Humidity DHT11 Sensor not working
Hello, I follow this
#include <DHT11.h>
dht11 DHT11;
#define DHT11PIN 2
  Serial.println("DHT11 TEST PROGRAM ");
  Serial.print("LIBRARY VERSION: ");
  Serial.println(DHT11LIB_VERSION);
double Fahrenheit(double celsius)
  return 1.8 * celsius + 32;
  Serial.println("\n");
  int chk = DHT11.read(DHT11PIN);
  Serial.print("Read sensor: ");
  switch (chk)
    case 0: Serial.println("OK"); break;
    case -1: Serial.println("Checksum error"); break;
    case -2: Serial.println("Time out error"); break;
    default: Serial.println("Unknown error"); break;
  Serial.print("Humidity (%): ");
  Serial.println((float)DHT11.humidity, 2);
  Serial.print("Temperature (oC): ");
  Serial.println((float)DHT11.temperature, 2);
  Serial.print("Temperature (oF): ");
  Serial.println(Fahrenheit(DHT11.temperature), 2);
  delay(2000);
with the following:
 * DH11.h
 *  Created on: 2012. 12. 12.
 *      Author: dalxx
 *      Version : 0.8
#ifndef DHT11_H_
#define DHT11_H_
#include <Arduino.h>
#define DHT11_RETRY_DELAY 1000  // 1000ms
class DHT11 {
	int pin;
	unsigned long last_read_time;
protected:
	byte readByte();
	unsigned long waitFor(uint8_t target, unsigned long time_out_us);
	void waitFor(uint8_t target);
public:
	DHT11(int pin_number);
	~DHT11();
	int read( float& humidity, float& temperature);
#endif /* DHT11_H_ */
and this
 * DH11.cpp
 *      Author: dalxx
#include "DHT11.h"
DHT11::DHT11(int pin_number) {
	this->pin=pin_number;
	this->last_read_time=0;
	pinMode(pin,INPUT);
	digitalWrite(pin, HIGH);
//wait for target status
//parameters
//  target : target status waiting for
//  time_out_us : time out in microsecond.
unsigned long DHT11::waitFor(uint8_t target, unsigned long time_out_us) {
	unsigned long start=micros();
	unsigned long time_out=start+time_out_us;
	while(digitalRead(this->pin)!=target)
		if(time_out<micros()) return -1;
	return micros()-start;
//wait for target status.
void DHT11::waitFor(uint8_t target) {
	while(digitalRead(this->pin)!=target);
//read one bye
byte DHT11::readByte() {
	int i=0;
	byte ret=0;
	for(i=7;i>=0;i--)
		waitFor(HIGH); //wait for 50us in LOW status
		delayMicroseconds(30); //wait for 30us
		if(digitalRead(this->pin)==HIGH) //if HIGH status lasts for 30us, the bit is 1;
			ret|=1<<(i);
			waitFor(LOW); //wait for rest time in HIGH status.
	return ret;
DHT11::~DHT11() {
	// TODO Auto-generated destructor stub
//parameters
//	temperature : temperature to read.
//	humidity : humidity to read.
//return -1 : read too shortly. retry latter .
//		  0 : read successfully
//        1 : DHT11 not ready.
//		  4 : Checksum Error
int DHT11::read(float& humidity, float& temperature) {
	if((millis()-this->last_read_time<DHT11_RETRY_DELAY)&&this->last_read_time!=0)	return -1;
	pinMode(pin,OUTPUT);
	digitalWrite(pin, LOW);
	delay(18);
	pinMode(pin,INPUT);
	if(waitFor(LOW, 40)<0)	return 1; //waiting for DH11 ready
	if(waitFor(HIGH, 90)<0)	return 1; //waiting for first LOW signal(80us)
	if(waitFor(LOW, 90)<0)	return 1; //waiting for first HIGH signal(80us)
	byte hI=this->readByte();
	byte hF=this->readByte();
	byte tI=this->readByte();
	byte tF=this->readByte();
	byte cksum=this->readByte();
	if(hI+hF+tI+tF!=cksum)
		return 4;
	humidity=(float)hI+(((float)hF)/100.0F);
	temperature=(float)tI+(((float)tF)/100.0F);
	this->last_read_time=millis();
	return 0;
but I take the following error:
HUMIDITY_sensor:3: error: 'dht11' does not name a type
dht11 DHT11;
C:\Users\arduino\HUMIDITY_sensor\HUMIDITY_sensor.ino: In function 'void setup()':
HUMIDITY_sensor:12: error: 'DHT11LIB_VERSION' was not declared in this scope
C:\Users\arduino\HUMIDITY_sensor\HUMIDITY_sensor.ino: In function 'void loop()':
HUMIDITY_sensor:25: error: expected primary-expression before '.' token
HUMIDITY_sensor:37: error: expected primary-expression before '.' token
HUMIDITY_sensor:40: error: expected primary-expression before '.' token
HUMIDITY_sensor:43: error: expected primary-expression before '.' token
exit status 1
option enabled in File -> Preferences.
I took the code from here:
The library I found it somewhere on the net.
Ok, i fixed it. You can lock the topic!
