Humidity sensor does not work when a SD card shield is used
Hi all,
since some months, I am learning to work with an Arduino and I now have run into my first serious problem.
I have bought an moisture sensor and got it to work instantly on my arduino.
But as soon as I add an SD card shield, the moisture sensor no longer works, it gives me constant readings of 1023.
I was using analoge port 0 for starters and guessed that the shield was doing something with this port so I also tried the other analoge port. Unfortunately, they result in the same response: 1023. Also, if I unplug the sensor I still receive 1023 as a response.
The data logging shield in question is the Deek-robot data logging shield 1.0.
moisture sensor http://www.seeedstudio.com/wiki/Grove_-_Moisture_Sensor
SD shield http://www.play-zone.ch/en/dk-data-logging-shield-v1-0.html
Also, the SD card shield seems to work fine because when I add a AM2315 humidity sensor it has no problem logging data.
Also, when I use the data shield together with the moisture sensor but only add the code for the moisture sensor it works as expected
int sensorPin = A0;    // select the input pin for the potentiometer
int sensorValue = 0;  // variable to store the value coming from the sensor
  // declare the ledPin as an OUTPUT:
  // read the value from the sensor:
  sensorValue = analogRead(sensorPin);
  Serial.print("sensor = " );
  Serial.println(sensorValue);
So clearly some part of the SD Card code is messing up my analogue ports
#include <SD.h>
#include <Wire.h>
#include "RTClib.h"
#include <Wire.h>
// A simple data logger for the Arduino analog pins
// how many milliseconds between grabbing data and logging it. 1000 ms is once a second
#define LOG_INTERVAL  1000 // mills between entries (reduce to take more/faster data)
// how many milliseconds before writing the logged data permanently to disk
// set it to the LOG_INTERVAL to write each time (safest)
// set it to 10*LOG_INTERVAL to write all data every 10 datareads, you could lose up to
// the last 10 reads if power is lost but it uses less power and is much faster!
#define SYNC_INTERVAL 1000 // mills between calls to flush() - to write data to the card
uint32_t syncTime = 0; // time of last sync()
#define ECHO_TO_SERIAL   1 // echo data to serial port
#define WAIT_TO_START    0 // Wait for serial input in setup()
RTC_DS1307 RTC; // define the Real Time Clock object
// for the data logging shield, we use digital pin 10 for the SD cs line
const int chipSelect = 10;
// the logging file
File logfile;
int sensorPin1 = A0;    // select the input pin for the potentiometer 1
int sensorValue1 = 0;  // variable to store the value coming from the sensor
void error(char *str)
  Serial.print("error: ");
  Serial.println(str);
  while(1);
void setup(void)
#if WAIT_TO_START
  Serial.println("Type any character to start");
  while (!Serial.available());
#endif //WAIT_TO_START
  // initialize the SD card
  Serial.print("Initializing SD card...");
  // make sure that the default chip select pin is set to
  // output, even if you don't use it:
  pinMode(10, OUTPUT);
  // see if the card is present and can be initialized:
  if (!SD.begin(chipSelect)) {
    error("Card failed, or not present");
  Serial.println("card initialized.");
  // create a new file
  char filename[] = "LOGGER00.CSV";
  for (uint8_t i = 0; i < 100; i++) {
    filename[6] = i/10 + '0';
    filename[7] = i%10 + '0';
    if (! SD.exists(filename)) {
      // only open a new file if it doesn't exist
      logfile = SD.open(filename, FILE_WRITE);
      break;  // leave the loop!
  if (! logfile) {
    error("couldnt create file");
  Serial.print("Logging to: ");
  Serial.println(filename);
  // connect to RTC
  Wire.begin();
  if (!RTC.begin()) {
    logfile.println("RTC failed");
#if ECHO_TO_SERIAL
    Serial.println("RTC failed");
#endif  //ECHO_TO_SERIAL
  logfile.println("millis,stamp,datetime,moisture_level");
#if ECHO_TO_SERIAL
  Serial.println("millis,stamp,datetime,moisture_level");
  // If you want to set the aref to something other than 5v
  analogReference(EXTERNAL);
void loop(void)
  DateTime now;
  // delay for the amount of time we want between readings
  delay((LOG_INTERVAL -1) - (millis() % LOG_INTERVAL));
  // log milliseconds since starting
  uint32_t m = millis();
  logfile.print(m);           // milliseconds since start
  logfile.print(", ");
#if ECHO_TO_SERIAL
  Serial.print(m);         // milliseconds since start
  Serial.print(", ");
#endif
  // fetch the time
  now = RTC.now();
  // log time
  logfile.print(now.unixtime()); // seconds since 1/1/1970
  logfile.print('"');
  logfile.print(now.year(), DEC);
  logfile.print("/");
  logfile.print(now.month(), DEC);
  logfile.print("/");
  logfile.print(now.day(), DEC);
  logfile.print(" ");
  logfile.print(now.hour(), DEC);
  logfile.print(":");
  logfile.print(now.minute(), DEC);
  logfile.print(":");
  logfile.print(now.second(), DEC);
  logfile.print('"');
#if ECHO_TO_SERIAL
  // Serial.print(now.unixtime()); // seconds since 1/1/1970
  // Serial.print(", ");
  // Serial.print('"');
  Serial.print(now.year(), DEC);
  Serial.print("/");
  Serial.print(now.month(), DEC);
  Serial.print("/");
  Serial.print(now.day(), DEC);
  Serial.print(" ");
  Serial.print(now.hour(), DEC);
  Serial.print(":");
  Serial.print(now.minute(), DEC);
  Serial.print(":");
  Serial.print(now.second(), DEC);
  //Serial.print('"');
  Serial.print(" - ");
  sensorValue1 = analogRead(sensorPin1);
  Serial.print("sensor 1 = " );
  Serial.println(sensorValue1);
  logfile.print(sensorValue1);
   logfile.println();
  // Now we write data to disk! Don't sync too often - requires 2048 bytes of I/O to SD card
  // which uses a bunch of power and takes time
  if ((millis() - syncTime) < SYNC_INTERVAL) return;
  syncTime = millis();
  logfile.flush();
any tips on how to continue are greatly appreciated.
When you post with questions about hardware you are expected to post the datasheets or links to the specifications for any hardware referenced in your post. You listed the names of the shield and the sensor. Please follow up by clicking the Modify button and adding the links to the vendor websites for these items.
Since I was unable to find the problem I tried some other code from the arduino website and with some modification I was able to get it to work.
So idea yet were the problem is in the previous code but at least I can log data from the humidity sensor to the SD card.
  SD card datalogger
 This example shows how to log data from three analog sensors
 to an SD card using the SD library.
 The circuit:
 * analog sensors on analog ins 0, 1, and 2
 * SD card attached to SPI bus as follows:
 ** MOSI - pin 11
 ** MISO - pin 12
 ** CLK - pin 13
 ** CS - pin 4
 created  24 Nov 2010
 modified 9 Apr 2012
 by Tom Igoe
 This example code is in the public domain.
#include <SD.h>
// On the Ethernet Shield, CS is pin 4. Note that even if it's not
// used as the CS pin, the hardware CS pin (10 on most Arduino boards,
// 53 on the Mega) must be left as an output or the SD library
// functions will not work.
   while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
    Serial.println("Card failed, or not present");
    // don't do anything more:
    return;
  // make a string for assembling the data to log:
  String dataString = "";
  // read three sensors and append to the string:
  // open the file. note that only one file can be open at a time,
  // so you have to close this one before opening another.
  File dataFile = SD.open("datalog.txt", FILE_WRITE);
  // if the file is available, write to it:
  dataFile.print("sensor = ");
  dataFile.println(sensorValue);
  dataFile.close();
