HX710B library problem
Hello everyone
Does anyone know how to deal with this problem??
I have searched many websites but don’t know how to solve it.
thanks
What’s the problem?
just i need use arduino connect HX710B ,and then this line appears when compiling
There will be an error when uploading
The Arduino HX710 library seems to use
ps.initialize (DOUT, SCLK);
Leo..
#include <Wire.h>  // i2C Conection Library
#include <LiquidCrystal_I2C.h>  //i2C LCD Library
#include "HX710B.h"
LiquidCrystal_I2C lcd(0x27, 16, 2);
int btok = 2;
int btup = 3;
int btdown = 4;
int btset = 5;
int btokx;
int btupx;
int btdownx;
int btsetx;
int dataadc;
int nilaimax = 3;
int nilaimin = 0;
float volt;
float mvolt;
float psi;
const int DOUT = 2;   //sensor data pin
const int SCLK  = 3;   //sensor clock pin
HX710B ps;
  lcd.begin();
  lcd.clear();
  lcd.noCursor();
  pinMode(btset,INPUT_PULLUP);
  pinMode(btok,INPUT_PULLUP);
  pinMode(btup,INPUT_PULLUP);
  pinMode(btdown,INPUT_PULLUP);
  btsetx = digitalRead(btset);
  btupx = digitalRead(btup);
  btdownx = digitalRead(btdown);
  btokx = digitalRead(btok);
  psi = ps.psi();
  if (pressure_sensor.is_ready()) {
    Serial.print("PSI: ");
    Serial.println(psi);
    Serial.println("Pressure sensor not found.");
  lcd.setCursor(0, 0);
  lcd.print("Psi=");
  lcd.print(psi);
  lcd.print("   ");
if(psi > nilaimax){
  lcd.setCursor(0, 1);
  lcd.print("Max pressure   ");
if((psi > nilaimin)&&(psi < nilaimax)){
  lcd.print("Normal        ");
if(psi < nilaimin){
  lcd.print("Min pressure  ");
if(btsetx == 0){
  batasatas();
  batasbawah();
delay(200);
void batasatas(){
  lcd.print("Max=");
  lcd.print(nilaimax);
  lcd.print(" psi  ");
  if(btupx == 0){
    delay(200);
    nilaimax++;
  if(btdownx == 0){
    delay(200);
    nilaimax--;
  if(btokx == 0){
    lcd.clear();
    delay(2000);
    return;
batasatas();
void batasbawah(){
  lcd.print("Min=");
  lcd.print(nilaimin);
  lcd.print(" pai  ");
  if(btupx == 0){
    delay(200);
    nilaimin++;
  if(btdownx == 0){
    delay(200);
    nilaimin--;
  if(btokx == 0){
    lcd.clear();
    delay(2000);
    return;
batasbawah();
so you meaning just : pressure_sensor.begin(DOUT,SCLK);
change to : ps.initialize (DOUT, SCLK); ???
or you can change your code , let me know :slight_smile: ?
  1. 清單項目
