HWT9053 interfacing with wemos D1 mini via rs-485
Hello,
I am trying to get data from HWT9053 sensor with D1 mini board via modbus (rs485), but I am not getting readings. Has anyone done it before? This is my code:
#include <SoftwareSerial.h>
#include "REG.h"
#include "wit_c_sdk.h"
#define ACC_UPDATE    0x01
#define GYRO_UPDATE   0x02
#define ANGLE_UPDATE  0x04
#define MAG_UPDATE    0x08
#define READ_UPDATE   0x80
static volatile char s_cDataUpdate = 0, s_cCmd = 0xff;
static void CmdProcess(void);
static void RS485_IO_Init(void);
static void AutoScanSensor(void);
static void SensorUartSend(uint8_t *p_data, uint32_t uiSize);
static void CopeSensorData(uint32_t uiReg, uint32_t uiRegNum);
static void Delayms(uint16_t ucMs);
const uint32_t c_uiBaud[8] = { 0, 4800, 9600, 19200, 38400, 57600, 115200, 230400};
#define RX_PIN 5 //D1
#define TX_PIN 2 //D4
SoftwareSerial Serialx(RX_PIN, TX_PIN,false); //RX TX
  Serialx.begin(115200);
  RS485_IO_Init();
  WitInit(WIT_PROTOCOL_MODBUS, 0x50);
  WitSerialWriteRegister(SensorUartSend);
  WitRegisterCallBack(CopeSensorData);
  WitDelayMsRegister(Delayms);
  Serial.print("\r\n********************** wit-motion modbus example  ************************\r\n");
  AutoScanSensor();
int i;
float fAcc[3], fGyro[3], fAngle[3];
  WitReadReg(AX, 12);
    while (Serialx.available())
      WitSerialDataIn(Serialx.read());
    while (Serial.available())
      CopeCmdData(Serial.read());
    CmdProcess();
    if(s_cDataUpdate)
      for(i = 0; i < 3; i++)
        fAcc[i] = sReg[AX+i] / 32768.0f * 16.0f;
        fGyro[i] = sReg[GX+i] / 32768.0f * 2000.0f;
        fAngle[i] = sReg[Roll+i] / 32768.0f * 180.0f;
      if(s_cDataUpdate & ACC_UPDATE)
        Serial.print("acc:");
        Serial.print(fAcc[0], 3);
        Serial.print(" ");
        Serial.print(fAcc[1], 3);
        Serial.print(" ");
        Serial.print(fAcc[2], 3);
        Serial.print("\r\n");
        s_cDataUpdate &= ~ACC_UPDATE;
      if(s_cDataUpdate & GYRO_UPDATE)
        Serial.print("gyro:");
        Serial.print(fGyro[0], 1);
        Serial.print(" ");
        Serial.print(fGyro[1], 1);
        Serial.print(" ");
        Serial.print(fGyro[2], 1);
        s_cDataUpdate &= ~GYRO_UPDATE;
      if(s_cDataUpdate & ANGLE_UPDATE)
        Serial.print("angle:");
        Serial.print(fAngle[0], 3);
        Serial.print(" ");
        Serial.print(fAngle[1], 3);
        Serial.print(" ");
        Serial.print(fAngle[2], 3);
        s_cDataUpdate &= ~ANGLE_UPDATE;
      if(s_cDataUpdate & MAG_UPDATE)
        Serial.print("mag:");
        Serial.print(sReg[HX]);
        Serial.print(" ");
        Serial.print(sReg[HY]);
        Serial.print(" ");
        Serial.print(sReg[HZ]);
        s_cDataUpdate &= ~MAG_UPDATE;
      s_cDataUpdate = 0;
void CopeCmdData(unsigned char ucData)
  static unsigned char s_ucData[50], s_ucRxCnt = 0;
  s_ucData[s_ucRxCnt++] = ucData;
  if(s_ucRxCnt<3)return;                    //Less than three data returned
  if(s_ucRxCnt >= 50) s_ucRxCnt = 0;
  if(s_ucRxCnt >= 3)
    if((s_ucData[1] == '\r') && (s_ucData[2] == '\n'))
      s_cCmd = s_ucData[0];
      memset(s_ucData,0,50);
      s_ucRxCnt = 0;
      s_ucData[0] = s_ucData[1];
      s_ucData[1] = s_ucData[2];
      s_ucRxCnt = 2;
static void ShowHelp(void)
  Serial.print("\r\n************************   WIT_SDK_DEMO ************************");
  Serial.print("\r\n************************          HELP           ************************\r\n");
  Serial.print("UART SEND:a\\r\\n   Acceleration calibration.\r\n");
  Serial.print("UART SEND:m\\r\\n   Magnetic field calibration,After calibration send:   e\\r\\n   to indicate the end\r\n");
  Serial.print("UART SEND:U\\r\\n   Bandwidth increase.\r\n");
  Serial.print("UART SEND:u\\r\\n   Bandwidth reduction.\r\n");
  Serial.print("UART SEND:B\\r\\n   Baud rate increased to 115200.\r\n");
  Serial.print("UART SEND:b\\r\\n   Baud rate reduction to 9600.\r\n");
  Serial.print("UART SEND:h\\r\\n   help.\r\n");
  Serial.print("******************************************************************************\r\n");
  switch(s_cCmd)
    case 'a': if(WitStartAccCali() != WIT_HAL_OK) Serial.print("\r\nSet AccCali Error\r\n");
    case 'm': if(WitStartMagCali() != WIT_HAL_OK) Serial.print("\r\nSet MagCali Error\r\n");
    case 'e': if(WitStopMagCali() != WIT_HAL_OK) Serial.print("\r\nSet MagCali Error\r\n");
    case 'u': if(WitSetBandwidth(BANDWIDTH_5HZ) != WIT_HAL_OK) Serial.print("\r\nSet Bandwidth Error\r\n");
    case 'U': if(WitSetBandwidth(BANDWIDTH_256HZ) != WIT_HAL_OK) Serial.print("\r\nSet Bandwidth Error\r\n");
    case 'B': if(WitSetUartBaud(WIT_BAUD_115200) != WIT_HAL_OK) Serial.print("\r\nSet Baud Error\r\n");
                 Serialx.begin(c_uiBaud[WIT_BAUD_115200]);
                 Serial.print(" 115200 Baud rate modified successfully\r\n");
    case 'b': if(WitSetUartBaud(WIT_BAUD_9600) != WIT_HAL_OK) Serial.print("\r\nSet Baud Error\r\n");
                Serialx.begin(c_uiBaud[WIT_BAUD_9600]);
                Serial.print(" 9600 Baud rate modified successfully\r\n");
    case 'h': ShowHelp();
    default :return;
  s_cCmd = 0xff;
  pinMode(4, OUTPUT); // for MEGA: 2    for wemos mini: 4 - D2
  digitalWrite(4, HIGH);   // for MEGA: 2
  Serialx.write(p_data, uiSize);
  //Serialx.flush();
  digitalWrite(4, LOW);    // for MEGA: 2
  delay(ucMs);
  int i;
    for(i = 0; i < uiRegNum; i++)
        switch(uiReg)
            case AZ:
        s_cDataUpdate |= ACC_UPDATE;
            case GZ:
        s_cDataUpdate |= GYRO_UPDATE;
            case HZ:
        s_cDataUpdate |= MAG_UPDATE;
            case Yaw:
        s_cDataUpdate |= ANGLE_UPDATE;
            default:
        s_cDataUpdate |= READ_UPDATE;
    uiReg++;
  int i, iRetry;
  for(i = 0; i < sizeof(c_uiBaud)/sizeof(c_uiBaud[0]); i++)
    Serialx.begin(c_uiBaud[i]);
    Serialx.flush();
    iRetry = 2;
    s_cDataUpdate = 0;
    do
      WitReadReg(AX, 3);
      delay(200);
      if(s_cDataUpdate != 0)
        Serial.print(c_uiBaud[i]);
        Serial.print(" baud find sensor\r\n\r\n");
        ShowHelp();
        return ;
      iRetry--;
    }while(iRetry);
  Serial.print("can not find sensor\r\n");
  Serial.print("please check your connection\r\n");
I miss a wiring diagram of your setup. A link to the used library and the device manual may also help.
From material I found about the sensor it seems that 9660 baud is the default rate. Accessing it with 115200 baud won't work. I don't know if the ESP8266 SoftwareSerial holds a 115200 baud speed precise enough for that sensor.
Library which I used:
Link to the documentation/manual:
https://drive.google.com/drive/folders/11PaP_vrL_v8WUi3EaP93EL0DDnkIWSZa?usp=sharing
This is the wiring diagram which i used:
Please reply.
According to the manual the default baudrate is definitely 9600 baud. As you're trying to access it with 115200 baud this might be your problem.
I have changed the baud rate to 9600, still not working
If you read the manual you posted on page 8 it tells you it needs from 5 to 36V. The odds of it working as shown in your picture is the same as my two cozens, slim & none. It works with the Arduino UNO because it is 5V. You will need to translate the levels and power it with 5V.
I think no one here has worked on this sensor, didn't get any working solutions.
I changed my code and tried using different library, it's working now.
