT22 to measure humidity. Such as the BME280.
