When My Arduino SD Card Module Music Player gets connected with USB power line, everything regarding sound output goes smooth and clear
But whenever I connected it to an external power supply source using an adapter via jack pin & 9v socket I am getting a severe humming or noise sound at speakers
What to do ??
Which type of power supply with what parameters i need to have here ?
I once bought a wall wart at a thrift store. It was marked 10 VDC. When it would not work properly, I actually read the label. It was 10 VAC! What does your power supply have on it and where did you get it?
No only when a power supply is coknexted at 9v socket line
Rest I applied a mobile charger at USB port abd its working fine
Means wirh USB everything is good but not with socket line
OK. So if it happens when only power supply and no USB is connected, it's not likely a ground noise problem (looks like @JohnRob and I had the same thought there). 12V@2A should be more than USB can provide, so it's likely not an overdriven power supply.
If a large capacitor on the input isn't having an effect, I have to wonder if it's your onboard regulator. Some arduino clones can only take 9V max at Vin (so I've heard, I haven't come across this problem personally), so it's plausible that it's the regulator's reaction to an over-limit input.
Without seeing the actual waveform that the power supply is putting out, that's my best guess.
