I built a circuit as shown in the HS1101 data sheet:
sensor ground pin to ground
10 mega ohm pullup resistor between ground and sensor pin
220 ohm resistor between sensor pin and digital pin 4 of my Arduino Uno
I'm getting readings of -35 give or take 2-3 using that code. If I breathe on the sensor a few times, the readings jump to -62 give or take 2-3.
So obviously I have a sign issue. Also am off by a factor of just under 2 it would seem. Ambient temp in my room is 70F, so temp correction shouldn't be a big deal as it's close to std.
I noticed the author of that code mentioned using a 2 mega ohm resistor instead of the 10M speced in the data sheet. I just swapped that and get readings of around -41.
Here's where it gets interesting. I dug up an old Radio Shack temp/humidity gauge I had buried with my beer brewing equipment. It's reading 36% sitting on my desk, which is pretty dam close to what the Humirel is saying (after ignoring the sign issue). If I breathe into it a few times it jumps to around 84% which is a little more than the Humirel jumped but still in the ballpark.
Not sure if I should leave his formula as is and experiment with different resistor values (not the pulldown, the RC) or tweak his formula: #define RH1(time) ((.1667*time)-67)
...based on some extrapolation. Or maybe try to mess around with the formula in the data sheet instead: (Time - RHConstant) / 24 where RHConstant is 12169 (though not sure what that is based on and may be different for Arduino).
I don't think the code in that link is correct. Good approach, but there are problems with the implementation - should not use the same pin to charge, discharge, and measure; also should not be using a digital pin to measure the decay rate (HIGH is 5V, but LOW could really be anything below 5V).
I have some code I'm testing now, using separate pins to charge and discharge and an analog pin to measure the time. I started with the code in the capacitance meter example:
This code works very well. I was able to accurately measure some caps I have from 100 uf down to 2 nf. It's spot on.
But I have run into a few issues using this with the sensor. The capacitance of the sensor is very low, regardless of humidity. But the biggest problem is I simply can't get the capacitor to charge to 5V no matter how long I keep the chargepin on. It will charge to around 1.61V and if I breathe heavily onto it I can get it to charge to 1.78V.
Nothing I've found really works well, so I started from scratch.
Wiring Instructions: Sensor ground to ground. Digital pin 13 to 10k ohm resistor to sensor input (series). Sensor input to 220 ohm resistor to digital pin 11 (series). Analog pin 0 to sesnsor input.
Future enhancements: 1) Find a way to more fully charge before discharging. 2) take average of several readings before displaying value as in previous code. 3) tweak the relHum calculation.
int analogPin = 0;
int chargePin = 13;
int dischargePin = 11;
unsigned long startTime;
unsigned long elapsedTime;
float relHum;
void setup(){
pinMode(chargePin, OUTPUT);
digitalWrite(chargePin, LOW);
void loop(){
digitalWrite(chargePin, HIGH); // charge capacitor
while(analogRead(analogPin) < 300){
//A full 5V should be a value of 1023, but I can only get it to vary from 330-365
digitalWrite(chargePin, LOW); // turn off charge pin
startTime = micros();
pinMode(dischargePin, OUTPUT); // set discharge pin to output
digitalWrite(dischargePin, LOW); // discharge capacitor
while(analogRead(analogPin) > 0){ // wait until capacitor is fully discharged
elapsedTime = micros() - startTime; // calculate decay time
relHum = ((elapsedTime * 0.2143) + 9.43); //simple algebra from a few known values with another humidity meter
Serial.println(relHum); // print the value to serial monitor
pinMode(dischargePin, INPUT); // reset discharge pin
delay(1000); // let it settle
I wouldn't rely on this, but it's in the ballpark, giving values within 5% or so of my Radio Shack humidity meter. It's a little slow to react sometimes and tends to randomly bounce around a bit though.
After trying some other different approach to get HS1101 working without 555 I found your post.
I followed your wiring tips and uploaded the sketch but i can't get a realistic value...
I found that th HS1101 is discharging always in approx. 120 us.
