HX711 and NODEMCU interfacing code
i want to send the sensor data (i used load cell and HX711) to blink app our in any other app or website where i can stored the runtime data. so please help me for the code...i want to used the NODEMCU....please send me the code.
I have one code but that code give me an error ---
ERROR --> #error This code is not intended to run on the ESP8266 platform! Please check your Tools->Board setting.
the code is attached below
ESP8266_Shield_Blynk_loadcell.ino (4.22 KB)
OP's Code:
   Blynk is a platform with iOS and Android apps to control
   Arduino, Raspberry Pi and the likes over the Internet.
   You can easily build graphic interfaces for all your
   projects by simply dragging and dropping widgets.
     Downloads, docs, tutorials: http://www.blynk.cc
     Blynk community:            http://community.blynk.cc
     Social networks:            http://www.fb.com/blynkapp
                                 http://twitter.com/blynk_app
   Blynk library is licensed under MIT license
   This example code is in public domain.
   This example shows how to use ESP8266 Shield (with AT commands)
   to connect your project to Blynk.
   Note: Ensure a stable serial connection to ESP8266!
         Firmware version 1.0.0 (AT v0.22) is needed.
         You can change ESP baud rate. Connect to AT console and call:
             AT+UART_DEF=9600,8,1,0,0
         In general, Soft Serial may be unstable.
         It is highly recommended to switch to Hard Serial.
   Change WiFi ssid, pass, and Blynk auth token to run :)
   Feel free to apply it to any other example. It's simple!
#define BLYNK_PRINT Serial    // Comment this out to disable prints and save space
#include <ESP8266_Lib.h>
#include <BlynkSimpleShieldEsp8266.h>
#include "HX711.h"
// HX711.DOUT  - pin #A1
// HX711.PD_SCK - pin #A0
HX711 scale(D1, D0);    // parameter "gain" is ommited; the default value 128 is used by the library
// You should get Auth Token in the Blynk App.
// Go to the Project Settings (nut icon).
char auth[] = "2b4160f0556c452797b82e0555fd48ca";
// Your WiFi credentials.
// Set password to "" for open networks.
char ssid[] = "fukat";
char pass[] = "akshay1234";
// Hardware Serial on Mega, Leonardo, Micro...
#define EspSerial Serial
// or Software Serial on Uno, Nano...
//#include <SoftwareSerial.h>
//SoftwareSerial EspSerial(2, 3); // RX, TX
// Your ESP8266 baud rate:
#define ESP8266_BAUD 115200
ESP8266 wifi(&EspSerial);
  Serial.begin(38400);
  Serial.println("HX711 Demo");
  Serial.println("Before setting up the scale:");
  Serial.print("read: \t\t");
  Serial.println(scale.read());      // print a raw reading from the ADC
  Serial.print("read average: \t\t");
  Serial.println(scale.read_average(20));   // print the average of 20 readings from the ADC
  Serial.print("get value: \t\t");
  Serial.println(scale.get_value(5));   // print the average of 5 readings from the ADC minus the tare weight (not set yet)
  Serial.print("get units: \t\t");
  Serial.println(scale.get_units(5), 1);  // print the average of 5 readings from the ADC minus tare weight (not set) divided
  // by the SCALE parameter (not set yet)
  scale.set_scale(6017.4159836065);                      // this value is obtained by calibrating the scale with known weights; see the README for details
  scale.tare();               // reset the scale to 0
  Serial.println("After setting up the scale:");
  Serial.println(scale.get_value(5));   // print the average of 5 readings from the ADC minus the tare weight, set with tare()
  Serial.println(scale.get_units(5), 1);        // print the average of 5 readings from the ADC minus tare weight, divided
  // by the SCALE parameter set with set_scale
  Serial.println("Readings:");
  // Set console baud rate
  delay(10);
  // Set ESP8266 baud rate
  EspSerial.begin(ESP8266_BAUD);
  delay(10);
  Blynk.begin(auth, wifi, ssid, pass);
  Serial.print("one reading:\t");
  Serial.print(scale.get_units(), 1);
  Serial.print("\t| average:\t");
  Serial.println(scale.get_units(10), 1);
  Blynk.virtualWrite(V5, scale.get_units(), 1);
  scale.power_down();              // put the ADC in sleep mode
  scale.power_up();
  Blynk.run();
You're using the wrong library. That code is meant to be run on an Arduino-type board with an ESP8266-based WiFi shield.
If you want to run natively on the ESP8266, look at the example:
File --> Examples --> Blynk --> Boards_WiFi --> ESP8266_Standalone
