#include <Servo.h>
Servo x;
Servo y;
Servo grip;
int potpin = A0;
int val;
int potpin2 = A1;
int val;
val = 1
int potpin3 = A2;
int val;
val = 1
servox.attach(2)
servoy.attach(3)
servogrip.attach(4)
val = analogRead(potpin); // reads the value of the potentiometer (value between 0 and 1023)
val = map(val, 0, 1023, 0, 180); // scale it for use with the servo (value between 0 and 180)
Servox.write(val); // sets the servo position according to the scaled value
delay(15);
Servoy.write(val); // sets the servo position according to the scaled value
delay(15);
Servogrip.write(val); // sets the servo position according to the scaled value
delay(15);
Thanks for using code tags on your first post!
What is the problem?
Hint: lines like these must be in the loop() or setup() functions. Terminate the line with a semicolon.
val = 1
Correct these errors in the // comments
#include <Servo.h>
Servo x; // this should be servox
Servo y; // this should be servoy
Servo grip; // this should be servogrip
int potpin = A0;
int val;
int potpin2 = A1;
int val; // remove the re-definition of val
val = 1 // missing closing semi-colon
int potpin3 = A2;
val = 1 // remove the re-definition of val
servox.attach(2) // missing the closing semi-colon
servoy.attach(3) // missing the closing semi-colon
servogrip.attach(4) // missing the closing semi-colon
Servox.write(val); // lower-case "s" in servox
delay(15);
val = analogRead(potpin); // using the same pot as servox
Servoy.write(val); // lower case "s" in servoy
delay(15);
Servogrip.write(val); // lower case "s" in servogrip
delay(15);
